Results 1 to 6 of 6
Thread: Drillstem inspection
  1. Drillstem inspection
    Dear Sir;
    I would like to have some specification and procedure about drill stem inspection. Those documents are:-
    Standard DS-1, Drill Stem Design and Operation. TH Hill Associates Inc. NS-2,
    Drill String Inspection Standard, Fearnley Proctor Group
    A.P.I. Specification 5D - Specification for Drill Pipe: API Specification 7 –
    Specification for Rotary Drill Stem Elements:
    A.P.I. Recommended Practice 5A5 (API RP 5A5):
    A.P.I. Recommended Practice 7G (API RP 7G)ocument No. CSWIP-DS-16-06,
    Requirements for the Certification of Personnel Engaged in the Inspection of Drillstem
    Components (Rotary Tool & Drillpipe)
    Anybody in this field would like to share will be appreciated.
    Best Regards
    Prasong Singthom
  3. I would like to have some specification and procedure about drill stem inspection. Those documents are:-
  5. hi
    sir you can download a lot of api standard in below address
    jest change language by Google crome.
    [link Point to another website Only the registered members can access] search name of standard. register. then download in free
    Here is DS-1 V3. The other API docs are also available on this forum.
    go to f_i_l_esonic dot com/file/4037230234
    go to f_i_l_esonic dot com/file/4037230234/DS-1_STANDARD_V3_JD.pdf
    Hi Zrebwar,
    I tried to follow the link and i could not find the documents.
    I am not sure how to search the document.
    If you could give me another link or tell me how to download, that will be appreciated.
    Cheers
    Quote Originally Posted by zrebwar View Post
    hi
  1. Inspection Tool Box
    By Ramlee in forum Mechanical Engineering
    Last Post: 11-23-2015, 09:31 AM
  2. Api 571 -Pipeline inspection
    By johnty52 in forum Pipeline And Fluid Flow
    Last Post: 11-20-2013, 08:04 PM
  3. Ask : Civil Inspection and Test Plan / Field Inspection and Form
    By Cikni in forum Civil & Structural Engineering
    Last Post: 08-25-2013, 05:47 PM
  4. Qa/qc inspection for oil and gas
    By thencirky in forum Mechanical Engineering
    Last Post: 08-20-2013, 10:56 AM
  5. Tubing inspection
    By prasong in forum Drilling And Workover
    Last Post: 04-09-2010, 08:57 AM
