Hi Friends,
Will you please help me to design the reactive distillation column for any reaction.
Hi Friends,
This book can solve all of your problem regarding reactive distillation
Reactive Distillation Design and Control by WILLIAM L. LUYBEN and CHENG-CHING YU
title:Modelling and Simulation of ethyl
acetate reactive distillation column
using ASPEN PLUS
aspenplus models
1. Agrawal, Ankit Kumar (2012) Effect on naphtha yield, overall conversion and coke yield through different operating variables in FCC unit using Aspen-Hysys simulator. BTech thesis. file
2. Bose, Arunim (2012) Simulation of air liquefaction using aspen plus. BTech thesis. file
3. Panda, Chittaranjan (2012) Aspen plus simulation and experimental studies on biomass gasification. BTech thesis. file
4. Sourav, Sagar (2012) Production of hydrogen enriched SYN-gas by absorption method. BTech thesis. file
5. Dalai, Abhijit (2012) Nitrogen and helium liquefier design and simulation using aspen plus. BTech thesis. file
6. Kaushik, Vishal (2011) Dynamics and Control of Distillation using Aspen. BTech thesis. file
7. Sahoo, Prasanna Kumar (2011) Production of ethylbenzene by liquid-phase benzene alkylation. BTech thesis. file
8. Sahu, Mohit Mohan (2011) Simulation of process parameters and bed-hydrodynamic studies for fluidized bed biomass gasification using aspen plus. BTech thesis. file
9. Tewari, Krishna (2011) Design of Cumene Plant using Aspen Plus. BTech thesis. file
10. Mahapatra, N (2010) Design and Simulation of Cumene Plant using Aspen Plus. BTech thesis.
1. Bal, Kalinga Simant (2012) Performance appraisal of cryo‐treated tool by turning operation. MTech thesis. file
2. Sutradhar, Bidyut Bikash (2012) Evaluation of bond between bituminous pavement layers. MTech thesis. file
3. Shrivastava, Vinay (2012) Design and development of downdraft gasifier for operating CI engine on dual fuel mode. MTech thesis. file
4. Agrawal, Ankit Kumar (2012) Effect on naphtha yield, overall conversion and coke yield through different operating variables in FCC unit using Aspen-Hysys simulator. BTech thesis. file
5. Biswal, Bijayani (2012) Recovery of liquid fuels from cellulosic feedstock. BTech thesis. file
6. Sinha, Rahul (2012) Recovery of liquid fuels from oil bearing seed. BTech thesis. file
7. Mohanty, Maithili (2012) Performance based characterisation of bituminous binders. BTech thesis. file
8. Mohanty, Rashmi Prava (2012) Fabrication and Characterization of Metal Organic
Framework (MOF) Based Membrane. BTech thesis. file
9. Das, Sukalyan and Rout, Satyajit (2012) Assessment of Water Quality Around Mine Sites. BTech thesis. file
10. Nayak, Monalisha (2012) Design and simulation of a multiple-effect evaporator using vapor bleeding. BTech thesis. file
11. Sahoo, Rashmi Rekha (2012) Antioxidant &antimicrobial efficacy of Ficus religiosa L. & Ficus benghalensis L. PLANT. MSc thesis. file
12. Bose, Arunim (2012) Simulation of air liquefaction using aspen plus. BTech thesis. file
13. Mishra, Manisha (2012) Analysis of dioxygenase gene in marine bacteria involved in polycyclic aromatic hydrocarbon degradation. MSc thesis. file
14. Sourav, Sagar (2012) Production of hydrogen enriched SYN-gas by absorption method. BTech thesis. file
15. Biswal, Chitta Ranjan and Seth, Madhabi (2012) Effect of solvent in azo-hydrazone tautomerism of 1 phenylazo-2-naphthol (Sudan I). MSc thesis. file
16. Das, Kreeti (2012) Process Fault Analysis using Digraph Method. BTech thesis. file
17. Vikash, Kumar (2012) Synthesis of Dibenzyl Thioether using H2S and Anion Exchange Resin as Triphase Catalyst. BTech thesis. file
18. Nayan, Niraj Kumar (2011) Experimental studies on extraction of valuable fuels from karanja and neem seed by pyrolysis. BTech thesis. file
19. Sahoo, Biranchi Narayan (2011) Effect of Cryogenic Treatment of Cemented Carbide Inserts on Properties & Performance Evaluation in Machining of Stainless Steel. MTech thesis. file
21. Khare, P K (2011) Treatment of Phenolic Water Using Adsorption. MTech thesis. file
22. Jaiswal, Abhash (2011) Effect of hydrogen induction on co mbustion, performance and emission behaviour of compression ignition engine using used transformer oil as a main fuel. MTech thesis. file
23. Volli, Vikranth (2011) Recovery of bio-fuels from agricultural residues. MTech thesis. file
24. Damarla, Seshu Kumar (2011) Multivariate Statistical Process Monitoring and Control. MTech thesis. file
25. Saleh, Abdullah (2011) Study Of The Performance Of Batch Distillation Using gPROMS. BTech thesis. file
26. Agrawalla, Ankit (2011) Thermal Pyrolysis of Groundnut De-Oiled Cake and Characterization of Bio-Oil Produced. BTech thesis. file
27. Kaushik, Vishal (2011) Dynamics and Control of Distillation using Aspen. BTech thesis. file
28. Mohanty, Chiranjiv (2011) Experimental investigation of the combustion, performance and emission parameters of a compression ignition engine using blends of vegetable oil and diesel fuel. BTech thesis. Item availablity restricted. file
29. Rath, Saswat (2011) Performance & Emission Analysis of blends of Karanja Methyl Ester in a Compression Ignition Engine. BTech thesis. file
30. Sahoo, Prasanna Kumar (2011) Production of ethylbenzene by liquid-phase benzene alkylation. BTech thesis. file
31. Sahoo, Swati (2011) Study of Capillary Filling Dynamics in a Microtube. BTech thesis. file
32. Bantraj, Kandi (2011) Studies on adsorption isotherms and heats of adsorption of CH4 on microporous and mesoporous adsorbents. BTech thesis. file
33. Rath, Deepali (2011) Development of a gasifier for fueling of a diesel engine. BTech thesis. file
34. S, Dinesh (2011) Development and Characterization Of Pellet Activated Carbon from New Precursor. BTech thesis. file
35. Tewari, Krishna (2011) Design of Cumene Plant using Aspen Plus. BTech thesis. file
36. Chidambaram, Allada (2011) CFD Analysis of Phase Holdup Behaviour in a Three Phase Fluidized Bed. BTech thesis. file
37. Giri, Sindhushree (2011) Isolation and biochemical characterization of mercury resistant bacteria (MRB) from soil samples of industrially contaminated area of Rourkela, Orissa. MSc thesis. file
38. S R, Shubham (2011) Wastewater minimization using aspen water. BTech thesis. file
39. Samal, Amit (2011) Simultaneous Fermentation and separation using
Pervaporation Technique of Acetone-Butanol-Ethanol Fermentation: A Mathematical Approach. BTech thesis. file
40. Swain, Manisha (2011) Study of Capillary Filling Dynamics in a Microchannel. BTech thesis. file
20. Chandrakar, Gaurav (2011) Studies on Improvement of Surface Characteristics and Stability of Cr, Cu and Zn Based Metal Organic Frameworks (MOFs). MTech thesis. file
41. Rangarajan, Raghuraman (2011) Design and Simulation of a Multiple Effect Evaporator System. BTech thesis. file
42. Alam, Rukhsar (2011) Studies on the properties of Karanja oil for probable industrial application. MSc thesis. file
43. Mohapatra, Swapna Sarita (2011) Iron/Copper Co-Catalyzed C-C Cross-Coupling Reaction. MSc thesis. file
44. Sahu, Ramesh Chandra (2011) Neutralization of Red Mud Using CO2 Sequestration and their Utilizations. PhD thesis. Item availablity restricted. file
45. Kaushikaram, K S (2010) Partial Least Squares and Neural Network Based Identification of Process Dynamics & Design of Neural Controllers. BTech thesis. file
46. Behera, Managobinda (2010) Vapour Liquid Equillibrium Modeling Using UNIFAC Group Contribution Method And Its Application In Distillation Column Design And Steady State Simulation. BTech thesis. file
47. Kumar, S (2010) Modelling and Simulation of Ethyl Acetate Reactive Distillation Column using ASPEN PLUS. BTech thesis. file
48. Mondal, Abhishek (2010) Preparation of CaO-SiO2-P2O5 glass by Sol-gel route. BTech thesis. file
49. Mahapatra, N (2010) Design and Simulation of Cumene Plant using Aspen Plus. BTech thesis. file
50. K, S Kumar (2010) Extraction of Essential Oil Using Steam Distillation. BTech thesis. file
51. Mehra, Vaibhav Kumar (2010) Salt effect on Vapourliquid equilibrium for the binary system methanol +ethyl acetate. BTech thesis. file
52. Padhi, Saroj Kumar (2010) Preparation and Characterization of Biodiesel from Non-Edible Oils. PhD thesis. file
53. Javaji, S K (2009) Study of Dynamic Behavior of Ethyl Acetate Reactive Distillation Column Using ASPEN PLUS. BTech thesis. file
54. Kumar, Chandranan (2009) Counter Current Flow Phenomenon & Pressure Drop Calculation in Annular Geometry. MTech thesis. file
