Thanks to all members who have contributed over here !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Great yeah
Great yeah
Dear
Achmad Nur Eddin and Guniawala
Can share the above documents please I need some of the above documents.
Thanks in advance.
Regards.
Thanks a lot. Good luck!!!
Dear Achmad Nur Eddin and Guniawala
All of the files are expired, can you send me a copy of the UL 1730 to 378637247@qq.com?
Thanks very much!
UL 1730-2007 Standard for Smoke Detector Monitors and Accessories.pdf
http://www.4shared.com/document/PYslKaDd/UL_1730-2007_Standard_for_Smok.html
Please share UL 1309.
Thanks..
Many thanks
very thanks!!!
Anyone has UL 7846:2009?
please~!
All the files of UL standards are expired can you please up load it again.
nayakya
UL 142 - 1998-for steel aboveground tank for flammable liquid.pdf 5.8 MB
UL 555-2006 Fire Dampers.pdf 672.56 KB
UL 521-2002 Heat Detectors for Fire Protective Signaling Systems.pdf 988.71 KB
UL 83-2008 Thermoplastic-Insulated Wires and Cables.pdf 1.76 MB
UL 1709-2007 Rapid Rise Fire Tests of Protection Materials for Structural Steell.pdf 1.25 MB
UL 1778 2005 Uninterruptible Power Systems.pdf 783.77 KB
UL 444-2008 Communication cable.pdf 835.49 KB
UL 467 - 2007 Grounding and Bonding Equipment.pdf 383.86 KB
UL 674 - 2003 Electric Motors and Generators for Use in Division 1 Hazardous (Classified) Locations. ... 748.5 KB
UL 698A - 2008 Industrial Control Panels Relating to Hazardous (Classified) Locations.pdf 362.67 KB
UL 844-2008 Luminaires for Use in Hazardous (Classified) Locations.pdf 887.51 KB
UL 877 - 1993 Circuit-Breaker Enclosures for Use in Hazardous Locations.pdf 3.4 MB
UL 886 - 1994 Outlet Boxes and Fittings for Use in Hazardous (Classified) Locations.pdf 273.75 KB
UL 894 - 2009 Switches For Use In Hazardous (Classified) Locations.pdf 326.95 KB
UL 913 - 2008 Intrinsically Safe Apparatus for Use in Class I, II, and III, Division 1 Locations.pdf 356.26 KB
UL 1424 - 2005 Cables for Power-Limited Fire-Alarm Circuits.pdf 469.66 KB
UL 96A-2007 Installation Requirements for Lightning Protection Systems.pdf 1.1 MB
UL 94-2006 Test of flammability of plasti materials.pdf 693.73 KB
UL 125-2007 Standard for Valves for Anhydrous Ammonia and LP-Gas (Other Than Safety Relief).pdf 588.93 KB
UL 132-2007 Standard for Safety Relief Valves for Anhydrous Ammonia and LP-Gas.pdf 486.76 KB
UL Standard 2.rar 10.03 MB
UL 2034-2007 Standard for Single and Multiple Station Carbon Monoxide Alarms.pdf 1.03 MB
UL 5A-2008 Nonmetallic Surface Raceways and Fittings.pdf 933.08 KB
UL 5B-2009 Strut-Type Channel Raceways and Fittings.pdf 634.5 KB
UL 6-2004 Electrical rigid metal conduit-steel.pdf 687.53 KB
UL 10B-2008 Standard for Fire Tests of Door Assemblies.pdf 549.8 KB
UL 10C-2009 Positive Pressure Fire Tests of Door Assemblies.pdf 671.55 KB
