Results 1 to 7 of 7
Thread: Design Skirt support
    Hi,
    Can some one help me, to design skirt support (for Vertical Pressure Vessels)
    Here is my parameters
    I have a vessel weight of 150000 daN
    A height from the tangente line of the bottom head : 10 meters
    an Outside Diameters of the skirt and of the vessel : 4 meters
    Here is my Problem / Question
    I have a height, with a weight and diameters, i want to know the minimum thickness of the skirt support,
    and how to design the stiffners for the skirt due to the height.
    I looked on codap, asme, and pressure vessel design manual.
    And if i am not mistaken, codes don't take the height in parameters.
    Please, ask for more information (if needed).
    Thanks for help
  3. Ridestar,
    The design of vertical vessel & its skirt is not according to a given weight. Lot of considerations required superimposed loads, internals, liquid, attachments, loads,piping,seismic,wind, lifting, temp. material of your skirt, anchoring etc. these affects your skirt thickness, its time consuming & wish that somebody can help you to run thru software. Overall height is considered on thickness calc. Stiffeners for skirt is not necessary, you need to satisfy the loads without stiffener.
    Gilbert
    Gilbert,
    thank you for replying to my message, yes sorry i was not clear to my message, i meant all what you say.
    But i need to know how to calculate this. Without Software, or at least know if there is a Code construction which explain this problem.
    Thank you again,
  6. Hi, refer to sample calculation on below PV handbook,
  7. You may also read a simplified calculation procedure in Megassey book on pressure vessel design
    Best regards
    Venugopal
    Hi Venugopal,
    Can you give me the link to download the Megassey book
    Please
    Best regards
  10. I remember it was posted in this forum at least twice. Please use search facility.
    Good luck and best regards
    Venugopal
  1. Skirt Support Vessel Design
    By FerchoEs in forum Engineering Spreadsheets & Presentations
    Last Post: 12-13-2013, 08:06 AM
  2. Lug Support Design
    By ghost123ghost in forum Mechanical Engineering
    Last Post: 07-04-2013, 02:23 PM
  3. design for piping support
    By trifilo in forum Pipeline And Fluid Flow
    Last Post: 07-05-2011, 11:42 AM
  4. Skirt design calculation
    By axeus in forum Mechanical Engineering
    Last Post: 11-30-2010, 11:43 AM
  5. design of piping support
    By vvvv in forum Pipeline And Fluid Flow
    Last Post: 07-15-2009, 08:22 PM
