I need IEC 60364-4-44:2018.
Thank you for sharing.
You can receive this IEC from[link Point to another website Only the registered members can access]
Thanks a lot! Great post
Thanks a lot!
Hi.
I have one question around this standard if anyone knows. If you look figure 44.A1 there is Uf as fault voltage that appears in the low-voltage system between exposed conductiive parts and earth. Now is this earth meant as remote earth because if it is then its impossible to provide adequate mittigation. But it is also imposible for human to be exposed to this voltage. This should be tounch voltage because you cant get whole remote earth voltage if you touch conductive object during fault time.
Hi,
Thanks!
Do you have IEC 60364-5-55?
