Thread: High pressure steam to reduce into low pressure steam system
  1. Smile High pressure steam to reduce into low pressure steam system
    Hello Brothers and friends,
    i need urgently a economical and technical solution for reducing high pressure steam line into low pressure steam..
    Thank you very much, i appreciate very much
  3. Your question is very open ended, there could be many situations of that nature
    and the answer wouldnt be the same
    if you are obtaining high pressure steam from lateral extraction of a turbine (sp its
    designed in that way or is excess steam) it can be used for low steam pressure
    neeed passing the steam thru a series of regulation stations (typical bypass configs)
    the number of stages and amount of pressure drop in each depends on your plant needs
    and the level of noise allowed
  1. Replies: 9
    Last Post: 09-29-2015, 10:25 AM
  2. High pressure steam to reduce into low pressure steam system
    By achi81 in forum Planning & Project Management
    Last Post: 01-31-2011, 03:44 AM
  3. High pressure steam to reduce into low pressure steam system
    By achi81 in forum Pipeline And Fluid Flow
    Last Post: 04-27-2010, 05:02 PM
  4. High pressure steam to reduce into low pressure steam system
    By achi81 in forum General Engineering
    Last Post: 04-24-2010, 05:48 AM
