Thread: Required: Password for Aramco Standards
  1. Question Required: Password for Aramco Standards
    Hello friends,
    Anybody has password for Aramco Standards?
    Thanks in advance
    Re: Required: Password for Aramco Standards
    I need too...
    Cool Re: Required: Password for Aramco Standards
    I need too
  6. Re: Required: Password for Aramco Standards
    You need to be specific as to what the problem is.
    1. Are they pdf files or Word files? I would presume they are pdf files.
    2. Do they have Owner or User (sometimes called Open) passwords or both Owner and User (Open) passwords? The User (OPen) password is the problem one to deal with as you can not open the pdf file at all so as to view it in the first place.
    3. There is no need to install a software package to do it (there are many of them available). You can use an online webpage application for this. Try this one which has the software tool to do it very quickly. I have found it works well:
    It works no problem taking out the Owner password as that is the easier one to remove. I have found in some cases that it can remove Owner and User (Open) passwords simultaneously where you do not know any of them in about 1 minute. If you do know the User (Open) password, input it as well as that will speed up the process. Give it a go and provide feedback to others as to whether it does or does not work.
  1. Saudi Aramco Standards - SATIP (Saudi Aramco Test Inspection Plan)
    By pavlo in forum Instrumentation & Control
    Last Post: 04-30-2019, 11:06 AM
  2. Aramco Best Pratices Standards
    By ch3coohminh in forum Mechanical Engineering
    Last Post: 04-27-2018, 05:37 PM
  3. Saudi Aramco Engineering Standards
    By emanc in forum Oil And Gas Process
    Last Post: 11-07-2016, 04:39 AM
  4. Aramco engineering standards
    By danielo in forum Instrumentation & Control
    Last Post: 07-19-2014, 12:59 AM
  5. Saudi Aramco Standards - SATIP (Saudi Aramco Test Inspection Plan)
    By psrafih in forum Instrumentation & Control
    Last Post: 02-26-2014, 08:35 PM
