Results 1 to 7 of 7
Thread: molecular weight of a compound
    How do we calculate the molecular weight of a compound?
  3. Thank You
  5. to calculate mol.wt
    your question is vague !! i hope you mean to say a petroleum compound??????
    which donot have constant composition hence no exact mol.wt but has avg
    if u simply mean a mol.wt of a compound
    1) split compound into its elements
    2) multiply No.of each elements with its mol.wt
    3)addition of which gives you the molwt of compound
    EX: H2SO4
    it's really simple H2=2(NO.of H2 molecule)*1(mol.wt of H2)
    S = 1(NO.of S molecule)*32(mol.wt of S)
    O4= 1(NO.of O molecule)*16(mol.wt of S)
    = 98 which is mol.wt of H2SO4
    if you mean mixture here is procedure
    1) u will know the composition of given mixture/mixtures of compound
    2)which shall be sum upto 100 if given in % or 1 if given in fractions (wt or mol. if they sumup to 1/100 they information given is wrong)
    3) now just put it the formula below
    mol.wt (avg) = (mol.wt)1*x1+.......+(mol.wt)n*xn
    (mol.wt)n = mol.wt of component n
  6. Mw Of Hc
    I think th MWof Hydrocarbons is very important for simulation. But for HC heavier than Naphtha ( FBP > 170 C) we cannt use GC method
    Is there any method for measuring heavy HC(FBP>170 C) ?
  7. hi omidi 1351,
    well this is intellectually wise question.......
    as far as my knowledge is concerned ( s iam still an undergraduate student ).
    HC heavier than naptha (FBP > 170 C) most of the time they exists in mixture rather than pure components . for precise calculations no other method exists rather than sticking to experimental studies ( calculating exact composition of each component,column chromatography is widely used for this purpose) and exact mol.wt is determined as i gave in above comment . if u want a rudimentary simulation (if composition of heavier HC is very low ) olefin >C5 would be a pretty good guess (it's only thumb rule ) .
    i hope this work's out ?????????
    Thank You
  10. thank's
  1. Replies: 0
    Last Post: 01-07-2009, 02:36 PM
  2. Pseudocomponent Molecular Weight Correlations
    By panos in forum Petroleum Refining
    Last Post: 12-13-2008, 10:08 PM
  3. Crude oil molecular weight data
    By abduh137 in forum Pipeline And Fluid Flow
    Last Post: 10-26-2008, 09:58 AM
