Please upload EN ISO 24373:2009 Welding consumables - Solid wires and rods for fusion welding of copper and copper alloys - Classification
Thanks in advance.
Thanks in advance.
it's included in zipped file that's linked
like every standard from the CEN/TC 121 - Welding & Allied Processes, except missing ones, which are now 4:
EN ISO 3677:2016 Filler metal for soldering and brazing - Designation (ISO 3677:2016)
EN ISO 15618-1:2016 Qualification testing of welders for underwater welding - Part 1: Hyperbaric wet welding (ISO 15618-1:2016)
EN ISO 15614-7:2016 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 7: Overlay welding (ISO 15614-7:2016)
EN ISO 17638:2016 Non-destructive testing of welds - Magnetic particle testing (ISO 17638:2016)
Dear BornToSin,
Have you posted CEN Standards Collection 341,342,350/350? I can't find these posts.
Best regards
341
CEN/TC 386 - Photocatalysis
342
CEN/CLC/JWG AIMD - CEN/CENELEC Joint Working Group on Active Implantable Medical Devices
350 still not posted but it will be soon![]()
Thank you!
1 of the 4 missing:
or
update:
better quality of the following standards:
EN ISO 3580:2011 Welding consumables - Covered electrodes for manual metal arc welding of creep-resisting steels - Classification (ISO 3580:2010)
EN ISO 3690:2012 Welding and allied processes - Determination of hydrogen content in arc weld metal (ISO 3690:2012)
EN ISO 14171:2016 Welding consumables - Solid wire electrodes, tubular cored electrodes and electrode/flux combinations for submerged arc welding of non alloy and fine grain steels -- Classification (ISO 14171:2016)
EN ISO 14341:2011 Welding consumables - Wire electrodes and weld deposits for gas shielded metal arc welding of non alloy and fine grain steels - Classification (ISO 14341:2010)
EN ISO 14344:2010 Welding consumables - Procurement of filler materials and fluxes (ISO 14344:2010)
EN ISO 16834:2012 Welding consumables - Wire electrodes, wires, rods and deposits for gas shielded arc welding of high strength steels - Classification (ISO 16834:2012)
EN ISO 17777:2016 Welding consumables - Covered electrodes for manual metal arc welding of copper and copper alloys - Classification (ISO 17777:2016)
EN ISO 18275:2012 Welding consumables - Covered electrodes for manual metal arc welding of high-strength steels - Classification (ISO 18275:2011)
EN ISO 19288:2016 Welding consumables - Solid wire electrodes, solid wires and rods for fusion welding of magnesium and magnesium alloys - Classification
EN ISO 17683:2015 Ships and marine technology - Ceramic weld backing for marine use (ISO 17683:2014)
EN ISO 18279:2003 Brazing - Imperfections in brazed joints (ISO 18279:2003)
EN ISO 15012-4:2016 Health and safety in welding and allied processes - Equipment for capture and separation of welding fume - Part 4: General requirements (ISO 15012-4:2016)
EN ISO 17916:2016 Safety of thermal cutting machines (ISO 17916:2016)
EN ISO 22825:2012 Non-destructive testing of welds - Ultrasonic testing - Testing of welds in austenitic steels and nickel-based alloys (ISO 22825:2012)
EN ISO 10042:2005 Welding - Arc-welded joints in aluminium and its alloys - Quality levels for imperfections (ISO 10042:2005)
EN ISO 10042:2005/AC:2006 Welding - Arc-welded joints in aluminium and its alloys - Quality levels for imperfections (ISO 10042:2005)
EN ISO 12932:2013 Welding - Laser-arc hybrid welding of steels, nickel and nickel alloys - Quality levels for imperfections (ISO 12932:2013)
EN ISO 14744-1:2008 Welding - Acceptance inspection of electron beam welding machines - Part 1: Principles and acceptance conditions (ISO 14744-1:2008)
EN ISO 9692-3:2016 Welding and allied processes - Recommendations for joint preparation - Part 3: Metal inert gas welding and tungsten inert gas welding of aluminium and its alloys (ISO 9692-3:2016)
EN ISO 15609-6:2013 Specification and qualification of welding procedures for metallic materials - Welding procedure specification - Part 6: Laser-arc hybrid welding (ISO 15609-6:2013)
EN ISO 15614-6:2006 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 6: Arc and gas welding of copper and its alloys (ISO 15614-6:2006)
EN ISO 15614-12:2014 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 12: Spot, seam and projection welding (ISO 15614-12:2014)
EN ISO 15614-13:2012 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 13: Upset (resistance butt) and flash welding (ISO 15614-13:2012)
EN ISO 15614-14:2013 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 14: Laser-arc hybrid welding of steels, nickel and nickel alloys (ISO 15614-14:2013)
EN ISO 17658:2015 Welding - Imperfections in oxyfuel flame cuts, laser beam cuts and plasma cuts - Terminology (ISO 17658:2002)
EN ISO 17662:2016 Welding - Calibration, verification and validation of equipment used for welding, including ancillary activities (ISO 17662:2016)
CEN ISO/TR 17844:2004 Welding - Comparison of standardised methods for the avoidance of cold *****s (ISO/TR 17844:2004)
CEN ISO/TR 18166:2016 Numerical welding simulation - Execution and documentation
EN ISO 5178:2011 Destructive tests on welds in metallic materials - Longitudinal tensile test on weld metal in fusion welded joints (ISO 5178:2001)
EN ISO 9016:2012 Destructive tests on welds in metallic materials - Impact tests - Test specimen location, notch orientation and examination (ISO 9016:2012)
EN ISO 12996:2013 Mechanical joining - Destructive testing of joints - Specimen dimensions and test procedure for tensile shear testing of single joints (ISO 12996:2013)
EN ISO 17641-1:2004 Destructive tests on welds in metallic materials - Hot *****ing tests for weldments - Arc welding processes - Part 1: General (ISO 17641-1:2004)
CEN ISO/TR 17641-3:2005 Destructive tests on welds in metallic materials - Hot *****ing tests for weldments - Arc welding processes - Part 3: Externally loaded tests (ISO/TR 17641-3:2005)
EN ISO 5182:2016 Resistance welding - Materials for electrodes and ancillary equipment (ISO 5182:2016)
EN ISO 8430-1:2016 Resistance spot welding - Electrode holders - Part 1: Taper fixing 1:10 (ISO 8430-1:2016)
EN ISO 8430-2:2016 Resistance spot welding - Electrode holders - Part 2: Morse taper fixing (ISO 8430-2:2016)
EN ISO 8430-3:2016 Resistance spot welding - Electrode holders - Part 3: Parallel shank fixing for end thrust (ISO 8430-3:2016)
EN ISO 10447:2015 Resistance welding - Peel and chisel testing of resistance spot and projection welds (ISO 10447:2015)
EN ISO 14270:2016 Resistance welding - Destructive testing of welds - Specimen dimensions and procedure for mechanized peel testing resistance spot, seam and embossed projection welds (ISO 14270:2016)
EN ISO 14272:2016 Resistance welding - Destructive testing of welds - Specimen dimensions and procedure for cross tension testing of resistance spot and embossed projection welds (ISO 14272:2016)
EN ISO 14273:2016 Resistance welding - Destructive testing of welds - Specimen dimensions and procedure for tensile shear testing resistance spot and embossed projection welds (ISO 14273:2016)
EN ISO 14323:2015 Resistance spot welding and projection welds - Destructive testing of welds - Specimen dimensions and procedure for impact shear test and cross-tension testing (ISO 14323:2015)
EN ISO 14373:2015 Resistance welding - Procedure for spot welding of uncoated and coated low carbon steels (ISO 14373:2015)
EN ISO 14554-1:2013 Quality requirements for welding - Resistance welding of metallic materials - Part 1: Comprehensive quality requirements (ISO 14554-1:2013)
EN ISO 14554-2:2013 Quality requirements for welding - Resistance welding of metallic materials - Part 2: Elementary quality requirements (ISO 14554-2:2013)
EN ISO 18278-2:2016 Resistance welding - Weldability - Part 2: Evaluation procedures for weldability in spot welding (ISO 18278-2:2016)
the missing list is:
new link:
Thanks a lot, a nice extensive list.
update:
added missing standards:
and better quality of:
EN ISO 15614-8:2016 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 8: Welding of tubes to tube-plate joints (ISO 15614-8:2016)
sector complete
links for mentioned standards
or
Dear BornToSin*
I just downloaded but can't find ISO 10675-1:2013 and ISO 10675-2:2013*
Only ISO 10675-1:2008 and ISO 10675-2:2010 are in folder.
Could you update* please.
Thank you in advanvce.
Mo
EN ISO 10675-1:2013 = Non-destructive testing of welds - Acceptance levels for radiographic testing - Part 1: Steel* nickel* titanium and their alloys (ISO 10675-1:2008)
EN ISO 10675-2:2013 = Non-destructive testing of welds - Acceptance levels for radiographic testing - Part 2: Aluminium and its alloys (ISO 10675-2:2010)
which means that ISO published that standards in 2008 (part 1) and 2010 (part 2) as ISO 10675* and CEN accepted the standards in 2013 as EN ISO 10675-1:2013 and as EN ISO 10675-2:2013 without any modifications so it's the same stanards
