Results 1 to 6 of 6
Thread: Emptying of a separator with HYSYS? HELP ME!
  1. Question Emptying of a separator with HYSYS? HELP ME!
    Hello,
    I need to make a dynamic simulation of instantaneous emptying of a separator using HYSYS. How I can do?
    thank you
  3. Hi,
    Can you elaborate your problem? What you are trying to find out is not clear ? Please state your objective, if you know the sep size, outlet pipe size etc .
    I am also in the learning phase. If you elaborate, I will try to work out.
    suresh
  5. Hello,
    I need to simulate the discharge of a separator filled with diesel oil due to the depressurization of this by breaking its control valve. The purpose of this is to calculate the capacity of a PSV.
    thank!
  6. Hi,
    Can I assume that you want to rate/ size the PSV of a vessel?
  7. I need to know what the flow rate in case the control valve is broken and begins to empty the separator and then sizes a PSV located farther.
    that is to say, I need to size the PSV in T-100 in the event that S-100 begins to empty. Here's the case. thank for your atention!
    my mail is cap_pelela@msn.com
  9. pl.send me link as well at rrvr52@aol.com
  1. 3 Phase separator software..SEP-Calc® Separator Design Suite
    By mzafar in forum Oil And Gas Process
    Last Post: 01-15-2015, 08:28 PM
  2. Replies: 3
    Last Post: 05-15-2013, 03:34 PM
