Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 34
Thread: Asme b31
    Asme b31
    1- B31.1-2007:
    [link Point to another website Only the registered members can access] 2- B31.2-1968:
    [link Point to another website Only the registered members can access] 3- B31.3-2008:
    [link Point to another website Only the registered members can access] 4- B31.4-2006:
    [link Point to another website Only the registered members can access] 5- B31.5-2006:
    [link Point to another website Only the registered members can access] 6- B31.8-2007:
    [link Point to another website Only the registered members can access] 7- B31.8S-2004:
    8- B31.9-2008:
    [link Point to another website Only the registered members can access] 9- B31.11-1991:
    [link Point to another website Only the registered members can access] 10- B31G-2009:
  3. Sir,
    the links u have posted not valid, could u post again.
    thanks in advance
    Dear Forum Members,
    Find link as below:
    1. ASME B31.1-2007:
    2. ASME B31.4-2006:
    3. ASME B31.5-2006:
    4. ASME B31.8-2007:
    5. ASME B31.8S-2004:
    6. ASME B31G-2009:
    Thanks you.
    Thank U very much for this information. Now I have a doubt: I've read the asme B31.8 and B31.2 in the inspection part; and I did'n find the neccesary application of radiography or criteria for acceptance of the tests??
  7. Thank U very much for this information. Now I have a doubt: I've read the asme B31.8 and B31.2 in the inspection part; and I did'n find the neccesary application of radiography or criteria for acceptance of the tests??
    Hi wendyx8, that all is only for "Standard of Pressure piping" when B31.2 is for "Fuel Gas Piping" and B31.8 is for "Gas Transmission & Distribution Piping System"
    If you wanna see the information that contains acceptance criteria for welding, you have to see in ASME IX or API 1104 or AWS D1.1
    thanks a million
    Muhammad Khurram
    thank u
    Muhammad Khurram
    I have the latest copy of ASME B31.4 -2009:
    Hi and good day,
    I have some problem here about assessment using ASME B31G Modified..If anybody can help me in using this manual (as attach by Faizol).
  13. Thank you very much for sharing updeted information.... thanks
  14. Thank you very much ..So kind of you.
  16. dear sir, what code for crude oil transportation in ASME b 31?
  1. Difference between ASME IX 2013 and ASME IX 2010 Add.2011
    By yakkidudu in forum Oil And Gas Production
    Last Post: 07-14-2026, 02:50 PM
  2. ASME PTB-3-2013 asme section viii div.2 ,example problem manual
    By lois in forum Mechanical Engineering
    Last Post: 02-25-2025, 01:20 PM
  3. Replies: 1
    Last Post: 07-29-2014, 10:26 PM
  4. Need Guide For Asme Stamp Holders ASME A15100
    By PINTAIUS in forum Mechanical Engineering
    Last Post: 10-07-2012, 10:09 PM
  5. ASME PTB-3-2010 asme section viii div.2 ,example problem manual
    By sharmilasu in forum Mechanical Engineering
    Last Post: 04-22-2012, 06:57 AM
