Thread: API RP 5C5 Procedures for Testing Casing and Tubing Connections
  1. API RP 5C5 Procedures for Testing Casing and Tubing Connections
    Hello Gentlemen
    Does anyone has a current vision of API RP 5C5?
    I need to check something very urgently and If some could upload this API RP I would be very very grateful.
    Thank you upfront and best regards.
  3. Re: API RP 5C5 Procedures for Testing Casing and Tubing Connections
    I have the Third Edition which its effective date is 2003.
    If it going to be useful, let me know and I'll upload it.
    Good luck!
  5. Re: API RP 5C5 Procedures for Testing Casing and Tubing Connections
    AmrElGaml,
    It would be useful definitely because ISO 13679 which is a base to this API RP is from 2002. I presume nothing important changed since 2003 in Pipe Testing thank you upfront
  6. Re: API RP 5C5 Procedures for Testing Casing and Tubing Connections
    Here you Go!
    By lukasek009 in forum Drilling And Workover
    Last Post: 10-02-2018, 09:22 PM
  2. API RP 5C5 Procedures for Testing Casing and Tubing Connections
    By lukasek009 in forum Materials Science &Corrosion
    Last Post: 08-09-2018, 11:48 AM
  3. API RP 5C5 Procedures for Testing Casing and Tubing Connections
    By lukasek009 in forum Oil And Gas Production
    Last Post: 08-09-2018, 11:47 AM
  4. REQUEST: DIN 52913 - Testing of Static Gaskets for Flange Connections
    By garimidisunilkumar in forum Mechanical Engineering
    Last Post: 10-24-2016, 08:59 AM
  5. Hovoy GRE tubing casing and tubing
    By franklinshih in forum Pipeline And Fluid Flow
    Last Post: 05-30-2011, 03:44 PM
