Page 5 of 24 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Results 49 to 60 of 302
Thread: American Welding Society (AWS)
Hybrid View
Previous Post Previous Post   Next Post Next Post
    this folder on 4shared contains a lot of files related to welding hope this contains some useful info
  2. Unhappy
    baibur ----- please a password is required. thank you in advance and regards
  3.    Sponsored Links
  4. baibur, can you please share the password? Thanks in advance.
  5. Hello Achmad Nur Eddin. Would you help me please with AWS D1.5/D1.5M-2002 Bridge Welding Code?
  6. #5
    Quote Originally Posted by Rock&welding View Post
    AWS D1.5/D1.5M-2002 Bridge Welding Code (ANSI STANDARD)
    AWS D1.5D1.5M-2002 Bridge Welding Code.pdf 24.450 MB
  7.    Spons.
  8. #6
    As requested by Manahan Rudolf
    AWS B2.1-1-205-2007 Standard Welding Procedure Specification (SWPS) forShielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 1-1/2 inch Thick, E6010 (Vertical Uphill) Followed by E7018 (Vertical Uphill), As-Welded or PWHT Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
    AWS B2.1.1.205-2007 Standard WPS of SMW Carbon Steel 1-8 thru 1 1-2 in.Vertical Uphill & Vertical Uphill & PWHT.pdf 0.265 MB
    AWS B2.1-1-206-96 (R2007) Standard Welding Procedure Specification (SWPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 1-1/2 inch Thick, E6010 (Vertical Downhill) Followed by E7018 (Vertical Uphill), As-Welded or PWHT Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
    AWS B2.1.1.206-2007 Standard WPS of SMW Carbon Steel 1-8 thru 1 1-2 in.Vertical Uphill & Vertical Downhill & PWHT.pdf 0.267 MB
  9. #7
    Thanks, you wonderful!
  10. #8
    Dear Pak Ahmad,
    Thank you so much Pak Ahmad....matur nuwun Pak
  11. Dear brother!
    Please post the links for the following standard"
    "AWS C7.3 Process Specification for Electron Beam Welding"
    Thanks in advance
  12. #10
    Hi Achmad
    Below are the copies I would like to request from you.
    Do you have AWS A5.1?
    Thank you very much
    Victor
    AWS – REFERENCE BOOK
    1 AWS - Arc Welding Safety, Fumes-Gases 1979
    2 AWS - Arc Welding and Cutting Noise 1979
    3 AWS - Characterization of Arc Welding Fume 1983
    4 AWS - Design for Welding 2003
    5 AWS - Design handbook for calculating fillet weld sizes 1997
    6 AWS - Economics of Welding and Cutting 2003
    7 AWS - Evaluating Welded Joints, Test 2003
    8 AWS - Radiographic Inspection Acceptance 1995
    9 AWS - Residual Stress and Distortion 2003
    10 AWS - Underwater Welding, Offshore Platforms-Pipelines 1980
    11 AWS - Vessel & Piping inspection 1999
    12 AWS - Welding, Design and Planning Manual 1999
    13 AWS - Welding-Joining Processes, Monitor-Control 2003
  13. #11
    Quote Originally Posted by victorlachica View Post
    Hi Achmad
    Thank you very much
    Victor
    Here is the link
    AWS Various Books.rar 58.130 MB
    Consist of :
    1. AWS - FUMES AND GASES In the Welding Environment
    2 AWS - ARC WELDING AND CUTTING NOISE
    3. AWS - Characterization of Arc Welding Fume
    4. AWS - DESIGN FOR WELDING
    7 AWS - Test Method for Evaluating Welded Joints
    8. AWS - The Practical Reference Guide for Radiographic Inspection Acceptance
    9. AWS - Residual Stress and Distortion
    10. AWS - Underwater Welding for Offshore Platforms and Pipelines
    11 AWS - THE PRACTICAL REFERENCE GUIDE for Visual Inspection of Pressure Vessels and Pressure Piping WELDING INSPECTION MANAGEMENT
    12 AWS - Welding, Design and Planning Manual for Cost Effective Welding
    13 AWS - Monitoring and Control of Welding and Joining Processes
  14.    Spons.
  15. #12
    Thank you Mr. Achmad Nur Eddin .
  1. ASM Code /American Society for Metals
    By Mohamed in forum Materials Science &Corrosion
    Last Post: 05-31-2018, 04:51 PM
  2. AWS American Welding Society codes
    By nocion_2h in forum Mechanical Engineering
    Last Post: 09-16-2015, 04:17 PM
  3. American Welding Society ( AWS )
    By miejot in forum Mechanical Engineering
    Last Post: 07-31-2014, 10:36 PM
  4. ASME - American Society of Mechanical Engineers
    By Esam in forum Pipeline And Fluid Flow
    Last Post: 09-05-2011, 03:34 PM
  5. American Welding Society (AWS) Codes
    By pkmaharia22 in forum Mechanical Engineering
    Last Post: 03-19-2010, 03:11 AM
