Thread: Article: pipeline calculations
  1. Article: pipeline calculations
    You can view the page at
  3. hi kunal ,
    here is what I do in this job.
    first you must to complete caesar II anlyze.
    hoop stress, displacement ..
    with caesar you can have vértical movement ( displacemnt in + y ) , ususually it's less than 0.05 metres.
    caluclate the axiale compressive force...
    calculate allowable axial stress applying vom mises criteria
    and you must ind allowable axial stress < pipeline material yiled stress
    fin the imperfection length using an initial imperfection less 0.3 or 0.25 meters
    after this calculate Weight of cover required W
    calculate weight of soil done at field ,( you have the soil density of of soil and the depth of pipe, and the widh of the dich..
    compare the soil required with the weight of sol done at field
    weight of soil required / weight of soil = (if the value is more than 1.5 ) then the pipeline is safe..
    regards
  5. sorry,
    if the the value = 1 or less , then the pipeline is no safe, you must to put the depth of pipe H more than the first step...
    when H is =1.5 meter...and teh diffence temperature in less than 50° C , no buckling...
    KUNAL
    wud try to give most of them to you by a day or two.....hopefully
  1. pipeline calculations
    By kunal_5683 in forum Pipeline And Fluid Flow
    Last Post: 04-15-2016, 08:52 AM
  2. Piping and pipeline calculations manual
    By aap in forum Mechanical Engineering
    Last Post: 09-07-2015, 11:07 AM
  3. Replies: 20
    Last Post: 09-07-2015, 11:04 AM
  4. Article: Tank Venting Calculations
    By taoxianwen123 in forum Home Articles
    Last Post: 05-02-2011, 10:52 PM
