Results 1 to 5 of 5
Thread: Transmision line cable conductor library into the ETAP
  1. Post Transmision line cable conductor library into the ETAP
    How to include new transmision line cable conductor library into the ETAP?
    For examample, 1/0 XLPE aluminium, 35 kv.
    Re: Transmision line cable conductor library into the ETAP
    there is a library for power lines cables , use the southwire library
  5. Re: Transmision line cable conductor library into the ETAP
    I need that type of specific cable in that line of transmission, in cable library it appears, but when I look for it within the parameters of the line it has not been possible to find it.
    try something like the video but I get this error: This project does not have any OLV cable or cable library data, or there is no linked cable library data in current library.
    when you merge a lot of libraries to main library, it's become unestable. reload old library bak file and only load libraries that you need on your project.
    To create a new one, preferable log as a librarian user. and do.
    copy the library that you want and modify it as you need.
    use transmission line cable for overhead bare cable and for insulated cables use cable component.
  7. Re: Transmision line cable conductor library into the ETAP
    Thanks, himmelstern
    I'm going to review everything you say.
  1. Allowable Ampacity of Conductor installed in a Cable Tray
    By BabyBear in forum Electrical & Power Engineering
    Last Post: 08-14-2017, 11:38 PM
  2. ETAP 14.1 or 16* DISTANCE PROTECTION* IMPEDANCE DIAGRAM* LIBRARY
    By OTTORONALDSTER in forum Electrical & Power Engineering
    Last Post: 04-28-2017, 02:01 PM
  3. ETAP 12.6 relay Library for ABB RED670 and Alstom P546
    By lemo in forum Electrical & Power Engineering
    Last Post: 04-27-2017, 07:11 PM
  4. Library ETAP 16.0 or 16.1
    By edgareee in forum Electrical & Power Engineering
    Last Post: 04-08-2017, 05:03 PM
  5. WTG Library in ETAP 12.6
    By raz in forum Electrical & Power Engineering
    Last Post: 08-26-2016, 12:19 AM
