Page 1 of 2 1 2 LastLast
Results 1 to 12 of 19
Thread: Running Hysys under Win 7
  1. Smile Running Hysys under Win 7
    My new laptop runs Win 7 Home Premium Edition. Hysys 3.2 and 2004 (I'm running these because other more updated versions such as 2006 and V7 etc seem to come only as part of a big suite of programs) get to a 95% installation and then "crash-out". The only way I can run these is inside a virtual PC running Win XP. Anyone have a solution? Thanks
  3. Exclamation
    Wich system do you have ?
    32 bits or 64 ?
    I couldn´t install HYSYS under W7 x 64
  5. Smile
    I'm running under 64 bit system - perhaps that's the problem?
  6. Exclamation
    Quote Originally Posted by JavaJoe View Post
    Yeah, probably, i will try with 32 bits in a virtual machine using virtualbox
    OK
    I have another error. In W7, If i load an old dynamic file, all my set point for controllers were reset. By the way, if i create a new controller, Hysys didn't allowed me to enter any value. This's so strange.
    guys i am facing problem with windows 7.i need to install hyses 3.2 on it.but it does not work.
    plz help
  10. Help installing hysys in 64 bit os
    Please i need help with hysys 3.2, i'm trying it on w7 64 bit and it doesn't work for me, i woul really appreciate if you guys can tell me some ways to do it.
    Quote Originally Posted by eliasroberty View Post
    Why don't you change your computer's date before 31/12/2009. For example: today's 11/09/2010. you changer to .../../2009. It might affect.
  12. Para instalar Hysys V7.1 en Windows de 64 bits se tiene que instalar "Microsoft SQL Server Express Editions" con compatibilidad de 64 bits.
  13. Para Jose Aguilar:
    Pudiste instalar el Aspen Hysys V7.1 en WIn 7 64 Bits?
    porq y tb intente instalar otro SQL... el 2008, pero no puedo instalarlo, me podes decir q version de SQL Server Express Editions instalaste?
  14. Hello people I couldnt able to run HYSYS in my laptop. I got the following eeror while opening. Please help.. btw i'm using WIN 7 32 bit
    Error_while_checking_out_license_(AEA_HYSYS_Online ) SLM Configuration Information
    IgnoreLocal SLM Configuration Information
    SuppressBroadcasts SLM Configuration Information
  16. Regarding hysys in windows 7
    Hi
    I am also facing the same problem...did u find the solution of it?
    also....in windows virtual xp mode..it is possible to install hysys 3.2??
