Thread: Free Engineering Services - Get your solution verified
    It's for free, try it
    thePetroStreet team provides the listed services in order to cross verify the engineering design / assessment / solution. The objective of providing these services is to provide confidence to the fellow engineers that their engineering assessment is up to the mark. We do not demand the work done by the user but only require a complete problem description. However, if users want to share their working, they can do that. A consolidated results will be given by us but we will not provide any guarantee. In case, the user demands anything in authenticated written format, we may consider providing that.
    We are a group of qualified working professionals of all engineering disciplines related to Petrochemical Industry belonging to different parts of the World. We try our best to confirm our users within 48 hours that the required inputs are OK or we require some more information. We also provide a target date on which we would be able to get back to the user.
    Ashfaq Anwer
    Dear Forum Members,
    Listing of FREE services being given to all is as under:
    Process / Petroleum Services
    Shell & Tube heat exchanger design
    Knockout Drum sizing
    Compressor package design / selection
    Gas turbine rating / selection
    Gas turbine performance check
    Fin-fan heat exchanger design
    Controller tuning of small process
    Simulation of simple process
    Piping network design
    Pump network design
    Instrument air plant design
    Compressor performance efficiency
    Steam turbine performance check
    Distillation column design
    Machinery Diagnostics
    Analysis of small pump vibration data
    Analysis of small turbines vibration data
    Analysis of small compressor vibration data
    Turbomachinery / gas turbine ; diagnostic of ADRE data
    Review of procurement cycle
    Third party inspection
    Inspection & Reliability
    Brittle fracture analysis / MDMT calculations
    Flexibility analysis
    Materials selection
    ASME code issues
    Welding procedure specification
    NDT selection &amp; procedures
    Pressure vessel design
    Inspection procedures for pressure vessels
    Inspection procedures for piping
    Cathodic protection design, implementation, inspection
    Other support requests
  1. Replies: 16
    Last Post: 11-30-2011, 11:49 AM
  2. Free Engineering Services - Get your solution verified
    By ashfaqanwer in forum Oil And Gas Process
    Last Post: 06-03-2010, 07:58 PM
