Page 1 of 2 1 2 LastLast
Results 1 to 12 of 20
Thread: Mss-sp 55/2005
    Mss-sp 55/2005
    Hello everybody.
    I am needing the MSSP-SP 55/2005 - Quality Standard for Steel Castings for Valves, Flanges and Fittings and Other Piping Components - Visual Method for Evaluation of Surface Irregularities
    If someone has a copy I will appreciate your help (i have just book of 2001).
    Regards.
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Hi,
    Dear friends,
    I am looking for the MSS specifications
    SP-6-2007 Standard Finishes for Contact Faces of Pipe Flanges and Connecting-End Flanges of Valves and Fittings
    SP-9-2008 Spot Facing for Bronze, Iron and Steel Flanges
    SP-25-2008 Standard Marking System for Valves, Fittings, Flanges, and Unions
    SP-42-2009 Corrosion Resistant Gate, Globe, Angle and Check Valves with Flanged and Butt Weld Ends (Classes 150, 300 & 600)
    SP-43-2008 Wrought and Fabricated Butt-Welding Fittings for Low Pressure, Corrosion Resistant Applications (Note: a 2010 Errata Sheet has been issued and inserted into this standard)
    SP-44-2010 Steel Pipeline Flanges
    SP-45-2003 (R 2008) Bypass and Drain Connections
    SP-51-2007 Class 150LW Corrosion Resistant Cast Flanges and Flanged Fittings
    SP-53-1999 (R 2007) Quality Standard for Steel Castings and Forgings for Valves, Flanges and Fittings and Other Piping Components - Magnetic Particle Examination Method
    SP-54-1999 (R 2007) Quality Standard for Steel Castings and Forgings for Valves, Flanges, and Fittings and Other Piping Components - Radiographic Examination Method
    SP-55-2006 Quality Standard for Steel Castings for Valves, Flanges, Fittings, and Other Piping Components - Visual Method for Evaluation of Surface Irregularities
    SP-58-2009 Pipe Hangers and Supports - Materials, Design, Manufacture, Selection, Application, and Installation
    SP-60-2004 Connecting Flange Joint Between Tapping Sleeves and Tapping Valves
    SP-61-2009 Pressure Testing of Valves
    SP-65-2008 High Pressure Chemical Industry Flanges and Threaded Stubs for Use with Lens Gaskets
    SP-67-2002a Butterfly Valves
    SP-68-1997 (R 2004) High Pressure Butterfly Valves with Offset Design
    SP-69-2003 Pipe Hangers and Supports - Selection and Application (ANSI-approved American National Standard)
    SP-70-2006 Gray Iron Gate Valves Flanged and Threaded Ends
    SP-71-2005 Gray Iron Swing Check Valves, Flanged and Threaded Ends
    SP-72-2010 Ball Valves with Flanged or Butt-Welding Ends for General Service
    SP-75-2008 Specification for High-Test, Wrought, Butt Welding Fittings
    SP-77-1995 (R 2000) Guidelines for Pipe Support Contractual Relationships - Relationships and Responsibilities of the Pipe Hanger Contractor with the Purchaser's Engineer or the Pipe Fabricator and/or Erector
    SP-78-2005a Gray Iron Plug Valves Flanged and Threaded Ends
    SP-79-2009 Socket Welding Reducer Inserts
    SP-80-2008 Bronze Gate, Globe, Angle, and Check Valves
    SP-81-2006a Stainless Steel, Bonnetless, Flanged Knife Gate Valves
    SP-82-1992 Valve Pressure Testing Methods
    SP-83-2006 Class 3000 Steel Pipe Unions Socket Welding and Threaded
    SP-85-2002 Gray Iron Globe & Angle Valves Flanged and Threaded Ends
    SP-86-2009 Guidelines for Metric Data in Standards for Valves, Flanges, Fittings, and Actuators
    SP-88-2010 Diaphragm Valves
    SP-89-2003 Pipe Hangers and Supports -Fabrication and Installation Practices
    SP-90-2000 Guidelines on Terminology for Pipe Hangers and Supports
    SP-91-2009 Guidelines for Manual Operation of Valves
    SP-92-1999 MSS Valve User Guide
    SP-93-2008 Quality Standard for Steel Castings and Forgings for Valves, Flanges, Fittings, and Other Piping Components - Liquid Penetrant Examination Method
    SP-94-2008 Quality Standard for Ferritic and Martensitic Steel Castings for Valves, Flanges, Fittings, and Other Piping Components - Ultrasonic Examination Method
    SP-95-2006 Swage(d) Nipples and Bull Plugs
    SP-96-2001 (R 2005) Guidelines on Terminology for Valves and Fittings
    SP-97-2006 Integrally Reinforced Forged Branch Outlet Fittings - Socket Welding, Threaded, and Buttwelding Ends
    SP-98-2001 (R 2005) Protective Coatings for the Interior of Valves, Hydrants, and Fittings
    SP-99-1994 (R 2005) Instrument Valves
    SP-100-2009 Qualification Requirements for Elastomer Diaphragms for Nuclear Service Diaphragm Type Valves
    SP-101-1989 (R 2001) Part-Turn Valve Actuator Attachment - Flange and Driving Component Dimensions and Performance Characteristics
    SP-102-1989 (R 2001) Multi-Turn Valve Actuator Attachment - Flange and Driving Component Dimensions and Performance Characteristics
    SP-104-2003 Wrought Copper Solder Joint Pressure Fittings
    SP-105-1996 (R 2005) Instrument Valves for Code Applications
    SP-106-2003 Cast Copper Alloy Flanges and Flanged Fittings Class 125, 150 and 300
    SP-108-2002 Resilient-Seated Cast-Iron Eccentric Plug Valves
    SP-109-1997 (R 2006) Welded Fabricated Copper Solder Joint Pressure Fittings
    SP-110-2010 Ball Valves Threaded, Socket-Welding, Solder Joint, Grooved and Flared Ends
    SP-111-2001 (R 2005) Gray-Iron and Ductile-Iron Tapping Sleeves
    SP-112-1999 (R 2004) Quality Standard for Evaluation of Cast Surface Finishes -Visual and Tactile Method. This SP must be used with a 10-surface, three dimensional Cast Surface Comparator, which is a necessary part of the Standard.
    SP-113-2001 (R 2007) Connecting Joint between Tapping Machines and Tapping Valves
    SP-114-2007 Corrosion Resistant Pipe Fittings Threaded and Socket Welding Class 150 and 1000
    SP-115-2006 Excess Flow Valves, 1 1/4 NPS and Smaller, for Natural Gas Service
    SP-116-2003 Service-Line Valves and Fittings for Drinking Water Systems
    SP-117-2006 Bellows Seals for Globe and Gate Valves
    SP-118-2007 Compact Steel Globe & Check Valves - Flanged, Flangeless, Threaded & Welding Ends (Chemical & Petroleum Refinery Service)
    SP-119-2003 Factory-Made Wrought Belled End Socket-Welding Fittings
    SP-120-2006 Flexible Graphite Packing System for Rising Stem Steel Valves - Design Requirements
    SP-121-2006 Qualification Testing Methods for Stem Packing for Rising Stem Steel Valves
    SP-122-2005 Plastic Industrial Ball Valves
    SP-123-1998 (R 2006) Non-Ferrous Threaded and Solder-Joint Unions for Use With Copper Water Tube
    SP-124-2001 Fabricated Tapping Sleeves
    SP-125-2010 Gray Iron and Ductile Iron In-Line, Spring-Loaded, Center-Guided Check Valves
    SP-126-2007 Steel In-Line Spring-Assisted Center Guided Check Valves
    SP-127-2001 Bracing for Piping Systems Seismic-Wind-Dynamic Design, Selection, Application
    SP-128-2006 Ductile Iron Gate Valves
    SP-129-2003 (R 2007) Copper-Nickel Socket-Welding Fittings and Unions
    SP-130-2003 Bellows Seals for Instrument Valves
    SP-131-2004 Metallic Manually Operated Gas Distribution Valves
    SP-132-2010 Compression Packing Systems for Instrument Valves
    SP-133-2005 Excess Flow Valves for Low Pressure Fuel Gas Appliances
    SP-134-2006a Valves for Cryogenic Service Including Requirements for Body/Bonnet Extensions
    SP-135-2006 High Pressure Steel Knife Gate Valves
    SP-136-2007 Ductile Iron Swing Check Valves
    SP-137-2007 Quality Standard for Positive Material Identification of Metal Valves, Flanges, Fittings, and Other Piping Components
    SP-138-2009 Quality Standard Practice for Oxygen Cleaning of Valves & Fittings
    SP-139-2010 Copper Alloy Gate, Globe, Angle, and Check Valves for Low Pressure/Low Temperature Plumbing Applications
    I will be thankfull if any body can share me the above documents. Thanks in advance.
    Regards.
    I can share what I have,
    SP-25-1978 Standard Marking System for Valves, Fittings, Flanges, and Unions
    SP-25-1998 Standard Marking System for Valves, Fittings, Flanges, and Unions
    SP-42-1999 Corrosion Resistant Gate, Globe, Angle and Check Valves with Flanged and Butt Weld Ends (Classes 150, 300 & 600)
    SP-43-1999 (R2001) Wrought and Fabricated Butt-Welding Fittings for Low Pressure, Corrosion Resistant Applications (Note: a 2010 Errata Sheet has been issued and inserted into this standard)
    SP-44-1996 (R2001) Steel Pipeline Flanges
    SP-45-2003 Bypass and Drain Connections
    SP-51-2000 Class 150LW Corrosion Resistant Cast Flanges and Flanged Fittings
    SP-53-1985 (R1990) Quality Standard for Steel Castings and Forgings for Valves, Flanges and Fittings and Other Piping Components - Magnetic Particle Examination Method
    SP-54-1995 Quality Standard for Steel Castings and Forgings for Valves, Flanges, and Fittings and Other Piping Components - Radiographic Examination Method
    SP-54-1999 Quality Standard for Steel Castings and Forgings for Valves, Flanges, and Fittings and Other Piping Components - Radiographic Examination Method
    SP-55-2001 Quality Standard for Steel Castings for Valves, Flanges, Fittings, and Other Piping Components - Visual Method for Evaluation of Surface Irregularities
    SP-58-2002 Pipe Hangers and Supports - Materials, Design, Manufacture, Selection, Application, and Installation
    SP-61-1961 - Pressure Testing of Steel Valves 1985 & API Std 598 8th May 2004 - Valve Inspection and Testing
    SP-61-2003 Pressure Testing of Valves
    SP-68-1997 High Pressure Butterfly Valves with Offset Design
    SP-70-1998 Gray Iron Gate Valves Flanged and Threaded Ends
    SP-71-1984 Gray Iron Swing Check Valves, Flanged and Threaded Ends
    SP-72-1999 Ball Valves with Flanged or Butt-Welding Ends for General Service
    SP-73-1991 Reaffirmed 1996 - Brazing Joints for Copper and Copper Alloy Pressure Fittings
    SP-73-2003 - Brazing Joints for Copper and Copper Alloy Pressure Fittings
    SP-75-1998 Specification for High-Test, Wrought, Butt Welding Fittings
    SP-75-2004 Specification for High-Test, Wrought, Butt Welding Fittings
    SP-77-1995 Guidelines for Pipe Support Contractual Relationships - Relationships and Responsibilities of the Pipe Hanger Contractor with the Purchaser's Engineer or the Pipe Fabricator and/or Erector
    SP-78-1998 Gray Iron Plug Valves Flanged and Threaded Ends
    SP-79-1992 Socket Welding Reducer Inserts
    SP-79-2004 Socket Welding Reducer Inserts
    SP-80-1997 Bronze Gate, Globe, Angle, and Check Valves
    SP-81-2001 Stainless Steel, Bonnetless, Flanged Knife Gate Valves
    SP-83-1995 Class 3000 Steel Pipe Unions Socket Welding and Threaded
    SP-85-1994 Gray Iron Globe & Angle Valves Flanged and Threaded Ends
    SP-86-1997 Guidelines for Metric Data in Standards for Valves, Flanges, Fittings, and Actuators
    SP-87-1991 (R1996) - Factory-Made Butt-Welding Fittings for Class I Nuclear Piping Applications
    SP-88-1993 Diaphragm Valves
    SP-90-1986 (R1991) Guidelines on Terminology for Pipe Hangers and Supports
    SP-91-1992 (R1996) Guidelines for Manual Operation of Valves
    SP-92-1987 (R1992) MSS Valve User Guide
    SP-93-1987 (R1992) Quality Standard for Steel Castings and Forgings for Valves, Flanges, Fittings, and Other Piping Components - Liquid Penetrant Examination Method
    SP-93-1999 Quality Standard for Steel Castings and Forgings for Valves, Flanges, Fittings, and Other Piping Components - Liquid Penetrant Examination Method
    SP-94-1999 Quality Standard for Ferritic and Martensitic Steel Castings for Valves, Flanges, Fittings, and Other Piping Components - Ultrasonic Examination Method
    SP-96-1996 Guidelines on Terminology for Valves and Fittings
    SP-97-1995 Integrally Reinforced Forged Branch Outlet Fittings - Socket Welding, Threaded, and Buttwelding Ends
    SP-97-2001 Integrally Reinforced Forged Branch Outlet Fittings - Socket Welding, Threaded, and Buttwelding Ends
    SP-98-1996 Protective Coatings for the Interior of Valves, Hydrants, and Fittings
    SP-99-1994 Instrument Valves
    SP-100-1997 Qualification Requirements for Elastomer Diaphragms for Nuclear Service Diaphragm Type Valves
    SP-110-1996 Ball Valves Threaded, Socket-Welding, Solder Joint, Grooved and Flared Ends
    OK, if you have any newer or additions to the above. Please make it your responsibility to post it here. Lets all be sharers and not just takers.
    Thanks, Nabilia
    Thank you Nabilia
    Cheers
    Thank you very much
    Victor Lachica
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Dear Nabila,
    Thanks for the share, Sure I will share what have, Thansk again.
    Thank you very much Nabilia
    Hello Nabila,
    How can see the link? by replying the email?
    Quote Originally Posted by anton77 View Post
    Hello Nabila,
    It is at the top of the post...
    Hello Nabila,
  14. Thanks for your support Mr. Nabilia
    Quote Originally Posted by Nabilia View Post
    Thanks, Nabilia
  16. #12
    Thanks for your help Mr. Mabilia
  1. Need: En 12285-2: 2005
    By vfq3481 in forum Mechanical Engineering
    Last Post: 07-23-2015, 09:28 AM
  2. Iso 9712:2005
    By mgkirupa in forum Safety And Environment
    Last Post: 05-31-2013, 11:34 AM
  3. Can any one share C50.12-2005 and C50.13-2005?
    By moon619 in forum Electrical & Power Engineering
    Last Post: 03-27-2013, 07:37 PM
  4. bs en 1993 1-1:2005
    By szevenz in forum Civil & Structural Engineering
    Last Post: 08-13-2012, 12:58 PM
