Thank you for your great help
Thank you so much for sharing
I got some additional for you :
UL 1739-2007 Standard for Pilot-Operated Pressure-Control Valves for Fire-Protection Service.pdf 0.208 MB
UL 262-2006 Standard for Gate Valves for Fire-Protection Service.pdf 407.83 KB
UL 8-2007 Water Based Agent Fire Extinguishers.pdf 1.05 MB
I've forgotten this one :
UL 1468-2007 Standard for Direct Acting Pressure Reducing and Pressure Restricting Valves.pdf 0.508 MB
Achmad Nur Eddin, thanks for sharing
Sorry, I do not have it Sir !
Most of the links are already expired. Can someone be good enough to reupload all of them?
UL 83-2001 Thermoplastic Insulated Wires and Cables
UL 1709-2007 Rapid Rise Fire Tests of Protection Materials for Structural Steel
UL 1778 2005 Uninterruptible Power Systems
UL 4 - Armored Cable
UL 444 - Communication Cables
UL 467 - Grounding and Bonding Equipment
UL 674 - Electric Motors and Generators for Use in Division 1 Hazardous (Classified) Locations
UL 698A - Industrial Control Panels Relating to Hazardous (Classified) Locations
UL 711 - Rating and Fire Testing of Fire Extinguishers
UL 823 - Electric Heaters For Use In Hazardous (Classified) Locations
UL 844 - Luminaires for Use in Hazardous (Classified) Locations
UL 877 - Circuit-Breaker Enclosures for Use in Hazardous Locations
UL 886 - Outlet Boxes and Fittings for Use in Hazardous (Classified) Locations
UL 894 - Switches For Use In Hazardous (Classified) Locations
UL 913 - Intrinsically Safe Apparatus for Use in Class I, II, and III, Division 1 Locations
UL 1424 - Cables for Power-Limited Fire-Alarm Circuits
UL 1-2007 Standard for Flexible Metal Conduit
UL 96A-2007 Installation Requirements for Lightning Protection Systems
UL 154-2007 Carbon-Dioxide Fire Extinguishers
UL 94-2006 Test of flammability of plastic materials
UL 125-2007 Standard for Valves for Anhydrous Ammonia and LP-Gas (Other Than Safety Relief)
UL 132-2007 Standard for Safety Relief Valves for Anhydrous Ammonia and LP-Gas
Sir,
Thank you for your great sharing
Thank you Achmad Nur Eddin
Please I need the UL 347A standard "OUTLINE OF INVESTIGATION FOR MEDIUM VOLTAGE POWER CONVERSION CONTROLLERS-Issue Number: 1 "
Thanks a lot
