Thread: PVTsim Nova 7.0
  1. PVTsim Nova 7.0
    NEW DATA VISUALIZATION TOOL
    DATA VISUALIZATION
    Plot fluid properties and compositions vs depth.
    Make cross plots of fluid properties.
    Input Field Data (Depth, Pressure, Temperature, etc) without a composition, and include this data in the DVT plots. The Field Data is stored in the database.
    NEW SEPARATOR OPTIMIZATION OPTION
    SEPARATION APP
    Optimize the separator pressures and temperatures in the Separation App for maximum liquid production.
    NEW PVTSIM LEDAFLOW API
    New PVTsim LedaFlow API installed with PVTsim Nova. The PVTsim LedaFlow API can be used from LedaFlow for running Composition Tracking simulations, starting from LedaFlow version 2.10.
    EXPORT AND IMPORT OF LEDAFLOW COMPOSITION TRACKING FILES
    Generate files with the EoS model information required to run LedaFlow Composition Tracking simulations.
    Import LedaFlow Composition Tracking files.
    NEW MODULE FOR CARBON CAPTURE AND STORAGE (CCS) SIMULATIONS
    NEW EOS MODELS
    In addition to Cubic EoS models and GERG-2008, the CCS module also features the Span-Wagner model for pure CO2 and the Leachman model for pure H2.
    NEW VISCOSITY AND THERMAL CONDUCTIVITY MODELS
    In addition to the traditional CSP and LBC models, the CCS module has the Laesecke/Huber model for pure CO2, the Muzny/Assael model for pure H2, and the CSP model with CO2 as reference component for CO2 rich systems.
    NEW COMPONENTS
    NO, N2O, NH3, SO2 and SO3 available with new parameters estimated.
    BRINE SOLUBILITY SIMULATIONS
    New parameters have been estimated for accurate simulations of CO2 solubility in Brine.
    Saturate Brine with CO2 or Impure CO2.
    Generate Brine solubility tables for CO2 for given Pressure and Temperature intervals.
    T-XY AND P-XY DIAGRAMS FOR CO2 IMPURITY SIMULATIONS
    For common impurity components, simulate the impact on saturation pressures as a function of the impurity concentration.
    PH PHASE ENVELOPE
    Pressure ? Enthalpy (PH) phase envelopes can be simulated with isothermal lines.
    HYDRATES
    New parameters have been estimated for improved simulations of hydrate formation in CO2 rich fluids with low amounts of water.
    Hydrate PH and PT phase mapping options.
    CO2 DENSITY TUNING
    Optimize Peneloux volume shift parameters (constant or temperature dependent) to match densities in a pressure-temperature grid. Reference densities simulated with Span-Wagner.
    INTERFACES
    PH tables for OLGA
    Standard tab files for OLGA and LedaFlow
    Hysys and UniSim Design
    CCS VERIFICATION REPORT
    The CCS verification report shows a comprehensive comparison of simulation results vs. experimental data for CO2 with impurities, CO2 with water, CO2 with brine and solid CO2 freezing.
    OTHER FEATURES IN THE CCS MODULE
    The CCS module has a number of additional PVT simulation options: Fluid database, Fluid mixing, Flash (2, 3, multi-phase PT, PH, UV, HS, VT, P-beta, T-beta), Phase envelope, Saturate with water (plot a T-range for a given pressure), Saturate with Salt Water, Critical Point, Property Generator, Hydrates and Unit Operations.
    NEW PVTSIM EOS FORMAT
    PVTSIM JSON EOS EXPORT
    New JSON type format for holding characterized fluid information. The format is available in two versions: A Limited version with data required for PVTsim consistent EoS simulations, and a Complete version, which holds all information stored with a characterized fluid in PVTsim, including PVT data. This format is ideal for use in cloud environments.
    PVTSIM JSON EOS IMPORT
    New import function for PVTSIM JSON EOS files.
    NEW INTERFACES
    NEW INTERFACE MODULES
    ECLIPSE THERMAL
    HARMONY
    REVEAL
    NEW FLUID INCLUSION APP
    FLUID INCLUSION SIMULATOR
    Simulate hydrocarbon composition and pressure data for fluid inclusions.
    FLUID DATA
    IMPORT OF PRODML FILES
    PRODML files containing reservoir fluids with OBM compositions can be imported.
    Support import of PRODML 2.2 files.
    Improved version check during file import.
    IMPORT OF CALSEP EXCEL FILES
    Enhancements to Calsep Excel File templates.
    MULTIPLE FILE IMPORT SUPPORT
    PVTsim supports import of multiple files at the same time for PRODML, PVTsim JSON EoS, and Calsep Excel files.
    FLUID MANAGEMENT
    UPDATED EDITING OPTIONS IN FLUID EXPLORER
    Bulk Edit functionality enabling easy editing of the name and sampling data for a selection of fluids.
    Single menu for editing Common EoS models. Updates to the model will be applied to all fluids in the Common EoS model.
    UPDATED COPY OF PVT DATA
    When you copy PVT data from one fluid to another the Sampling Data will also be copied.
    FLUID HANDLING
    LUMP COMMON EOS MODELS
    It is now possible to lump existing Common EoS models.
    ASSIGN LUMPING TO IMPORTED EOS MODELS
    Imported EoS models do not have PVTsim?s lumping information, which is required to run the ?Add to EoS? functions. The new Assign Lumping to EoS function allows the lumping information to be stored on the fluid, thereby enabling the use of PVTsim?s ?Add to EoS? functions for the imported EoS model.
    OBM CLEANING ? USER CONTROLLED
    Users can now select a measured OBM composition in the OBM Cleaning ? User Controlled menu. The amount of OBM removed can be changed with the slider, and the plot of the resulting clean composition can immediately be viewed.
    When a measured OBM Composition is selected, users can press ?Find Optimum OBM amount?. This new function finds the amount of OBM to be removed to give the best trend line of the clean composition vs. carbon number.
    The allowed range for the estimated OBM composition increased to C9-CNplus-2.
    SIMULATIONS WITH OBM
    When a fluid is selected with OBM components, simulation menus now display the amount of OBM in the fluid.
    PVT SIMULATION & REGRESSION
    IMPROVED LOGIC FOR NEAR-CRITICAL FLUIDS
    For near-critical fluids with a measured Differential Liberation experiment, logic has improved so regression to the data can take place, even if the fluid becomes a gas condensate during the regression iterations.
    IMPROVED CSP MODEL TUNING
    Issue fixed, which in rare instances could yield unphysical behavior when tuning the CSP viscosity model.
    VISCOSITY SIMULATION
    Viscosity data can now be simulated as a Constant Mass Expansion experiment.
    RESERVOIR
    UPDATED DEPTH GRADIENT REGRESSION
    Tune to match a Gas-Oil Contact depth, and match compositions and Saturation Pressures vs. depth.
    NEW DEPTH GRADIENT ? COMPARE WITH DATA FUNCTION
    For a group of fluids, simulate the compositional variation vs. depth, and compare the simulated variation in fluid compositions, fluid properties and Gas-Oil Contact with the experimental data.
    DEPTH GRADIENT SIMULATION
    Explicit location of GOC found when the starting sample is a gas and there is no distinct GOC, just a critical transition at a pressure higher than the saturation pressure.
    FLOW ASSURANCE
    WATER SIMULATIONS
    Inner lines can be included in phase envelopes with water.
    The Saturation Point option now allows the fluid to contain water and calculates all hydrocarbon and aqueous saturation points.
    CTM FILE
    PVTsim CTM files now contains the viscosity model choice.
    DEPOWAX
    Issue fixed in plotting of output, which sometimes caused PVTsim Nova to shut down.
    PVTSIM APPS
    SEPARATION APP
    New Composition Split separators are available. Specify the separation by compositional K-factors or Oil Recovery Factors.
    COMPOSITION PREPARATION FOR AUTO EOS
    Evaluation of the Plus Fraction Weight Amount updated to follow the procedure in SPE-216783-MS. The Plus Fraction Weight Amount procedure is now only applied to lighter fluids with a GOR > 600 Sm3/Sm3.
    INSITU FLUID
    Updated to allow simulations on characterized fluids.
    FLASH & PROCESS
    MULTIPHASE FLASH W/ SOLIDS
    Enhanced numerical robustness.
    MODELS & MODEL PARAMETERS
    Improved CO2-H2, CO2-Ar and CO2-O2 kijs
    SURFACE TENSION
    Updated coefficients for surface tension between liquid hydrocarbon and aqueous phases.
    INTERFACES
    PROSPER EOS
    Format update with separator conditions.
    Up to 100 components allowed for Prosper EoS files.
    HYSYS
    Updated to support export of CSP and LBC viscosity model parameters.
    Updated Hysys file names for several defined components.
    UNISIM
    Updated to support T-dep kijs and LBC viscosity model parameters.
    ECLIPSE COMP AND GEM IMPORT
    Improved handling of component names.
    OLGA BATCH
    OPM
    Bg and VISC values corrected in PVTG and PVTGW tables.
    BLACK OIL TABLES FOR RESERVOIR SIMULATORS
    Improved logic for avoiding undersatured property lines crossing.
    Monotonicity correction updated to obtain expected viscosity trends for gas condensates (rare cases).
    Issue fixed that sometimes could result in unphysical extrapolated Rv values when correcting for negative compressibilities.
    OTHER UPDATES
    INSTALLATION
    Issue fixed, which sometimes caused PVTsim Nova to enter ?Repair mode? on startup.
    FASTER EXECUTION SPEED
    PVTsim is upgraded to use Microsoft Ready-to-Run technology, which significantly improves the startup and operation speed of the application.
    PLOTS
    Updated plotting tool compatible with .NET 6 from Microsoft.
  3. Re: PVTsim Nova 7.0
    Anyone know password?
  5. Re: PVTsim Nova 7.0
  1. PVTsim Nova 7.1
    By tdl522 in forum Reservoir
    Last Post: 10-04-2025, 06:29 PM
