any chance for mediafire or 1fichier links?
figured it out...![]()
Dear BornToSin,
I am looking for AWS D1.8 2016 (Structural Welding Code Seismic Supplement) do you have? Thank you in advance
G1.2M/G1.2:1999 (R2010) Specification for Standardized Ultrasonic Welding Test Specimen for Thermoplastics
G1.6:2006 Specification for the Qualification of Plastics Welding Inspectors for Hot Gas, Hot Gas Extrusion, and Heated Tool Butt Thermoplastic Welds
G1.10M:2016 Guide for the Evaluation of Hot Gas, Hot Gas Extrusion, and Heated Tool Butt Thermoplastic Welds
GWF:1998 Guide for Setting Up a Welder Training
Please upload if you have the above.
Thanks in advance
Thank you very much. God bless you.
ok* a lot of updates thanx to Marty Thompson...
again* only unbolded are missing:
Aerospace
D17.1/D17.1M:2010-AMD 1 Specification for Fusion Welding for Aerospace Applications
D17.2/D17.2M:2013 Specification for Resistance Welding for Aerospace Applications
D17.3/D17.3M:2016 Specification for Friction Stir Welding of Aluminum Alloys for Aerospace Applications
Aluminium
A5.3/A5.3M:1999 (R2007) Specification for Aluminum and Aluminum-Alloy Electrodes for Shielded Metal Arc Welding
A5.10/A5.10M (ISO 18273 MOD):2012 Welding Consumables – Wire Electrodes* Wires and Rods for Welding of Aluminum and Aluminum-Alloys – Classification
B2.1-22-015:2011 Standard Welding Procedure Specification (Aluminum)
C3.7M/C3.7:2011 Specification for Aluminum Brazing
D1.2/D1.2M:2014 Structural Welding Code – Aluminum
D3.7:2004 Guide for Aluminum Hull Welding
D8.14M:2008 Specification for Automotive Weld Quality—Arc Welding of Aluminum
D10.7M/D10.7:2008 Guide for the Gas Shielded Arc Welding of Aluminum and Aluminum Alloy Pipe
PHB-8 The Everyday Pocket Handbook for Gas Metal Arc Welding (GMAW) of Aluminum
WQA:2010 Welding Aluminum–Questions and Answers
Automotive
D8.1M:2013 Specification for Automotive Weld Quality – Resistance Spot Welding of Steel
D8.8M:2014 Specification for Automotive Weld Quality – Arc Welding of Steel
D8.9M:2012 Recommended Practices for Test Methods for Evaluating the Resistance Spot Welding Behavior of Automotive Sheet Steel Materials
Brazing & Braze Welding
A5.8M/A5.8-AMD 1:2011 Specification for Filler Metals for Brazing and Braze Welding
A5.31M/A5.31:2012 Specification for Fluxes for Brazing and Braze Welding
B2.2/B2.2M:2010 Specification for Brazing Procedure and Performance Qualification
BRH:2007 Brazing Handbook
C3.2M/C3.2:2008 Standard Method for Evaluating the Strength of Brazed Joints
C3.3:2008 Recommended Practices for the Design* Manufacture* and Examination of Critical Brazed Components
C3.4M/C3.4:2016 Specification for Torch Brazing
C3.5M/C3.5:2016 Specification for Induction Brazing
C3.6M/C3.6:2016 Specification for Furnace Brazing
C3.8M/C3.8:2011 Specification for the Pulse-Echo Ultrasonic Examination of Brazed Joints
C3.9M/C3.9:2009 Specification for Resistance Brazing
D10.13/D10.13M:2001 Recommended Practices for the Brazing of Copper Tubing and Fittings for Medical Gas Systems
Bridges
AASHTO/AWS D1.5:2015 Bridge Welding Code
Carbon Steel
A5.1/A5.1M:2012 Specification for Carbon Steel Electrodes for Shielded Metal Arc Welding
A5.2/A5.2M:2007 Specification for Carbon and Low Alloy Steel Rods for Oxyfuel Gas Welding
A5.17/A5.17M:1997 (R2007) Specification for Carbon Steel Electrodes and Fluxes for Submerged Arc Welding
A5.18/A5.18M:2005 Specification for Carbon Steel Electrodes and Rods for Gas Shielded Arc Welding
A5.20/A5.20M:2005 (R2015) Specification for Carbon Steel Electrodes for Flux Cored Arc Welding
A5.25/A5.25M:1997 (R2009) Specification for Carbon and Low-Alloy Steel Electrodes and Fluxes for Electroslag Welding
A5.26/A5.26M:1997 (R2009) Specification for Carbon and Low-Alloy Steel Electrodes for Electrogas Welding
A5.36/A5.36M:2016 Specification for Carbon and Low-Alloy Steel Flux Cored Electrodes for Flux Cored Arc Welding and Metal Cored Electrodes for Metal Arc Welding
GTW:2005 Guide to Weldability: Carbon and Low-Alloy Steels
Cast Iron
A5.15:1990 (R2016) Specification for Welding Electrodes and Rods for Cast Iron
D11.2:1989 (R2006) Guide for Welding Iron Castings
Certification
CM:2000 Certification Manual for Welding Inspectors
CMWS:2005 Certified Welding Supervisor Manual
QC1:2007 Standard for AWS Certification of Welding Inspectors
QC4:1989 Standard for Accreditation of Test Facilities for AWS Certified Welder Program
QC5:1991 Standard for AWS Certification of Welding Educators
QC7:1993 Standard for AWS Certified Welders
QC7C:1993 Supplement C*Welder Performance Qualification Sheet Metal Test Requirements
QC7F:1993 Supplement F* Chemical Plant and Petroleum Refinery Piping
QC7G:1993 Supplement G* AWS Performance Qualification Test
QC10:2008 Specification for Qualification and Registration of Level I — Entry Welders
QC11:1996 Specification for Qualification and Certification for Level II — Advanced Welders
QC12:1996 Specification for Qualification and Certification for Level III — Expert Welders
QC13:2006 Specification for the Certification of Welding Supervisors
QC14:2009 Specification for the Certification of Welding Sales Representatives
QC15:2008 Specification for the Certification of Radiographic Interpreters
QC17:2015 Specification for AWS Accreditation of Certified Welding Fabricators
QC19:2002 Standard for the AWS Certification of Robotic Arc Welding Personnel
QC20:2011 Standard for the AWS Certification of Resistance Welding Technicians
QC47:2016 Specification for AWS Certification of Welders and Accreditation of Test Facilities
Charts
A2.1 WC:2012 Welding Symbol Charts
A2.1 DC:2012 Welding Symbol Charts
A3.1:2010 Master Chart of Welding and Joining Processes
D1.1-SWJ-WC Welded Joint Details Wall Chart
D18.2:2009 Guide to Weld Discoloration Levels on Inside of Austenitic Stainless Steel Tube
F2.2:2001 (R2010) Lens Shade Selector
Computerization
A9.5:2013 Guide for Verification and Validation in Computation Weld Mechanics
Corrosion Resistance
C2.20/C2.20M:2002 Specification for Thermal Spraying Zinc Anodes on Steel Reinforced Concrete
C2.23M/C2.23:2003 Specification for the Application of Thermal Spray Coatings (Metallizing) of Aluminum* Zinc* and Their Alloys and Composites for the Corrosion Protection of Steel
PRGHF The Practical Reference Guide for Hardfacing
Cutting
A5.12M/A5.12 (ISO 6848 MOD):2009 Specification for Tungsten and Tungsten-Alloy Electrodes for Arc Welding and Cutting
C4.6M (ISO 9013 IDT) :2006 (R2012) Thermal Cutting—Classification of Thermal Cuts—Geometric Product Specification and Quality Tolerances
C5.3:2000 (R2011) Recommended Practices for Air Carbon Arc Gouging and Cutting
C5.10/C5.10M :2003 Recommended Practices for Shielding Gases for Welding and Cutting
C7.2:2010 Recommended Practices for Laser Beam Welding* Cutting* and Allied Processes
F4.1:2007 Safe Practices for the Preparation of Containers and Piping for Welding and Cutting
Design
DPW:1997 Design and Planning Manual for Cost-Effective Welding
FWSH:1997 Design Handbook for Calculating Fillet Weld Sizes
Education & Training
API-M:2008 Study Guide for API Standard 1104
CCRM:2015 Code Clinic–Structural Welding Code – Steel
EG2.0:2008 Guide for Training and Qualification of Welding Personnel: Entry Welder
EG3.0:2006 Guide for the Training and Qualification of Welding Personnel: Level II – Advanced Welders
GWF:1998 Guide for Setting Up a Welder Training Facility
WIT-T:2008 Welding Inspection Technology
WIT-W:2008 Welding Inspection Technology Workbook
Electrogas & Electroslag Welding
Reference Title
C5.7:2000 (R2006) Recommended Practices for Electrogas Welding
Electron Beam Welding
C7.1M/C7.1:2013 Recommended Practices for Electron Beam Welding and Allied Processes
C7.3:2016 Process Specification for Electron Beam Welding
Filler Metals & Fluxes
A4.2M (ISO 8429 MOD):2006 (R2014) Standard Procedures for Calibrating Magnetic Instruments to Measure the Delta Ferrite Content of Austenitic and Duplex Ferritic-Austenitic Stainless Steel Weld Metal
A4.3:1993 (R2006) Standard Methods for Determination of the Diffusible Hydrogen Content of Martensitic*Bainitic* and Ferritic Steel Weld Metal Produced by Arc Welding
A4.4M:2001 (R2006) Standard Procedures for Determination of Moisture Content of Welding Fluxes and Welding Electrode Flux Coverings
A4.5M/A4.5 (ISO 15792-3 MOD):2012 Standard Methods for Classification Testing of Positional Capacity and Root Penetration of Welding Consumables in a Fillet Weld
A5.01M/A5.01 (ISO 14344 MOD):2013 Welding Consumables–Procurement of Filler Metals and Fluxes
A5.02/A5.02M:2007 Specification for Filler Metal Standard Sizes* Packaging* and Physical Attributes
A5.4/A5.4M:2012 Specification for Stainless Steel Electrodes for Shielded Metal Arc Welding
A5.5/A5.5M:2014 Specification for Low-Alloy Steel Electrodes for Shielded Metal Arc Welding
A5.6/A5.6M:2008 Specification for Copper and Copper-Alloy Electrodes for Shielded Metal Arc Welding
A5.7/A5.7M:2007 Specification for Copper and Copper-Alloy Bare Welding Rods and Electrodes
A5.11/A5.11M:2010 Specification for Nickel and Nickel-Alloy Welding Electrodes for Shielded Metal Arc Welding
A5.13/A5.13M:2010 Specification for Surfacing Electrodes for Shielded Metal Arc Welding
A5.14/A5.14M:2011 Specification for Nickel and Nickel-Alloy Bare Welding Electrodes and Rods
A5.16/A5.16M (ISO 24034 MOD):2013 Specification for Titanium and Titanium-Alloy Welding Electrodes and Rods
A5.19:1992 (R2016) Specification for Magnesium Alloy Welding Electrodes and Rods
A5.21/A5.21M:2011 Specification for Bare Electrodes and Rods for Surfacing
A5.22/A5.22M:2012 Specification for Stainless Steel Flux Cored and Metal Cored Welding Electrodes and Rods
A5.23/A5.23M:2011 Specification for Low-Alloy Steel Electrodes and Fluxes for Submerged Arc Welding
A5.24/A5.24M:2014 Specification for Zirconium and Zirconium-Alloy Welding Electrodes and Rods
A5.28/A5.28M:2005 (R2015) Specification for Low-Alloy Steel Electrodes and Rods for Gas Shielded Metal Arc Welding
A5.29/A5.29M:2010 Specification for Low-Alloy Steel Electrodes for Flux Cored Arc Welding
A5.30/A5.30M:2007 Specification for Consumable Inserts
A5.34/A5.34M:2013 Specification for Nickel-Alloy Electrodes for Flux Cored Arc Welding
A5.35/A5.35M:2016 Specification for Covered Electrodes for Underwater Wet Shielded Metal Arc Welding
UGFM:2010 User’s Guide to Filler Metals
Food Processing Systems
D18.1:2009 Specification for Welding of Austenitic Stainless Steel Tube and Pipe Systems in Sanitary (Hygienic) Applications
D18.3/D18.3M:2015 Specification for Welding of Tanks* Vessels* and Other Equipment in Sanitary (Hygienic) Applications
Friction Welding
C6.1:1989 (R2009) Recommended Practices for Friction Welding
C6.2/C6.2M:2006 Specification for Friction Welding of Metals
GMAW
PHB-4 Everyday Pocket Handbook for Gas Metal Arc Welding (GMAW) and Flux Cored Arc Welding (FCAW)
PHB-8 Everyday Pocket Handbook for Gas Metal Arc Welding (GMAW) of Aluminum
GTAW
A5.22/A5.22M:2012 Specification for Stainless Steel Flux Cored and Metal Cored Welding Electrodes and Rods for Gas Tungsten Arc Welding
C5.5/C5.5M:2003 Recommended Practices for Gas Tungsten Arc Welding
D10.6/D10.6M:2000 Recommended Practices for Gas Tungsten Arc Welding of Titanium Piping and Tubing
Inspection
B1.10M/B1.10:2016 Guide for the Nondestructive Examination of Welds
B1.11:2015 Guide for the Visual Examination of Welds
B4.0/B4.0M:2016 Standard Methods for Mechanical Testing of Welds
G1.6:2006 Specification for the Qualification of Plastics Welding Inspectors for Hot Gas* Hot Gas Extrusion* and Heated Tool Butt Thermoplastic Welds
PHB-2 Everyday Pocket Handbook for Visual Inspection and Weld Discontinuities —Causes and Remedies
PHB-6 Everyday Pocket Handbook for Visual Inspection of AWS D1.1 Structural Welding Code’s Fabrication and Welding Requirements
WI:2015 Welding Inspection Handbook
Laser Beam Welding
C7.2M:2010 Recommended Practices for Laser Beam Welding* Cutting* and Allied Processes
C7.4/C7.4M:2008 Process Specification and Operator Qualification for Laser Beam Welding
Machinery & Equipment
C2.19/C2.19M:2013 Specification for the Application of Thermal Spray Coatings to Machine Elements for OEM & Repair
D14.1/D14.1M:2005 Specification for Welding of Industrial and Mill Cranes and Other Material Handling Equipment
D14.3/D14.3M:2010-AMD1 Specification for Welding Earthmoving* Construction* and Agricultural Equipment
D14.4/D14.4M:2012 Specification for Welded Joints in Machinery and Equipment
D14.5/D14.5M:2009 Specification for Welding of Presses and Press Components
D14.6/D14.6M:2012 Specification for Welding of Rotating Elements of Equipment
D14.7/D14.7M:2005 Recommended Practices for Surfacing and Reconditioning of Industrial Mill Rolls
D14.8M (ISO/TR 17844 IDT): 2009 Standard Methods for the Avoidance of Cold *****s
D14.9/D14.9M:2013 Specification for Welding of Hydraulic Cylinders
Management & Economics
DPW Design and Planning Manual for Cost-Effective Welding
TIH-H The Industrial Hobarts
TWM Total Welding Management
Marine
D3.5:1993 Guide for Steel Hull Welding
D3.6M:2010 Underwater Welding Code
D3.9:2010 Specification for Classification of Weld-Through Paint Primers
Metallurgy
PRGWM The Practical Reference Guide to Welding Metallurgy: Key Concepts for Weldability
WM1.4 Welding Metallurgy* Carbon and Alloy Steels* Volume 1* Fundamentals
Nickel
G2.1M/G2.1:2012 Guide for the Joining of Wrought Nickel-Based Alloys
Oxyfuel Welding & Cutting
C4.1:1977 (R2010) Criteria for Describing Oxygen-Cut Surfaces* and Oxygen Cutting Surface Roughness Gauge
C4.2/C4.2M:2009 Recommended Practices for Safe Oxyfuel Gas Cutting Torch Operation
C4.3/C4.3M:2007 Recommended Practices for Safe Oxyfuel Gas Heating Torch Operation
C4.4/C4.4M:2007 Recommended Practices for Heat Shaping and Straightening with Oxyfuel Gas Heating Torches
C4.5M:2012 Uniform Designation System for Oxyfuel Nozzles
C4.6M:2006 (R2012) Thermal Cutting – Classification of Thermal Cuts – Geometric Product Specification and Quality Tolerances
Piping & Tubing
D10.4:1986 Recommended Practices for Welding Austenitic Chromium-Nickel Stainless Steel Piping and Tubing
D10.8:1996 Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and Tubing
D10.10/D10.10M:1999 (R2009) Recommended Practices for Local Heating of Welds in Piping and Tubing
D10.11M/D10.11:2007 Guide for Root Pass Welding of Pipe Without Backing
D10.12M/D10.12:2000 Guide for Welding Mild Steel Pipe
D10.14M/D10.14:2010 Guide for Multipass Orbital Machine Pipe Groove Welding
D10.18M/D10.18:2008 Guide for Welding Ferritic/Austenitic Duplex Stainless Steel Piping and Tubing
Plastics
B2.4:2012 Specification for Welding Procedure and Performance Qualification for Thermoplastics
G1.1M/G1.1:2006 Guide to Ultrasonic Assembly of Thermoplastics
G1.10M:2016 Guide for the Evaluation of Hot Gas* Hot Gas Extrusion* and Heated Tool Butt Thermoplastic Welds
Qualification Procedures & Personnel
B2.1/B2.1M:2014 Specification for Welding Procedure and Performance Qualification
B2.1/B2.1M-BMG:2014 Base Metal Grouping for Welding Procedure and Performance Qualification
B2.3/B2.3M:2012 Specification for Soldering Procedure and Performance Qualification
B5.1:2013 Specification for the Qualification of Welding Inspectors
B5.2:2001 Specification for the Qualification of Welding Inspector Specialists and Welding Inspector Assistants
B5.4:2005 Specification for the Qualification of Welder Test Facilities
B5.5:2011 Specification for the Qualification of Welding Educators
B5.9:2006 Specification for the Qualification of Welding Supervisors
B5.14:2009 Specification for the Qualification of Welding Sales Representatives
B5.15:2010 Specification for the Qualification of Radiographic Interpreters
B5.16:2006 Specification for the Qualification of Welding Engineers
B5.17:2014 Specification for the Qualification of Welding Fabricators
C1.5:2015 Specification for the Qualification of Resistance Welding Technicians
C2.16/C2.16M:2002 Guide for Thermal-Spray Operator Qualification
D16.4M/D16.4:2015 Specification for the Qualification of Robotic Arc Welding Personnel
PAPQV The Professional’s Advisor on Procedure Qualification Variables
Radiography
Railroads
D15.1/D15.1M:2012-AMD1 Railroad Welding Specification for Cars and Locomotives
D15.2/D15.2M:2013 Recommended Practices for the Welding of Rails and Related Rail Components for Use by Rail Vehicles
Reference
A1.1:2001 Metric Practice Guide for the Welding Industry
A2.4:2012 Standard Symbols for Welding* Brazing* and Nondestructive Examination
A3.0M/A3.0:2010 Standard Welding Terms and Definitions
JWE Jefferson’s Welding Encyclopedia
PHB-5 The Everyday Pocket Handbook on Metric Practices for the Welding Industry
PPGHF The Practical Reference Guide for Hardfacing
PRGP Practical Reference Guide to Positioning
WHB-1-9 Welding Handbook Ninth Edition* Volume 1* Welding Science and Technology
WHB-2-9 Welding Handbook Ninth Edition* Volume 2* Welding Processes* Part 1
WHB-3-9 Welding Handbook Ninth Edition* Volume 3* Welding Processes* Part 2
WHB-4-9 Welding Handbook Ninth Edition* Volume 4* Materials and Applications* Part 1
WHB-5-9 Welding Handbook Ninth Edition* Volume 5* Materials and Applications* Part 2
Resistance Welding
A1.10M:2007 Specification for Calibration and Performance testing of Secondary Current Sensing Coils and Weld Monitors used in Single-Phase AC Resistance Welding
C1.1M/C1.1:2012 Recommended Practices for Resistance Welding
C1.4M/C1.4:2009 Specification for Resistance Welding of Carbon and Low-Alloy Steels
J1.1M/J1.1:2013 Specification for Resistance Welding Controls
J1.2M/J1.2;2016 Guide to Installation and Maintenance of Resistance Welding Machines
RWM Resistance Welding Manual
RWPH Resistance Welding Pocket Handbook
Robotic Welding
D16.1M/D16.1:2004 Specification for Robotic Arc Welding Safety
D16.2M/16.2:2007 Guide for Components of Robotic and Automatic Arc Welding Installations
D16.3M/ D16.3:2009 Risk Assessment Guide for Robotic Arc Welding
Health & Safety
EWH-1 thru 14 Effects of Welding on Health* Vol. I through XIV
F1.1M:2006 Method for Sampling Airborne Particulates Generated by Welding and Allied Processes
F1.2:2013 Laboratory Method for Measuring Fume Generation Rates and Total Fume Emission of Welding and Allied Processes
F1.3:2006 A Sampling Strategy Guide for Evaluating Contaminants in the Welding Environment
F1.6:2003 Guide for Estimating Welding Emissions for EPA and Ventilation Permit Reporting
F2.3M:2011 Specification for Use and Performance of Transparent Welding Curtains and Screens
F3.2M/F3.2:2001 Ventilation Guide for Weld Fume
FUMES AND GASES Fumes and Gases in the Welding Environment
Z49.1:2012 Safety in Welding* Cutting* and Allied Processes
Sheet Metal
D1.3/D1.3M:2008 Structural Welding Code—Sheet Steel
D9.1M/D9.1:2012 Sheet Metal Welding Code
SMAW
PHB-7 The Everyday Pocket Handbook for Shielded Metal Arc Welding (SMAW)
Shielding Gases
A5.32M/A5.32 (ISO 14175 MOD):2011 Welding Consumables – Gases & Gas Mixtures for Fusion Welding and Allied Processes
Soldering
SHB Soldering Handbook
GHSP Guideline for Hand Soldering Practices
C3.11M/C3.11:2011 Specification for Torch Soldering
Stainless Steel
A5.9/A5.9M:2012 Specification for Bare Stainless Steel Welding Electrodes and Rods
D1.6/D1.6M:2007 Structural Welding Code—Stainless Steel
G2.3M/G2.3:2012 Guide for the Joining of Solid Solution Austenitic Stainless Steels
PASS The Professional’s Advisor on Welding of Stainless Steels
WQS Welding Stainless Steel—Questions and Answers
Steel
D1.1/D1.1M:2015 Structural Welding Code-Steel
PHB-1 The Everyday Pocket Handbook for Arc Welding Steel
Structural Welding
D1.1 CCRM:2015 Code Clinic for Study of AWS D1.1 Structural Welding Code—Steel* Reference Manual
D1.4/D1.4M:2011 Structural Welding Code—Reinforcing Steel
D1.5M/D1.5:2015 Bridge Welding Code
D1.7/D1.7M:2010 Guide to Repair and Strengthening of Existing Structures
D1.8/D1.8M:2016 Structural Welding Code—Seismic Supplement
D1.9/D1.9M:2015 Structural Welding Code—Titanium
PHB-3 The Everyday Pocket Handbook on Welded Joint Details for Structural Applications
PHB-6 The Everyday Pocket Handbook for Visual Inspection of D1.1 Structural Welding Code’s Fabrication & Welding Requirements
Stud Welding
Surfacing
Symbols
Terminology
Thermal Spraying
C2.18:1993 Guide for the Protection of Steel with Thermal Sprayed Coatings of Aluminum and Zinc and Their Alloys and Composites
C2.21M/C2.21:2015 Specification for Thermal Spray Equipment Acceptance Inspection
C2.25/C2.25M:2012 Specification for Thermal Spray Feedstock — Wire and Rods
TSM Thermal Spray Manual
TSS Thermal Spraying Practice* Theory and Application
TST ASM Handbook Volume 5A: Thermal Spray Technology
Thermite Welding
Titanium
G2.4/G2.4M:2014 Guide for the Fusion Welding of Titanium and Titanium Alloys
Welding Curtains & Screens
Zinc Coatings
WZC Welding Zinc-Coated Steels
Zirconium
G2.5/G2.5M:2012 Guide for the Fusion Welding of Zirconium and Zirconium Alloys
new link:
AWS A5.36-2016 Spec for Carbon and Low-Alloy Steel Flux Cored Electrodes for FCAW and Metal Cored Electrodes for GMAW
AWS - WIT-W-2008 Welding Inspection Technology Workbook 5th Ed. 2008
AWS G2.3 G2.3M-2012 Guide for the Joining of Solid Solution Austenitic Stainless Steels
It is not A1.10M:2007
The correct number is A10.1
AWS A10.1M-2007 Calibration and Performance Testing of Secondary Current Sensing Coils and Weld Current Monitors used in Single-Phase AC Resistance Welding
TWM - Total Welding Management - Barckhoff 2005
Aws qc1-2016 standard for aws certification of welding inspectors
