can u please help me by giving installing steps...
I followed the steps as mentioned in this blog. but when opening etap 11 showing
Licence manager server: ....
ETAP key is not found or the licence manager is not ready
And then
ETAP failed to receive authorization from ETAP License Manger.
Please help.....
Hi,
Any body can share etap v12 link, I may can make --------.
Hello, i install Etap 11.1 the 20 of february of 2014, and today 20 of April, it say me that expiration activation code, i try with others code of the net
Z@8cUuS5w#nytVgCfvvccA%tDDu4jD6aNb?K
fGfbh3n6Mks8tB4YkGCv5D+J2CGeVBKKaYyE
U53ra2F9b#qZ9EFVATGfhEB7%ZEFiydBGxL&
no workings for uptade activation code, i shared my solution for somebody have the same situation. you should use the runasdate.exe program for run new the etap 11.1 in one day don't expire, in my situation is 18 of april of 2014 and create a shortcut.
also, would you change the date of windows, but is more effort.
same here
we need someone to make a key generator.... anyone???
same here
Another solution for the meantime is before to start ETAP 11, to change the date to before April 20th, for example April 01. After ETAP started, you can change the date to the correct date.
I did a test, and the program runs sucessfully after the date is changed to the correct one. So the date in the reports is OK. If ETAP is closed and started again, the procedure shall be repeated.
