Page 4 of 29 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 37 to 48 of 347
Thread: Eclipse step by step
  1. #37
    Jan 2009
    ALA, KZ
    Chapter_7
    This chapter will be dedicated for building schedule section in Eclipse Schedule and then in chapter _8 we will make it manually in eclipse
    Note that i personally do not use Schedule so if i will explain something not clear-ask
    Appendix 1 will describe how fast plan and add vertical wells in petrel for simulation purposes
    This chapter covers Input data which are
    2. Production data
    1. Event data
    3. Trajectory data
    4. Grid data(Egid)
    5. Property data (Init)
    Attachment data
    1. Eclipse model
    2. Excel file File with ev and volume data
    And Type of schedule files and Type of errors you may encounter during building section
    To do !!!!!!!!!!!!!!!!!!!!!!!!!
    1.Download Egpet_net_v2.xlsm and put it to data folder . Open file and press macro button. This file add link to schedule file in Schedule folder
    [link Point to another website Only the registered members can access] 2.Download schedule.xlsm and put it to schedule folder . Open file and press 2 macro buttons and sheets vol and ev . In the folder you will see 2 text files with vol and ev data
    3.Export from Gmodel well connection data and put it to schedule folder or download it from link below
    4.Run Sim model in NOSIM mode and generate INIT and EGRID files
    or download them from this folder
    Again i will explain shortly if you will have nay question ask me in thread
    Lets quick describe input data which was not covered yet
    1. Event data
    Event data shows to eclipse all events that happen in reservoir by particular well . The detail description of all events can be found on page 309 of manual sche_ug.pdf which can be found on following link
    but briefly they are
    All names are reserved so if you will use pirfaration instead of perforation Schedule will give you an error.
    For building section we will need two of most important ones
    1. perforation - means perforation))) or opens connection cell to wellbore
    2.plug - means shut or close cell in defined interval from connection to well
    For giving idea to Schedule what well and when open or close we need to give info on following
    1. Well name, Event type, Date of events, Interval of event, Diameter of wellbore, skin
    NOTE!!!!!!!!!!! That for perforation you need to give top and bottom of perforation interval, for plug data only top because all cells below will be shut so be careful with plug data.
    Detail event file description and format can be founded on schedule.xlsm file
    2.Production data
    For eclipse you need to give production of each well ( vol file).
    First you need to select time step you will use in your runs. By common practice for history matching period used monthly period for long terms forecast runs yearly, but again it is all depends on your task
    NOTE!!!!!!!!!!!!! that eclipse reports all phases (oil,water,gas) in m3 not tons so your observed production should be in m3
    In our example we will use Monthly report
    For Schedule you need to supply following
    1.Report period
    2. Well name
    3. Date
    4. Actual Oil production rate (m3/month)
    5. Actual Water production rate (m3/month)
    6. Actual Gas production rate (m3/month)
    7. If well injector injection rate (oil, water, gas)
    8.Uptime - fraction actual days well worked in period/calendar days
    NOTE!!!!!!!!!!!! History measurements of bottom hole pressure not covered in this chapter but will be in next chapters as it is keen data during history matching o process
    All this data is in Vol sheet of schedule.xlsm
    For getting two files Press Macro buttons in Sheets and two files will appear in directory of excel file
    The scenario of history section is following
    Production start on February 2008 then Field working till 1 of January 2010
    well_3 as it perforated almost in contact zone will be switch from producers to water injector
    NOTE!!!!!!!! In eclipse it is the rule that production by date means production till this date !!!!
    for example if you put 1 January 2009 and production 100 m3 it means that by 1 of January well produce 100 m3
    Files required for schedule section
    1. event.ev
    2. volumes.vol
    3.well connection file ( conection.trj)
    4.init file
    5.egrid file
    Now we ready to build schedule section.
    Start schedule form eclipse
    You will return to this window
    Menu window log message window
    On menu window Press File , Save as
    Choose file name and safe it in schedule directory - it is project file then you can direct access it.
    Then choose system you work with i use metric so do this
    Press Save
    On menu Press Import, Production History, Replace
    Choose created previously volume.vol file in schedule directory
    On menu press Import, Events, Replace
    Choose created previously event.ev file in schedule directory
    Save Project
    On menu press Grid, Single Porosity
    Choose EGRID file in DATA directory and press open
    On menu press Well Locations, Trajectory File
    Choose well connection file exported from petrel and press open
    Save project
    On menu press Properties
    Choose INIT file in DATA folder and press open
    Press Save .
    On this step we finish data import ( except bottom hole pressure which will be covered later)
    On menu press data, Item List
    This list will give all information you load to Project
    So lets make Schedule section
    For doing this you need 1 create Control Network
    On menu press data, Control network
    You will be return to
    So here it is Group structure of your wells
    The upper grope is Filed
    Select filed by pressing mouse on it
    And press this button
    Put new name in the box let say history_match
    Press Ok new grope will appear under Field
    Now select pressing CTRl button following wells
    And drag them under History_match
    Check Filed and press right mouse button
    Choose Show Events
    You will retern to event control list of all groups which are belong to Filed
    As we doing history section you need to choose control for Producing and injecting wells
    On left menu Choose WCONHIST
    On right you have option for now
    Leave everything as is only change Phase to ORAT and press Apply
    this is what simulator will be keen to produce first in our example all wells first will be forsed to produce declared oil rates and only then all other phases will be calculated base on phase relative permeability's
    On left meny Choose WCONINJE
    Choose rate here
    it is mean that simulator will increase injection pressure unless it will be able to inject declared volumes of liquid press Apply
    So we ready to export schedule section
    On menu press Export, Schedule section
    name it hm.sch and press save
    If you make everything correct then simulator will report 0 errors but in our case we have 164 errors lets see what is problem
    NOTE !!!!!!! The main errors are wells has flow but no grid connection it is mean either well perforates inactive cell or you production starts before you connect well to grid
    open hm.sch in text editor
    In our example Production started but well is not connected to the grid
    Let see where problem comes from
    As you can see my wells has flow but no grid connection so we need check Perforation intervals
    If you will carefuly look to item list you will notice that wells duplicates WELL_1 and Well_1 are the same but for schedule they are different,
    NOTE!!!!!!!!!!!! names of wells should be the same including Caps in vol ev and trj files
    In excel file write all wells name in production has capita letters from this
    to this
    and press Export_vol
    Re import vol data to schedule(replace)
    Remove all wells from grope History_match by selecting them and pressing this button
    Drag all Well_* to groupe
    Save project and press export -0 errors!!!!!!!!!
    So now you can Make schedule section !!!!!!!!!!!!!!!!!!
    Appendix 1
    Making project wells in Petrel
    Open test petrel project
    Press this
    In input folder check all wells and press this
    So now i want to place well in random order
    Go to Processes and double click on Make edit polygons
    on right meny press this and start to draw polygon
    like this one
    no go to input data you will find ny polygon1 right click on it and choose spreadsheet
    You will be return to polygon spreadsheets
    Copy them and prepare in excell following table
    then copy this and paste to txt file
    save it
    Then do this
    Choose this
    Choose file
    make this settings and press ok for all
    Now you get all you project well quick and fast - enjoy!!!!!!!!!!
    Link to full chapter with pictures
    Jan 2009
    ALA, KZ
    Run model and Prepare Rsm file we will refiew results tommorow
  5. temr, could u re-upload the file
    [link Point to another website Only the registered members can access] Its said: "The file link that you requested is not valid."
    BIG thanks
  6. #40
    Jan 2009
    ALA, KZ
    coyee please find below
    [link Point to another website Only the registered members can access] in this folder you will find all data enjoy!
  7. #41
    Jan 2009
    ALA, KZ
    I reorginoze folders so now all data located in folder
    [link Point to another website Only the registered members can access] In next chapters i will refer to this link
  9. #42
    Dear Temr
    First, thank you so much for your great contribution to learn us Eclipse step by step so nicely and meticulously .
    I go through your lessons but I have some questions
    1. How I make PVT file in eclipse with the help of excel or petroleum expert
    software?
    2. How I prepare SCAL file in excel for Eclipse?
    3. When I import grid file from Petrel to Eclipse, in that file ACTNUM file is already included. Why separate ACTNUM file is required? If so how I prepare this ACNUM file in Petrel?
    4. How EQIL and regions file prepare in Petrel?
    5. Please tell about preparation of SUMMERY file?
    6. How I prepare Schedule Section file without using Eclipse Schedule?
  10. #43
    Jan 2009
    ALA, KZ
    dipak_m
    please find my answers below
    1. PVT data is another big domain which requered additional knowledges. Normaly i take this data from fluid analysis grope , test it and use it in my model. If you want to go deeply to theory go on this link
    [link Point to another website Only the registered members can access] and keep in mind - if you want programm you using work you need to know theory
    2.Scal datasets is not preparing in excel - they are result of analysis of special core analysis , in excel you only prepare this data in Eclipse format.
    3. Good quastion. The first actnum in gridfile is actnum of grid , it is hard to expalin better to visulaze it in 3D , just remove actnum from grid section and you will see the differents. Second actnum is actnum of cells of active grid blocks i will prepare ditail example in following chapter
    4. eqlnum and regions prepare in petrel by means of property caulculator. You make active part of the grid and assign to it using filter in calculator any value. But take in mind that petrel default value for integer type is 0 and if you not overvrite it starting from 1 then eclipse will give you an error
    5.In summary section you list all mnemonics which should be written to RSM file after run in detail you can find it in eclipse reference manual
    in terms of preparing you just put all needed mnemonics
    6. That will come in following chapter
    Reagrds
    Temr
  11. Wink
    Dear Tamer,
    Thanx a lot 4 this gr8 job indeed, I liked it. But I have some concerns, we have PETREL RE, so why not to use it to prepare the data file?? Using ECLIPSE OFFICE or manual editing requires learning bunch of keywords which is time wasting, e.g. in order to create an aquifer manually, it may take more than 5 days, but using petrel I can do that within few minutes.
    Of course I realize that PETREL is still under development and many enhancements to be made remaining ahead. But it's the best option to prepare simulation data file.
    ASSIGNMENT OF PARAMETERS IS MUCH EASIER THAN THE PREPARATION OF THEM, you know that engineers spend more 75% of the time in editing and creating eclipse input data files, which distracts engineers from their core job which is the PREPARATION OF DATA THEMSELVES, NOT THE INPUT DATA, once these data are prepared, they can be easily assigned via PETREL RE instead of wasting time in eclipse data file preparation. ECLIPSE must used as THE CORE SIMULATION ENGINE WHICH RUNS THE SIMULATION DATA FILE PREPARED BY PETREL RE.
    PETREL RE is good indeed and it's designed for newcomers, but experienced old ECLIPSE users insist on using ECLIPSE OFFICE or manual data file preparation instead, I don't know why, maybe coz it’s hard for them to change to PETREL RE I guess.
    Thank You!
  12. #45
    Anyone has Petrel RE tutorial manual and data file for practice?
  13. #46
    Jan 2009
    ALA, KZ
    anastinger
    Good point but note in my chapters i am never refering to office becase i personally think that it is a waste of time.
    I use Excel, Petrel, and Eclipse (engine) , the reason i showing how to data organize and what should be in data is that this is amust information you need to know.
    For aqufer for example i use Excel becase i know how eclipse can understand include file and i know how petrel export property in i j k order so for me its takes less than 10 minutes to build aqufer with different faces and productivity of each connected cell but again to do this i need to know how eclipse and petrel treat data.
    Again i am not forsing you, you can use you petrel RE but my approch - you need to understand what data you use
    Only then you can play with parameters to reach results you want
    In next chapter i will show how to build schedule section in Excel and trust me it is more easy make it in excel than in schedule or petrel if you know all keywords
    reagrds
    Temr
  14. #47
    Dear Temr,
    I will be thankful to you if you provide the excel file to prepare SCAL data for Eclipse.
  16. hi everybody
    i need eclipse software. If anyone has it please share it to me.
    My email: zangari.luciano@gmail.com
  1. Replies: 11
  2. Eclipse Step by Step?
    By Zuper in forum Reservoir
    Last Post: 04-05-2012, 12:56 AM
  3. Step by step to calculate control valve Cv thorugh Intools
    By hswang2 in forum Instrumentation & Control
    Last Post: 11-28-2010, 09:37 AM
