Hy! I need to calculate a kettle reboiler using HTFS 2006 but when I enter the process data some errors occur: due to small pressure drop, the temperature for cold fluid (shell side) decrease instead of increase. Pls help!
Hy! the fluid is propane in both shell and tube but at different temperatures and pressure.(I need to subcool liquid propane in tubes by vaporizing liquid propane in the shell). The pressure drop in shell decrease the outlet temperature causing an error to HTFS.
Please advice me!
Thanks!
Thanks!
I have checked an excample with htri and htfs. the results were egual, but the shell diameter was different. I have a problem with the liquid particle in the gas-stream. can anybody help me? What is the rightly gas velocity and shell diameter.
