Results 1 to 6 of 6
Thread: Chemical Selection Guide V5
  1. Chemical Selection Guide V5
    The Green Chemistry Team is issuing the Chemical Selection Guide Version 5, which replaces all previous versions and it now contains 500 chemicals used in chemical development.
    The purpose of the guide is to provide an awareness of environmental impact when using the listed chemicals and to give a choice to facilitate in the selection of chemicals with minimum environmental impact. The guide classifies each chemical as Green, Yellow, or Red. The meaning of the classifications is as follows:
    Green: Environmentally acceptable
    Yellow: Conditionally acceptable. Discussion with Global Safety & Environment (GSE) is recommended.
    Red: Use caution. If possible consider alternative. Discussion with GSE is required.
    The guide is not meant to be a list of prohibited substances. Rather, it is a tool to assist in the selection of chemicals, while taking environmental factors into consideration. Note that whenever environmental information was not available and a classification could not be made based on scientific data, the default classification of Yellow was used. The Chemical Selection Guide is available in an Excel spreadsheet format. Like any spreadsheet, the information is searchable and sortable. A total of four tabs are included in the guide and the tabs contain the following information:
    1st Tab – Instruction – contains definition of each column in the Guide and instructions on how to use the guide.
    2nd Tab – Flowsheet – contains a systematic approach for Green Chemistry classification
    3rd Tab – Summary Guide – contains a condensed version of the Guideline (sorted by alphabetical order)
    4th Tab – Full Guide – contains the Guideline and back-up information (sorted by CAS number)
    The guide will be periodically reviewed, modified and/or added to maintain it ever-green.
    Sasikumar
    Attached Files Attached Files
    Sasikumar, thank you
    [link Point to another website Only the registered members can access] Green Chemistry and Processes
    Mukesh Doble & Anil Kumar Kruthiventi
    Thanks Sasirkumar
  7. Thank you.
    Useful databank
    great, sasi
    Muhammad Khurram
  1. Material selection for Hydrocarbon and chemical plants
    By rmrns in forum Mechanical Engineering
    Last Post: 11-26-2017, 06:07 PM
  2. Quick Selection Guide to Chemical Protective Clothing
    By Han Ah kwang in forum Safety And Environment
    Last Post: 06-25-2014, 10:56 PM
  3. Chemical and Process Equipment: Selection and Design
    By rodryr640 in forum Petroleum Refining
    Last Post: 04-21-2014, 10:29 PM
  4. gasket selection guide
    By mohammad sadegh in forum Materials Science &Corrosion
    Last Post: 10-28-2013, 08:36 AM
  5. Chemical process equipment - selection and design, 3rd
    By usyd12a in forum Oil And Gas Process
    Last Post: 05-19-2013, 07:02 AM
