Page 9 of 29 FirstFirst ... 7 8 9 10 11 19 ... LastLast
Results 97 to 108 of 347
Thread: Eclipse step by step
  1. #97
    Jan 2009
    ALA, KZ
    Quote Originally Posted by Bang Gaol View Post
    Hei guys,
    I can't go to the download page. It comes to redirection at last.
    Is there any problem?
    What spesific you want to download?
    Hello guys
    How can help me with simulation of multilateral wells in Eclipse?
    Which command or keyword should I use?
    Anyone have the data file of such wells to do this simulation?
    Determination of initial saturation
    Dear friends,
    How I determine the initila saturation of the model (petrel model) from capillary pressure (Pc) -height function
  6. #100
    Jan 2009
    ALA, KZ
    Dipak,
    in petrel there is no dedicated workflow to make initial water saturation.
    This can be made base on your Sw log data
    just make cross plot on x axes is Sw log
    on y axes PC - culculate PC by following formula pc=Owc*0.098*(rw-ro)
    where owc - oil water column high
    rw - water density
    ro - oil reservoir density
  7. #101
    Dear Term,
    I don't want to use log Sw. I want to make saturation profile based on capillary pressure data. I want to make some relationship with Pc from where I can generate initial saturation of the model.
  9. #102
    Jan 2009
    ALA, KZ
    Dipak you need to use your Sw by log otherwise your initial Sw will not match log data
  10. #103
    Dear Term,
    This field is producing in last 30 years. If I use present log Sw data for populate initial saturation, it will give wrong result. In this case I can use Cap data for initial saturation, but how that thing I want to know.
    We are eagarly waiting for your special core analysis lecture- how we use rel perm for eclipse by excel.
  11. #104
    Jan 2009
    ALA, KZ
    Dipak, use only wild cat wells and othere wells which produce with no water for you analysis because only lab data can lead you to wrong results due to behavior of the rock ( water-wet oil-wet)
    The picture below shows the results you can get using my approach ( my because normally all uses j-functions)
    this is a filed with 500 wells with the production period of 22 years and i just finished reserve redeterminition . So as you can see there is more or less good match to log data.
  12. #105
    Dear Term
    Pl explain in details "wrong results due to behavior of the rock ( water-wet oil-wet)" - not understanding
    Dipak
  13. #106
    Jan 2009
    ALA, KZ
    For this filed for example the Cap lab data gave me the Sw results less that Sw by log more than 30%
    The rock is water-wet but there is no free water in the reservoir
    SO that is way you need to compare you minimum Sw by log and by Lab
  14. #107
    Dear friends,
    I have single relperm curve and sigle PC curve. How I make diffrent relperm and cap cuve as per SATNUM. How this relperm can be merge with capillary pressure. Please give deatails procedure.
  16. #108
    Oct 2009
    Lahore, Pakistan.
    CO2 PVT data
    hey guys! I need co2 PVT data for making the compositional model of co2 miscible flood. If anybofy can help me? Here is my e-mail: uetian28@hotmail.com
    thanx in advance
  1. Replies: 11
  2. Eclipse Step by Step?
    By Zuper in forum Reservoir
    Last Post: 04-05-2012, 12:56 AM
  3. Step by step to calculate control valve Cv thorugh Intools
    By hswang2 in forum Instrumentation & Control
    Last Post: 11-28-2010, 09:37 AM
