Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
Thread: Gas Transmission & Distribution Piping Systems
    Thumbs up Gas Transmission & Distribution Piping Systems
    Foreword vii
    CommitteePersonnel ix
    Introduction xii
    SummaryofChanges xiv
    GeneralProvisionsandDefinitions
    801. General 1
    802. ScopeandIntent 1
    803. PipingSystemsDefinitions 2
    804. PipingSystemsComponentDefinitions 4
    805. Design,Fabrication,Operation,andTestingTerms 6
    807QualityAssurance 7
    Chapter I Materials and Equipment
    810. Material and Equipment 8
    811. Qualification of Materials and Equipment 8
    812. Materials for Use in Cold Climates 9
    813. Marking 9
    814. Material Specifications 9
    815. Equipment Specifications 9
    816. Transportation of Line Pipe 10
    817. Conditions for the Reuse of Pipe 10
    Chapter II Welding
    820. Welding 12
    821. General 12
    822. Preparation for Welding 12
    823. Qualification of Procedures and Welders 12
    824.Preheating 13
    825. Stress Relieving 13
    826. Inspection of Welds 14
    827. Repair or Removal of Defective Welds in Piping Intended to Operate at
    Hoop Stress Levels of 20% or More of the Specified Minimum Yield Strength 15
    Chapter III Piping System Components and Fabrication Details
    830. Piping System Components and Fabrication Details 16
    831. Piping System Components 16
    832. Expansion and Flexibility 22
    833. Design for Longitudinal Stress 23
    834. Supports and Anchorage for Exposed Piping 25
    835. Anchorage for Buried Piping 26
    Tables
    831.42 Reinforcement of Welded Branch Connections,Special Requirements 21
    832.2 Thermal Expansion of Carbon and Low Alloy Steel 22
    832.5 Modulus of Elasticity for Carbon and Low Alloy Steel 23
    Chapter IV Design,Installation,and Testing
    840. Design,Installation,and Testing 27
    841.Steel Pipe 29
    842.Other Materials 40
    843.Compressor Stations 46
    844. Pipe-Type and Bottle-Type Holders 49
    845. Control and Limiting of Gas Pressure 50
    846. Valves 58
    847. Vaults 58
    848.Customers’ Meters and Regulators 59
    849. Gas Service Lines 60
    Tables
    841.114A. Basic Design Factor, F 30
    841.114B. Design Factors for Steel Pipe Construction 31
    841.115A.Longitudinal Joint Factor, E 32
    841.116A. Temperature Derating Factor, T, for Steel Pipe 32
    841.322.(f)Test Requirements for Pipelines and Mains to Operate at Hoop Stresses of 30% or More of the Specified Minimum Yield Strength of the Pipe 39
    841.33.Maximum Hoop Stress Permissible During Test 39
    842.214. Standard Thickness Selection Table for Ductile Iron Pipe 41
    842.32(c). Wall Thickness and Standard Dimension Ratio for Thermoplastic Pipe 42
    842.33(c). Diameter and Wall Thickness for Reinforced Thermo setting Plastic Pipe 42
    842.396(c). Nominal Values for Coefficients of Thermal Expansion of Thermoplastic Pipe Materials 44
    Chapter V Operating and Maintenance Procedures 850 Operating and Maintenance Procedures Affecting the Safety of Gas Transmission and Distribution Facilities 64
    851. Pipeline Maintenance 66
    852. Distribution Piping Maintenance 71
    853. Miscellaneous Facilities Maintenance 74
    854. Location Class and Changes in Number of Buildings Intended for Human Occupancy 76
    855. Concentrations of People in Location Classes1 and 2 77
    856. Pipeline Service Conversions 78
    Table
    854.1(c). Location Class 77
    Chapter VI Corrosion Control
    860. Corrosion Control 79
    861. Scope 79
    862. External Corrosion Control 79
    863. Internal Corrosion Control 82
    864. Pipelines in Arctic Environments 84
    865. Pipelines in High-Temperature Service 85
    866. Stress Corrosion and Other Phenomena 85
    867. Records 86
    Chapter VII Miscellaneous
    870. Miscellaneous 87
    871. Odorization 87
    872. Liquefied Petroleum Gas (LPG) Systems 87
    873. Pipelines on Private Rights-of-Way of Electric Transmission Lines 88
    Chapter VIII Offshore Gas Transmission
    A800. Offshore Gas Transmission 89
    A801. General 89
    A802. Scope and Intent 89
    A803.Offshore Gas Transmission Definitions 89
    A811. Qualification of Materials and Equipment 90
    A814. Material Specifications 90
    A817.Conditions for the Reuse and Requalification of Pipe 90
    A820. Welding Offshore Pipelines 91
    A821. General 91
    A823. Qualification of Procedures and Welders 91
    A825. Stress Relieving 91
    A826. Welding and Inspection Tests 91
    A830. Piping System Components and Fabrication Details 92
    A831. Piping System Components 92
    A832. Expansion and Flexibility 92
    A834. Supports and Anchorage for Exposed Piping 92
    A835. Anchorage for Buried Piping 92
    A840. Design,Installation,and Testing 92
    A841. Design Considerations 92
    A842. Strength Considerations 93
    A843. Compressor Stations 96
    A844. On-Bottom Stability 97
    A846. Valves 98
    A847. Testing 98
    A850. Operating and Maintenance Procedures Affecting the Safety of Gas Transmission Facilities 99
    A851. Pipeline Maintenance 99
    A854. Location Class 100
    A860. Corrosion Control of Offshore Pipelines 100
    A861. Scope 100
    A862. External Corrosion Control 100
    A863. Internal Corrosion Control 102
    Table
    A842.22. Design Factors for Offshore Pipelines,Platform Piping,and Pipeline Risers 94
    Chapter IX Sour Gas Service
    B800. Sour Gas Service 103
    B801. General 103
    B802. Scope and Intent 103
    B803. Sour Gas Terms and Definitions 103
    B813. Marking 104
    B814. Material Specifications 104
    B820. Welding Sour Gas Pipelines 104
    B821. General 104
    B822. Preparation for Welding 104
    B823. Qualifications of Procedures and Welders 104
    B824. Preheating 104
    B825. Stress Relieving 104
    B826. Welding and Inspection Tests 105
    B830. Piping System Components and Fabrication Details 105
    B831. Piping System Components 105
    B840. Design,Installation,and Testing 105
    B841. Steel Pipe 105
    B842. Other Materials 106
    B843. Compressor Stations 106
    B844. Pipe-Type and Bottle-Type Holders 106
    B850. Additional Operating and Maintenance Considerations Affecting the Safety of Sour Gas Pipelines 106
    B851. Pipeline Maintenance 107
    B855. Concentrations of People in Location Classes 1 and 2 107
    B860. Corrosion Control of Sour Gas Pipelines 107
    B861. General 107
    B862. External Corrosion Control 107
    B863. Internal Corrosion Control 108
    B866. Stress Corrosion and Other Phenomena 108
    Appendices
    A. References 109
    B. Numbers and Subjects of Standards and Specifications That Appear in Appendix A 112
    C. Publications That Do Not Appear in the Code or Appendix A 113
    D. Specified Minimum Yield Strength for Steel Pipe Commonly Used in Piping Systems 115
    E. Flexibility and Stress Intensification Factors 117
    F. Extruded Headers and Welded Branch Connections 123
    G. Testing of Welders Limited to Work on Lines Operating at Hoop Stresses of Less Than 20% of the Specified Minimum Yield Strength 128
    H. Flattening Test for Pipe 129
    I. End Preparations for Butt welding 130
    J. Commonly Used Conversion Factors 137
    K. Criteria for Cathodic Protection 141
    L. Determination of Remaining Strength of Corroded Pipe 143
    M. Gas Leakage Control Criteria 144
    N. Recommended Practice for Hydrostatic Testing of Pipelines in Place 151
    O. Preparation of Technical Inquiries to the ASME Code for Pressure Piping, B31 153
    P. Nomenclature for Figures 154
    Q. Scope Diagrams 155
    R. Estimating Strain in Dents 158
    Index 160
    Muhammad Khurram
  3. great post post can download from that site
    i try it without register and after done that but
    didnt work
    i do hope someone advise me how to get it or post it
    in another server
    thank you
    very useful post
    thank you
    hai
    Your contribution in this forum is unforgetable
  9. Gas Transmission and Distribution Piping Systems 31.8 -2007
    ASME B31.8 – 2007 Gas Transmission and Distributing Systems (202 Pages & 1.971 MB):
    [link Point to another website Only the registered members can access] ASME B31.8S - 2004 Managing System Integrity of Gas Pipelines (70 Pages & 0.718 MB):
    Thank you so much for your links
    Thank you
  13. Thank's
  14. #11
  16. #12
    thanks a lot
    Muhammad Khurram
  1. ASME B31.8_Ed.2010_Gas Transmission and Distribution Piping Systems
    By acier58 in forum Mechanical Engineering
    Last Post: 01-31-2013, 12:11 PM
  2. Water Transmission and Distribution - AWWA Book
    By Abo Khaled in forum Mechanical Engineering
    Last Post: 08-16-2012, 09:02 AM
  3. IEE Proceedings Generation, Transmission & Distribution
    By Isoon in forum Electrical & Power Engineering
    Last Post: 09-06-2010, 05:20 AM
  4. Gptc guide for gas transmission and distribution piping systems
    By AYAZUDDIN in forum Pipeline And Fluid Flow
    Last Post: 07-15-2010, 07:59 PM
  5. B31.8-2003 - 2004 Gas Transmission and Distribution Piping Systems
    By bhartendu in forum Oil And Gas Production
    Last Post: 02-19-2009, 12:22 AM
