download links:
download links:
oh.. its in spanish but thanks anyways...
The software fully works* instructions are in Spanish and Chinese* even I speak that language was a little difficult to understand steps.
Only the key is to copy the demo licence file and rename it. And it works
Instructions to install are on Spanish but software is multilingual
PROCEDIMIENTO DE INSTALACIÓN - INSTALLATION PROCEDURE
Instalar el software de manera normal - Install the software in the normal way
Ir a la carpeta donde se instaló el programa - Go to the folder where the program was installed
Realizar una copia del archivo - Make a copy of the file : NepDemoLicense.dll
Y cambiarle de nombre por - And change its name to : NepLicense.dll
Luego abrir el programa les aparecerá - Then open the program will appear:
AquÃ* deben seleccionar la primera opción: Iniciar NEPLAN en modo de licencia normal…
Here you must select the first option: Start NEPLAN in normal license mode ...
Luego Pegar donde dice código de activación - Then Paste where it says activation code: oJF8W3Nb9z@q@+/CipPf<do8*vp83kZDzJ3
Thanks to google translate ......
Instalar el software de manera normal - Install the software as regular installation to finish
Ir a la carpeta donde se instaló el programa - Go to the folder location where the program was installed
Y cambiarle de nombre por - And rename to : NepLicense.dll in the same location
Luego abrir el programa les aparecerá - Then open the software will appear:
AquÃ* deben seleccionar la primera opción: Click on start NEPLAN at regular licence mode at the first option
Luego Pegar donde dice código de activación - Then Paste activation code: oJF8W3Nb9z@q@+/CipPf<do8*vp83kZDzJ3 or others at serial txt
Thanks very much for sharing. Any one with NEPLAN cde file format for automating network import from GIS data into NEPLAN?
I found a bit difficult to use Neplan....
