Hi,
Yeah. You need ETAP with Real Time module. Then you need an electric network with IEDs (Intelligent Electronic Devices) as relays, PLC, motor starters and others. After that you should setup a data network for IEDs communications. Finally you can setup an Electrical SCADA and then, you could connect ETAP to monitor that electrical network. There's a lot of work to do setting up ETAP Real Time, but after that you got some Smart grids funcionalities as network auto-healing and load shedding (Intelligent Load Shedding), load forecasting, EMS (Energy Management Systems for generation and power supply control), PMS, etc.
Best regards
