Page 1 of 2 1 2 LastLast
Results 1 to 12 of 14
Thread: PVTi and E100 problem HELP !!!
    Dec 2007
    Novi Sad, Serbia
    i'm having huge a problem with PVT file for E100... E100 is giving me some errors and warnings due to NEGATIVE COMPRESSIBILITY.... can anyone help with this one?
    Thanx
    First check would be to look at the PVT Tables you have and make sure the curves are smooth (the data points you have make nice smooth lines). None smooth data can make E100 extrapolate badly and cause this problem. That is the first place to look.
    I looked on the NET but nothing obvious poped out. Here is a translation of a Chinese site that mentions this problem and OTHERS !!
    —Big Oil Executive
    Dec 2007
    Novi Sad, Serbia
    Thank you bro..
    The same thing is written in E100 manual but no use of it.. The .PVO file i use is an export from PVTi so i suppose it is smooth enough...i can do that manualy but i don't think it is a good solution...
    Thanks for your effort
    Next thing to look at is when the problem happens in the simulation and what changes in the run at that moment, as you might have a big pressure transient and this may cause e100 to try extrapolate PVT data where you have none in your PVT table.
    I would still inspect the curves from PVTi in OFFICE or PVTi. Were they from correlations ?
    —Big Oil Executive
    Dec 2007
    Novi Sad, Serbia
    i absolutly agree with you.. here is the situation... my PMAX is 700 bars but the PVT data go to the last highest pressure in the experiment table (PVTi)... i need it to go to 700 bars but i can't do that in PVT.. i really think that the problem lies in exporting .PVO from PVTi to PMAX.. but i can't do it, i don't know how.
    Forgot another thing you might try. Add more data points to make those curves better defined and smoother.
    —Big Oil Executive
    If you look in your DATA file in the section with you PVT data, you could manually adjust those tables. Not sure how complicated you model is but this manual adjustment could be done for instance in EXCEL. A lot of people do it this way
    Does you simulation when you run it ACTUALLY go to 700 bar?
    Is you simulation running OK and then after lets say 2 months you see this problem, or does it start from the very start?
    —Big Oil Executive
    Dec 2007
    Novi Sad, Serbia
    Hahahahah... first i wanted the PVT file to be done in PVTi becasue i have the lab data but now i will use the best fitting correlation and make it .... stupid PVTi...
    But the main question remains ... how can i make PVTi extrapolate to a value i want?
    that problem is killing me....!!!!!!!
    Ivan I am not a Pvti expert, but there must be in the package an option that tells it to output or generate tables over a given range of pressure.
    Search on keyword "range" in the PVTi manual.
    When choosing the values of the max/min temperature and pressure consider the following:
    a The default values of Pmax=1000psia, Pmin=50psia, Tmax=400F and Tmin=50F are considered to be reasonable variations of conditions within a reservoir.
    b Make sure you alter these values to suit your particular reservoir. Try to make the region that is defined by your values as small as possible. For example if you think that the maximum temperature in your reservoir is going to be 300F then do not leave the default value in the panel (400F).
    Read this on page 22
    Can Black Oil tables be extended above the liquid
    bubble point in PVTi? Yes. You should make sure that the DL/CVD .....
    —Big Oil Executive
    I had the same problem during simulation with petrel.
    it is just due to bad license or -----. try it with new version of licensed software
  14. #11
    Quote Originally Posted by ivan_aljeburi View Post
    Thanx
    I am familiar how to solve the problem. If it is still actual, just write me to alknyaz@yahoo.com
    I will send you excell spreadsheet to fix it.
  16. #12
    Thanx
    No reasons to share it with one person. I tink it is very common problem. So,
    Sometimes ECLIPSE will calculate negative total compressibility values even if the PVT tables are not extrapolated. This issue seems to occur due to either PVT tables created by PVT packages that do not have total compressibility checks as in PVTi, or user errors when tables are exported. Whatever the reason, it is possible to fix the total compressibility by slightly changing Bo values as shown in the attached tables. These small changes should improve simulation convergence.
    Gas and oil PVT properties are defined in the ECLIPSE deck using PVDG and PVTO
    (or PVCO). ECLIPSE then issues the following message:
    @--WARNING AT TIME 0.0 DAYS ( 1-JAN-1990):
    @ NEGATIVE COMPRESSIBILITY FOUND IN GAS
    @ PRESSURE TABLE 1 AND OIL PRESSURE
    @ TABLE 1 AT A SAMPLE PRESSURE VALUE
    @ 5911.25172 . ADJUST SATURATED FLUID
    @ PROPERTY VALUES AT THIS PRESSURE.
    @ NEGATIVE COMPRESSIBILITIES OCCUR
    @ FOR GAS SATURATIONS LESS THAN 0.01461
    Why does ECLIPSE issue this message? What does it mean? How do I fix it?
    Answer Details:
    To ensure the total volume of the oil-gas mixture reduces as the pressure
    increases, ECLIPSE checks that the total compressibility of the hydrocarbon
    system along the "saturated line" is positive.
    The total compressibility of the oil-gas mixture is defined as:
    Ct = Sg*Ct,g + So*Ct,o --- (1)
    where,
    Ct,g = [-dBg/dP + dRv/dP * (Bo-Rs*Bg) / (1-Rs*Rv)]/Bg --- (2)
    Ct,o = [-dBo/dP + dRs/dP * (Bg-Rv*Bo) / (1-Rs*Rv)]/Bo --- (3)
    For each PVT region, ECLIPSE selects a pressure range which spans the complete
    range of the pressure data in the corresponding oil and gas PVT tables. This
    pressure range is then subdivided into 30 equally spaced pressure nodes for the
    evaluation of the total hydrocarbon compressibility.
    At each pressure node, ECLIPSE checks two limiting total compressibilities:
    Ct = Ct,o at Sg = 0, So = 1 --- (4)
    Ct = Ct,g at Sg = 1, So = 0 --- (5)
    If either or both limiting values are found to be negative at a pressure node,
    ECLIPSE will issue a warning message indicating the offending pressure and the
    gas saturation range for which negative total compressibility occurs:
    If Ct < 0 --- (6)
    Then Sg < - Ct,o / (Ct,g - Ct,o) --- (7)
    The effect of a negative total compressibility is usually to cause the simulator
    to experience numerical difficulties (convergence failures and/or erratic
    changes in the solution).
    A complete table of total compressibility evaluation can be written to the .DBG
    file by activating switch 21 of the DEBUG keyword in the PROPS section.
    If the range of sample pressures extends above the maximum bubble point entered
    in the PVTO table or above the maximum dew point entered in the PVTG table, then
    ECLIPSE will be forced to extrapolate above the highest entered Rs or Rv. This
    extrapolation is linear in Rs, 1/Bo, 1/(Bo*Visco), Rv, 1/Bg, and 1/(Bg*Viscg).
    In this case, it is not unlikely that negative compressibilities could occur as
    a result of extrapolation.
    It is recommended that the highest bubble point node in the PVTO table is
    constructed so as to avoid extrapolations above the highest entered Rs in
    the table. Similarly, in a run with vaporized oil present, it is recommended
    that the highest dew point node in the PVTG table is constructed so as to avoid
    extrapolation above the maximum entered Rv during the simulation.
    Three examples of PVT tables are provided below for a model with dry gas (Rv=0)
    and live oil (Rs>0):
    __________________________________________________ _____________________________
    Example 1. PVDG and PVTO are defined with a single "undersaturated line".
    ECLIPSE extrapolates Bo and Rs from 4014.7 to 9014.7 psi along the
    saturated line. This may cause negative total compressibilities to be
    calculated.
    PVDG
    -- PG BG VISG
    14.7 177.506 0.0086
    264.7 11.218 0.0098
    514.7 5.943 0.0111
    1014.7 3.108 0.0135
    2014.7 1.614 0.0182
    2514.7 1.306 0.0205
    3014.7 1.098 0.0228
    4014.7 0.835 0.0272
    5014.7 0.675 0.0314
    6014.7 0.568 0.0355
    7014.7 0.490 0.0394
    8014.7 0.432 0.0432
    9014.7 0.386 0.0468
    PVTO
    -- RS (PBUB)O BO VISO
    0.0061 14.7 1.117 0.994 / -- saturated
    0.0944 264.7 1.160 0.953 / -- saturated
    0.1776 514.7 1.202 0.913 / -- saturated
    0.3384 1014.7 1.284 0.838 / -- saturated
    0.6492 2014.7 1.435 0.706 / -- saturated
    0.8014 2514.7 1.505 0.648 / -- saturated
    0.9520 3014.7 1.571 0.595 / -- saturated
    1.2497 4014.7 1.691 0.502 -- Psat
    5014.7 1.668 0.549
    6014.7 1.646 0.597
    7014.7 1.623 0.645
    8014.7 1.601 0.692
    9014.7 1.578 0.740 /
    Example 2. PVDG is the same as that in the Example 1 but PVTO has multiple
    "undersaturated lines". Since the saturated PVT data exists for
    the complete pressure range (14.7 to 9014.7 psi), ECLIPSE does not
    extrapolate Bo and Rs along the saturated line.
    PVTO
    5014.7 1.668 0.549
    6014.7 1.646 0.597
    7014.7 1.623 0.645
    8014.7 1.601 0.692
    1.5436 5014.7 1.796 0.423 -- saturated
    6014.7 1.772 0.463
    7014.7 1.748 0.503
    8014.7 1.724 0.543
    9014.7 1.700 0.583 /
    1.8346 6014.7 1.886 0.356 -- saturated
    7014.7 1.861 0.390
    8014.7 1.835 0.424
    9014.7 1.810 0.458 /
    2.1232 7014.7 1.960 0.300 -- saturated
    8014.7 1.934 0.329
    9014.7 1.908 0.357 /
    2.4097 8014.7 2.019 0.253 -- saturated
    9014.7 1.992 0.277 /
    2.6945 9014.7 2.063 0.213 -- saturated
    10014.7 2.035 0.234 /
    Example 3. PVDG is the same as that in the Example 1 but PVCO has the multiple
    compressibilities (CO) and viscosibities (CV) of the undersaturated
    oil. Since the saturated PVT data exists for the complete pressure
    range (14.7 to 9014.7 psi), ECLIPSE does not extrapolate Bo and Rs
    PVCO
    -- (PBUB)O RS BO VISO CO CV
    14.7 0.0061 1.117 0.994 1.334E-05 9.501E-05 -- saturated
    264.7 0.0944 1.160 0.953 1.334E-05 9.501E-05 -- saturated
    514.7 0.1776 1.202 0.913 1.334E-05 9.501E-05 -- saturated
    1014.7 0.3384 1.284 0.838 1.334E-05 9.501E-05 -- saturated
    2014.7 0.6492 1.435 0.706 1.334E-05 9.501E-05 -- saturated
    2514.7 0.8014 1.505 0.648 1.334E-05 9.501E-05 -- saturated
    3014.7 0.9520 1.571 0.595 1.334E-05 9.501E-05 -- saturated
    4014.7 1.2497 1.691 0.502 1.334E-05 9.501E-05 -- saturated
    5014.7 1.5436 1.796 0.423 1.334E-05 9.501E-05 -- saturated
    6014.7 1.8346 1.886 0.356 1.334E-05 9.501E-05 -- saturated
    7014.7 2.1232 1.960 0.300 1.334E-05 9.501E-05 -- saturated
    8014.7 2.4097 2.019 0.253 1.334E-05 9.501E-05 -- saturated
    9014.7 2.6945 2.063 0.213 1.334E-05 9.501E-05 -- saturated
    Attached excel sheet illustrates how a small change in specific Bo values can remove negative total compressibilities. Just turn on option 21 in DEBUG keyword to generate the check table. JUST RENAME the attached *.doc file in to *.xls
    Alex
  1. PVTi splitting and grouping
    By Sequestrator in forum Reservoir
    Last Post: 05-15-2013, 06:03 PM
  2. Regarding Eclipse PVTi
    By sajidaminshah in forum Reservoir
    Last Post: 05-25-2012, 10:41 PM
  3. Replies: 0
    Last Post: 10-29-2010, 06:30 PM
  4. PVTi components
    By besucher in forum Reservoir
    Last Post: 07-20-2010, 12:20 PM
