Hi, somebody can help me?, I need de next standards
API-2015A
API-2555
API-MPMS-2.2B
THNX
Calibration of Upright Cylindrical Tanks Using the Optical Reference Line Method
API MPMS 2.2B 1st Ed 2002.pdf 433.41 KB
Liquid Calibration of Tanks
API STD 2555 1st Ed 1987.pdf 653.43 KB
Requirements for Safe Entry and Cleaning of Petroleum Storage Tanks (ANSI/API Std 2015-2001)
API STD 2015 6th Ed 2001.pdf 4.47 MB
Please does anyone have API 510 Edition 2006
Can anyone please upload Hydraulic Institute Standards (HI) for pumps. Thanks in advance
in german and english.
VDI 2040 Part 1 year 1991 - Calculation Principles for the Measurement of Fluid Flow, Using Ofifices Plates, Nozzles a. Venturi Tubes - Deviations and Supplements to DIN 1952
VDI 2040 Part 2 year 1987 - Calculation Principles for the Measurement of Fluid Flow, Using Ofifices Plates, Nozzles a. Venturi Tubes - Equations and Formulae
VDI 2040 Part 3 year 1990 - Calculation Principles for the Measurement of Fluid Flow, Using Ofifices Plates, Nozzles a. Venturi Tubes - Examples of Calculations
VDI 2040 Part 5 year 1989 - Calculation Principles for the Measurement of Fluid Flow, Using Ofifices Plates, Nozzles a. Venturi Tubes - Uncertainties
VDI 2041 year 1991 - Measurement of Fluid Flow with Primary Devices - Orifice Plates and Nozzles for Special Applications
VDI 2200 year 2007 - Tight flange connections - Selection, calculation, design a. assembly of bolted flange connections
VDI 3842 year 2004 - Vibrations in piping systems
Best regards,
westad22
Westad22 ,
thanks for the VDI's
if you have something about SILO's or storage tanks ..please let me know
Danke
Hi
Please share
"OST 26-291-94 Welded Steel Vessels And Process Vessels. General specifications"
Praphulla
api 650 with 2009 addenda
