Hello, Is it possible to have a link to the installation file for MagiCAD 2026 for Revit 2025?
If someone answers yes, I will share it with them MagiCAD 2026 for Revit 2026.
MagiCAD 2026 is compatible with the new Autodesk Revit 2026, as well as with the previous two Revit versions 2025 and 2024.
Source:[link Point to another website Only the registered members can access]
Thank you for your reply jandonian
I understand about compatibility, but I need the installer to have the same interface and features as the 2026 version for Revit 2026 that I have.
In addition, the 2025 version creates a 2025_r2025 directory in Program Files instead of 2026_r2025.
hi jandonian
You are right about compatibility. I just modified the 2025 .addin files in Revit\Addins to redirect them to those of 2026 and everything works correctly with the same toolbars as the 2026.
