Dear forum members
your help & technical insight is needed for following two cases illustrated below, which i am facing right now as i write:
kindly confirm if PWHT is required for monel 400 piping (weld filler: monel 60) in HCL or caustic environment. In our plant. we have seen severe corrosion of monel weld build up in such environment in our caustic scrubber column in the isom unit of ms plant in our refinery (monel weld build up was severly attacked & reduced to porous honeycomb type dendritic structure). Kindly also suggest the details of PWHT.
Note: In normal cases PWHT is not required as monel is a solid solution alloy & is readily fusion welded, normally in the annealed condition. As the heat affected zone (HAZ) does not harden, heat treatment is not usually required after welding
Also kindly confirm if PWHT is required for SS446 sheathed skin thermocouple welding to T91 heater tube material with inconel-82 filler wire.
if possible kindly mail me or suggest some concrete technical backup at finiteinjustice@gmail.com
with regards
"J"
