Page 1 of 2 1 2 LastLast
Results 1 to 12 of 15
Thread: Asme pipeline request
    Would you please upload to this forum the following standard :
    ASME B31J - Standard Test Method for Determining Stress Intensification Factors (i-Factors) for Metallic Piping Components
    ASME STP-PT-011 Integrity Management of Stress Corrosion -----ing in Gas Pipeline High Consequence Areas
    Thank you very much in advance
    fren, i have ASME B31J only :
    Thank you Mr. Luqman
  6. Luqman
    Is the file protected? I downloaded ASME B31J from the link you kindly provided and got a damaged 421 KB .pdf file...
    Error message says: "Error opening file. File is damaged and can not be reapaired"
    Please help...
    Thanks in advance...
  7. Sorry.... the file is ok !!! the download process was interrupted and I didn't notice.... that's why the file was 421 KB instead of 509 KB.
    By the way, Anyone have the ASME B31E - Standard for the Seismic Design and Retrofit of Above-Ground Piping Systems (2008) available?
    fren, here is link for ASME B31E :
    ASME B31E - 2008 in 4Shared:
    [link Point to another website Only the registered members can access] ASME B31G - 2009 in 4Shared:
    [link Point to another website Only the registered members can access] ASME B31J - 2008 in 4Shared:
    Thanks a lot for the cool links
  13. T H A N K S A L O T !!!!!
    Thank you very much for sharing...
  14. Re: Asme pipeline request
    The links are dead.. can anyone re-upload the files? please!
  16. #12
    Nov 2010
    Algiers, ALGERIA
    Quote Originally Posted by shaggex View Post
    Hi,
    Find in 3 posts the requested codes.
    1.
    If you download and find it useful, just click on Thanks button !
    Visit and become a member of
    Welding Engineering & Inspection group
    Here:
  1. API Pipeline & Instrumentation request
    By Achmad Nur Eddin in forum Pipeline And Fluid Flow
    Last Post: 10-07-2015, 11:46 PM
  2. API Pipeline & Instrumentation request
    By Achmad Nur Eddin in forum Instrumentation & Control
    Last Post: 02-10-2010, 07:25 PM
  3. Asme pipeline management
    Last Post: 02-06-2010, 02:28 AM
  4. Piping Systems & Pipeline: ASME Code Simplified
    By sharmeen in forum Pipeline And Fluid Flow
    Last Post: 11-27-2009, 09:32 PM
