Hye all.
Looking for some feedback on the following issues:
1. Those who are familiar with Etap will notice under the LF tab, we can choose the generator voltage mode as either swing, voltage, Mvar or PF. Having said that, say for example if we chose PF, where do we key in the required PF setpoint? If we choose Mvar, where do we key in the Mvar setpoint and so on. Or does it follow the Var or PF as per rated value that we key in under the nameplate?
2.For the governor which has load sharing( kW sharing), how does this been implemented in Etap?
3.Having said the above, how do we set No.1 in Easypower or SKM? Does it equivalent to PV and PQ bus selection?
Looking for good technical feedback on this.
