Table of Contents
Preface xv
About the Author xxxi
Chapter 1: Mole Balances 1
1.1 The Rate of Reaction, –rA 4
1.2 The General Mole Balance Equation 8
1.3 Batch Reactors (BRs) 10
1.4 Continuous-Flow Reactors 12
1.5 Industrial Reactors 23
Chapter 2: Conversiona and Reactor Sizing 33
2.1 Definition of Conversion 34
2.2 Batch Reactor Design Equations 34
2.3 Design Equations for Flow Reactors 37
2.4 Sizing Continuous-Flow Reactors 40
2.5 Reactors in Series 49
2.6 Some Further Definitions 60
Chapter 3: Rate Laws 71
3.1 Basic Definitions 72
3.2 The Rate Law 74
3.3 The Reaction Rate Constant 85
3.4 Molecular Simulations 95
3.5 Present Status of Our Approach to Reactor Sizing and Design 99
Chapter 4: Stoichiometry 111
4.1 Batch Systems 113
4.2 Flow Systems 119
4.3 Reversible Reactions and Equilibrium Conversion 132
Chapter 5: Isothermal Reactor Design: Conversion 147
5.1 Design Structure for Isothermal Reactors 148
5.2 Batch Reactors (BRs) 152
5.3 Continuous-Stirred Tank Reactors (CSTRs) 160
5.4 Tubular Reactors 170
5.5 Pressure Drop in Reactors 177
5.6 Synthesizing the Design of a Chemical Plant 199
Chapter 6: Isothermal Reactor Design: Moles and Molar Flow Rates 217
6.1 The Molar Flow Rate Balance Algorithm 218
6.2 Mole Balances on CSTRs, PFRs, PBRs, and Batch Reactors 218
6.3 Application of the PFR Molar Flow Rate Algorithm to a Microreactor 222
6.4 Membrane Reactors 227
6.5 Unsteady-State Operation of Stirred Reactors 236
6.6 Semibatch Reactors 237
Chapter 7: Collection and Analysis of Rate Data 255
7.1 The Algorithm for Data Analysis 256
7.2 Determining the Reaction Order for Each of Two Reactants Using the Method of Excess 258
7.3 Integral Method 259
7.4 Differential Method of Analysis 263
7.5 Nonlinear Regression 271
7.6 Reaction-Rate Data from Differential Reactors 276
7.7 Experimental Planning 283
Chapter 8: Multiple Reactions 293
8.1 Definitions 294
8.2 Algorithm for Multiple Reactions 297
8.3 Parallel Reactions 300
8.4 Reactions in Series 309
8.5 Complex Reactions 319
8.6 Membrane Reactors to Improve Selectivity in Multiple Reactions 327
8.7 Sorting It All Out 332
8.8 The Fun Part 332
Chapter 9: Reaction Mechanisms, Pathways, Bioreactions, and Bioreactors 349
9.1 Active Intermediates and Nonelementary Rate Laws 350
9.2 Enzymatic Reaction Fundamentals 359
9.3 Inhibition of Enzyme Reactions 372
9.4 Bioreactors and Biosynthesis 380
Chapter 10: Catalysis and Catalytic Reactors 419
10.1 Catalysts 419
10.2 Steps in a Catalytic Reaction 425
10.3 Synthesizing a Rate Law, Mechanism, and Rate-Limiting Step 441
10.4 Heterogeneous Data Analysis for Reactor Design 457
10.5 Reaction Engineering in Microelectronic Fabrication 467
10.6 Model Discrimination 472
10.7 Catalyst Deactivation 475
10.8 Reactors That Can Be Used to Help Offset Catalyst Decay 485
Chapter 11: Nonisothermal Reactor Design–The Steady-State Energy Balance and Adiabatic PFR Applications 515
11.1 Rationale 516
11.2 The Energy Balance 517
11.3 The User-Friendly Energy Balance Equations 525
11.4 Adiabatic Operation 531
11.5 Adiabatic Equilibrium Conversion 541
11.6 Reactor Staging with Interstage Cooling or Heating 546
11.7 Optimum Feed Temperature 550
Chapter 12: Steady-State Nonisothermal Reactor Design—Flow Reactors with Heat Exchange 565
12.1 Steady-State Tubular Reactor with Heat Exchange 566
12.2 Balance on the Heat-Transfer Fluid 569
12.3 Algorithm for PFR/PBR Design with Heat Effects 572
12.4 CSTR with Heat Effects 592
12.5 Multiple Steady States (MSS) 602
12.6 Nonisothermal Multiple Chemical Reactions 609
12.7 Radial and Axial Variations in a Tubular Reactor 624
12.8 Safety 632
Chapter 13: Unsteady-State Nonisothermal Reactor Design 661
13.1 The Unsteady-State Energy Balance 662
13.2 Energy Balance on Batch Reactors (BRs) 664
13.3 Batch and Semibatch Reactors with a Heat Exchanger 679
13.4 Nonisothermal Multiple Reactions 690
Appendix A: Numerical Techniques 715
A.1 Useful Integrals in Reactor Design 715
A.2 Equal-Area Graphical Differentiation 716
A.3 Solutions to Differential Equations 718
A.4 Numerical Evaluation of Integrals 719
A.5 Semilog Graphs 721
A.6 Software Packages 721
Appendix B: Ideal Gas Constant and Conversion Factors 723
Appendix C: Thermodynamic Relationships Involving the Equilibrium Constant 727
Appendix D: Software Packages 733
D.1 Polymath 733
D.2 Wolfram 735
D.3 MATLAB 735
D.4 Excel 736
D.5 COMSOL (
D.6 Aspen 737
D.7 Visual Encyclopedia of Equipment—Reactors Section 738
D.8 Reactor Lab 738
Appendix E: Rate-Law Data 739
Appendix F: Nomenclature 741
Appendix G: Open-Ended Problems 745
G.1 Design of Reaction Engineering Experiment 745
G.2 Effective Lubricant Design 745
G.3 Peach Bottom Nuclear Reactor 745
G.4 Underground Wet Oxidation 746
G.5 Hydrodesulfurization Reactor Design 746
G.6 Continuous Bioprocessing 746
G.7 Methanol Synthesis 746
G.8 Cajun Seafood Gumbo 746
G.9 Alcohol Metabolism 747
G.10 Methanol Poisoning 748
Appendix H: Use of Computational Chemistry Software Packages 749
H.1 Computational Chemical Engineering 749
Appendix I: How to Use the CRE Web Resources 751
I.1 CRE Web Resources Components 751
I.2 How the Web Can Help Your Learning Style 754
I.3 Navigation 755
Index 757
Web Chapters (available on companion Web site)
Chapter 14: Mass Transfer Limitations in Reacting Systems
Chapter 15: Diffusion and Reaction
Chapter 16: Residence Time Distributions of Chemical Reactors
Chapter 17: Predicting Conversion Directly from the Residence Time Distribution
Chapter 18: Models for Nonideal Reactors
