Results 1 to 11 of 11
Thread: Archie equation coefficients
  1. Archie equation coefficients
    Hello guys, right now I am dealing with low-resistivity laminated reservoir (thin sand-shale sequences). We have large number of conventional logs (sonic, gamma ray, laterals, etc), but now we are planning to run NMR and FMI tools.
    To prove usage of these tools we want to run saturation calculation with different Archie equation coefficients.
    So can someone provide me numerical values of these coefficients for different low-resistivity reservoirs?
    I will ask one of my best freinds about it and feed you back ,just send me of ur detailed questions and i will let him answer it
    mostafa_monir2003@yahoo.com
  5. usually m, n, and a coefficients are used with standard values if there is no core data so
    you can try m=2, n=2 , a=1 if you have low porosity sands. or a=0.81 if you have high porosity sands (phi>15%).
    if u need any help just let me know.
  6. Yes, I know about standard values m = 2, n = 2 and a = 1. You see usage of these values gave us 100 % water saturation in interval of interest, but after it was perforated the well gave us 700 bbl/day of oil without any water. I know that in current situation we need to perform NMR and acquire porosity and saturation from it. I heard that one can use NMR water saturation values to match with Archie equation coefficients. So we want to drill a new well on the field to make NMR and other modern loggings and after that obtain Archie equation for our reservoir. Than we can perform re-interpretation of old well logs to reduce logging costs.
    Have someone do such things before and could someone obtain m, n, a values for similar case?
  7. please send me the logs and then i can help you.
    may be you have a low resistivity pay or something like this which you have to be very careful in extracting RW, so i could help if i see the logs.
  9. Hello Dear Friend, sorry for a delay it takes time to arrange this logs. If you still can help me, please provide me your e-mail and I’ll send you las files.
  10. hello,
    my mail is geology5500@yahoo.com
    Is the interval cored?
    What about measuring the electrical properties directly on cores?
  12. Allah yenawar ya petrophysicist
  13. Dear Kochichiro,
    If you have FRF (Formation Resistivity Factor), I can give you the exact value of the Archie parameters at each depth you have the FRF.
  14. Please can any one assist me with the following Data in the Gas pipeline:
    Static temperatures,Static pressures,Static densities,Static gas constants, From Emmanuel,Master Student,Nigeria.
  1. Article: Archie equation coefficients
    By kochichiro in forum Home Articles
    Last Post: 07-07-2010, 02:39 PM
