Page 5 of 11 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 49 to 60 of 121
Thread: Mss-sp valves and fittings
  1. #49
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Hi,
    Dear Forum members,
    Can you please provide me the links for the following documents
    183 - Guide for the Prevention of Bottom Leakage from Vertical, Cylindrical, Steel Storage Tanks.
    180 - Frangible Roof Joints for Fixed Roof Storage Tanks: Guide for Designers and Users
    159 - Users' Guide to the Inspection, Maintenance and Repair of Above ground Vertical Cylindrical Steel Storage Tanks
    154 - Guidance to Owners on Demolition of Vertical Cylindrical Steel Storage Tanks and Storage Spheres
    API MPMS 19.3A - Manual of petroleum measurement standards - chapter 19.3 evaporative loss measurement - part a: wind runnel test method for the measurement of deck-fitting loss factors for
    external floating-roof tanks
    API MPMS 19.3E - Manual of petroleum measurement standard - chapter 19.3: evaporative loss measurement - part e: weight loss test method for the measurement of deck-fitting loss factors for
    internal floating-roof tanks
    API MPMS 19.3F - Manual of petroleum measurement standards - chapter 19.3: evaporative loss measurement - part f: evaporative loss factor for storage tanks certification program
    Thanks in advance
    Can anybody please post MSS SP-54-1999 (R2007) ? Thanks in advance.
    Thank you very much.
    I look for SP-127, If somebody have please shared.
  6. #52
    Quote Originally Posted by ani_dat View Post
    MSS SP-54-1999 - Steel Castings - Radiographic Examination Method.pdf
    This would be the same as R2007
    gateaux_boy, I don't have SP-127
  7. #53
    npsrinivasarao, sorry I didn't see your request earlier.
    Here is API MPMS Chapter 19 Evaporative Loss Measurement
    API MPMS 19.3A, Evaporative Loss Measurement 6-1997 (R 3-2002) Part A-Wind Tunnel Test Method for the Measurement of Deck-Fitting Loss Factors for External Floating-Roof Tanks.pdf
    API MPMS 19.3B, Evaporative Loss Measurement 8-1997 (R 3-2002) Part B-Air Concentration Test Method- Rim-Seal Loss Factors for FIoating-Roof Tanks.pdf
    API MPMS 19.3C, Evaporative Loss Measurement 7-1998 (R 3-2002) Part C-Weight Loss Test Method for the Measurement of Rim-Seal Loss Factors for Internal Floating-Roof Tanks.pdf
    API MPMS 19.3D, Evaporative Loss Measurement 6-2001 (R 3-2002) Part D-Fugitive Emission Test Method for the Measurement of Deck-Seam Loss Factors for Internal Floating-Roof Tanks.pdf
    API MPMS 19.3E, Evaporative Loss Measurement 5-1997 (R 3-2002) Part E-Weight Loss Test Method for the Measurement of Deck-Fitting Loss Factors for Internal Floating-Roof Tanks.pdf
    API MPMS 19.3F, Evaporative Loss Measurement 3-1997 (R 3-2002) - Part F-Evaporative Loss Factor for Storage Tanks Certification Program.pdf
    API MPMS 19.3G, Evaporative Loss Measurement 3-1997 (R 3-2002) Part G-Certified Loss Factor Testing Laboratory Registration.pdf
    API MPMS 19.3H, Evaporative Loss Measurement 3-1998 (R 3-2002) Part H-Tank Seals and Fittings Certification-Administration.pdf
  9. Nabila thanq
  10. #55
    Thank Nabilia.
    Did somebody have MSS SP-127?
  11. Thankx for the great effort
  12. #57
    Dear Nabilia,
    Thanx a lot.
  13. dears, plz reupload or send to my mail id. kalaiselvan0707@gmail.com
  14. Quote Originally Posted by mskhadke View Post
    MSS SP 72, 73, 75, 77, 78 , 79, 80, 81, 82, 83, 85 , 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100.
  16. #60
    hello, i need SP-89 but all "ifile.it-links" are brokens...
    thx a lot
  1. Replies: 59
    Last Post: 12-15-2018, 11:37 AM
  2. Crane TP-410. "Flow of Fluids through valves, fittings, and pipes
    By nocion_2h in forum Pipeline And Fluid Flow
    Last Post: 05-20-2018, 09:32 PM
  3. Crane - Flow of Fluids Through Valves, Fittings, and Pipe
    Last Post: 05-20-2018, 09:23 PM
  4. Replies: 0
    Last Post: 05-18-2013, 06:36 PM
  5. Flow of Fluids Through Valves, Fittings, and Pipe
    By azheee in forum Pipeline And Fluid Flow
    Last Post: 04-19-2011, 05:04 AM
