Page 35 of 35 FirstFirst ... 25 33 34 35
Results 409 to 413 of 413
Thread: Etap 7.5.0
  1. Re: Etap 7.5.0
    My etap 7.5 failed to open memory mapped files for transient stability plot data ....
    How to fix that error ?
    Re: Etap 7.5.0
    etap 7.5 on win 8?
    somebody ???
    Dec 2009
    Riau, Indonesia
    Re: Etap 7.5.0
    etap 7.5 in Win-8 is just the same as install it on Win-7 or XP ...., but when in my case, I have experience because Win-8 is usually not otomatically install dotnetfx files ..., so ... comparing with installing etap in XP compare to win 8, the difference is only 2 ..., see this
    1. the software compatibility ..., ==> before install software, right click the installer, and set the compatibility to XP SP-3, then after finished install, set again the installed etap software compatibility to XP SP-3
    2. Dotnetfx-4, ==> make sure it is installed on your win-8
    So :
    - For XP => install as usual
    - For Win-7 => Install as for XP, then set the compatibility to XP SP-3
    - For Win-8 => install as for Win-7, plus make sure the dot net fx 4 is installed.
    and one more, ... etap 32bit version is unintentionally appeared to be "successfully" installed on 64 bit, but ... when we insert the activation code, it always give's error message.
    OK, hope this will help you all.
    Thanks brother
  6. #412
    Re: Etap 7.5.0
    Hi friends
    Hope everything goes well with you
    I have provided a huge collection of newest petroleum software like: Petrel 2013.3, Eclipse 2013.1, Geoframe 2012, Paradigm 2011.3, Olga 7.2, OSP4.0.3, Mepo 4.2, Techlog 2013.2, RoXar RMS 2013.1, Ecrin 4.2.07, CMG 2013.1, S/M/T K/ingdom 8.8, Rokdoc 6.0.0.107, Desicion Space Desktop r5000.8.1.1, Drillworks 5000.8.1.1, Openworks r5000.8.1, VIP-Nexus 5000.4.4.0, Skua Gocad 2011.3, IPM 8.0, PetroMod 2013.1, Interactive Petrophysics 4.1, Openflow 2012.2, Pipesim 2013.1, Que$tor 3013Q1, FractPro 2013, Vista 13, Jason 8.4, GeoGraphix Discovery 2013, and so many other things ...
    if anybody need Please contact me I will share with you. Also I need some applications hope you can kindly help me.
    My E-mail is: slbsoft33@gmail.com
    Cheers.
  7. Re: Etap 7.5.0
    1. Disable connection to internet
    2. Disable antivirus software on your computer
    3. Run Etap-7 installation
    4. select install + license manager, just follow the instruction.
    5. When finish installation, dont run the software.
    6. Open DRIVERS folder in downloaded file (\ETAPSETUP\LM32SETUP\LMSETUP\SYSTEM32\DRIVERS )
    7. copy all files in that folder to C:Windows\System32\Drivers
    8. Goto c:\Program Files\Operation Inc. Technology ETAP Licence Manager and open the file ETAPKEY.exe.
    A window will keep running. Let it be running.
    9. Now Go to ----- folder and run Etap7-----.exe . This is the software to bypass license.
    this file is under DOS file, so you will see DOS application run.
    10.After finish installing Etap7-----.exe, then Reboot your computer/laptop.
    11.Enable again your antivirus
    12.Run ETAp 7 application.
    13.Will show up window for license , click OK, then software will ask for activation serial
    Enter Activation serial :
    %RZRSSNwC%Qrn%hRvCpRCw8+CvfpBx4tzfMu <------recomended print button enabled
    or
    %RZRSSNAC%Qrn%hZrCxRf3uk+khVaZP?i4QT
  1. ETAP v11.0
    By surgeArrester in forum Electrical & Power Engineering
    Last Post: 08-28-2016, 01:28 PM
  2. Etap 7
    By Sarmad Imtiaz Awan in forum Electrical & Power Engineering
    Last Post: 09-07-2014, 01:35 PM
  3. Need etap --------
  4. Etap 7.1
    By Rudi Tua in forum Electrical & Power Engineering
    Last Post: 07-06-2011, 12:02 PM
  5. Etap 7.0
    By pdms.ir in forum Electrical & Power Engineering
    Last Post: 08-19-2010, 10:44 PM
