Page 3 of 29 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 25 to 36 of 347
Thread: Eclipse step by step
  1. temr, excellent effort.. I'm following
    Thank you
    exuse me temr ,but the pictures in the filefactory are not downloadable???
    please help ( or put them like an attached files).
    Thanks for this great and nice effort...
    by the way i'have a step by step course for eclipse if you want i'll share it
    i think it can clarify well your explanation
    Jan 2009
    ALA, KZ
    Again friends share with you questions and success))
    to poss007 not a problem please share here more information more understanding
    the link with model and all 5 chapters is
    Elamin Wrote
    Dear Temr please if you have Swi from the log is =0.35 and from Pc =0.15 and from relative permeability =0.20 which one I can depend on and why ?? thanks
    To Elamin
    The main chalange of reservoir engeenier to combine core data and log data . You have raised very keen issue how to link Sw by Archie with Core Data , like Pc and Real Perm.
    In your example Swc by Pc =0.15, Swc by realperm = 0.2 , first of all check if it the sample core sample. Some times laboratories use different core samples.
    If poro sample are different then try to establish trend Swc vs Perm. If this are the same sample then i would use Pc value because the displacement pressure much higher during Swc measurements ( mercury, oil injection) comparing to real perm.
    Regarding Archi Sw value if 0.35 is you average then before to change something try to build SCAL data with your Pc pressure un the model , import it to petrel and in Petrel run volumetrics, and compare that value to wat you have from logs .
    Follow my link i will insert now step by step profile
  6. #28
    Jan 2009
    ALA, KZ
    Chapter 5_1
    Elamin, raised a good question. So how we can check average saturation in sim model fast and quick and compare it let say to saturation of well data or gmodel or play with scal data and see results
    For example i have to sets of scal data how that will impact to my Sw and apparently reserves
    Firstly i prepare second set of scal with following data
    SWOF
    0.428595 0 1 1.36
    0.440147 0.001664 0.906708 0.902168
    0.460815 0.001794 0.755375 0.444337
    0.483279 0.00262 0.612257 0.213154
    0.509156 0.005004 0.472792 0.095297
    0.510767 0.005218 0.464956 0.090764
    0.512465 0.005452 0.456795 0.086231
    0.514261 0.00571 0.448278 0.081698
    0.516167 0.005995 0.43937 0.077165
    0.518196 0.006314 0.430029 0.072632
    0.520364 0.00667 0.420207 0.068099
    0.522692 0.007072 0.409847 0.063566
    0.525204 0.007529 0.398881 0.059033
    0.527929 0.008051 0.387224 0.0545
    0.530908 0.008656 0.374775 0.049967
    0.53419 0.009364 0.361406 0.045434
    0.53784 0.010205 0.346954 0.040901
    0.54195 0.011221 0.331203 0.036368
    0.546645 0.012474 0.313867 0.031835
    0.552113 0.014063 0.294544 0.027302
    0.558646 0.016153 0.272644 0.022769
    0.56674 0.019047 0.247251 0.018236
    0.577333 0.023375 0.216798 0.013703
    0.592556 0.030752 0.178212 0.00917
    0.619323 0.047409 0.123698 0.004637
    0.792122 0.3 0 0.000104
    1 1 0 0
    SGOF
    0 0 1 0
    0.036361 0.002542 0.683335 0
    0.072721 0.02537 0.463762 0
    0.109082 0.068665 0.312376 0
    0.145443 0.133083 0.208646 0
    0.181803 0.219281 0.138051 0
    0.218164 0.327919 0.090368 0
    0.254525 0.459651 0.058431 0
    0.290885 0.615138 0.037243 0
    0.327246 0.795035 0.023339 0
    0.363607 1 0 0
    then
    i run 1 model with initial scal and import data as i describe in Chapter 5
    as all properties in sim folder are dynamic ( if you delete data in sim model all data will disappeared in Petrel ) i create new Sw_scal1 property
    Press Enter then NO
    you will get new property
    now you can run volumetrics
    on process tab double click on volume culculations as shown in pictures below
    You will be return to
    DO the following
    Step 1
    Define contact by dragging existing contact
    In jeneral properties uncheck poro and Ntg
    in Oil prop check sw_scal1
    Press apply and run
    Petrel will calculate reserve table
    you can import it to excell an get following
    for this filed my saturation oil will make 55%
    NOTE!!!!!!!!!!! the reserves in table are at reservoir condition to get to standard meter cubic you need to multiply them to shrinkage factor
    So you by this approach you can check you reserves in model, average saturation, and play with scal
    i mooved to 4share here is link with all chapters
  7. #29
    Jan 2009
    ALA, KZ
    Sorry for making not clear statements in some sentences - end of the day )
  9. Temr
    Plz reupload your link for all chapters.
    TIA
  10. #31
    Jan 2009
    ALA, KZ
    Vitaly
    please find below
  11. thank you very much,I want to study step by step following you!
  12. #33
    this is the link for the step by step course for eclipse
    i hope that it'll be helpful!!
  13. Temr, Poss007.... you are AWSOME!!!!!!!!!!!!!!!!!!!!!!! keep it coming!!!
  14. #35
    Jan 2009
    ALA, KZ
    Poss007 Thanks for you input
  16. #36
    Jan 2009
    ALA, KZ
    The Chapter 6 and Chapter 7 will be dedicated pure to well model applied in Eclipse
    In the chapter 6 following point will be discussed
    1. Well as it defined geometrically in simulator
    2. Well inflow equation ( approximate)
    3. Connection productivity index calculation
    1. Well representation in Eclipse.
    Normally what we call well, has wellbore , bottom hole and trajectory, in eclipse for the purpose of simplicity stated that the well penetrates the cell strictly in the center of it so, for showing to eclipse the well you do not need to input well coordinates, all you need is to give to Eclipse the i,j,k indexes of cell which well penetrate.
    So for representing well to eclipse you need
    1. give i, j of well head , usually it is the value of i,j of 1 cell well penetrates.
    2. cells indexes well penetrates .
    How to get that values
    In Petrel, eclipse specification, this data called , eclipse well connection data, and usually files with that data has extension *.trj.
    For exporting that data open test project in Petrel
    go to model and press export
    in combo box choose eclipse well connection data
    and press save
    in option menu check properties
    press ok and open file in text editor
    you will have something like this
    Lets go details for well_1 connection data
    but before this form table in excel and sort data as shown below
    in row TRAJECTORY_COLUMN_ORDER you have the following table heads the description of each showed below
    MD_ENTRY - measured depth of well trace where well_1 penetrates cell
    GRID_I - i index of cell , penetrated by well_1
    GRID_J - j index of cell , penetrated by well_1
    GRID_K - k index of cell , penetrated by well_1
    WELL_ENTRY - note that there 3 rows after it which are x,y,z of point where well_1 penetrates cell
    ENTRY_FACE - entry face of cell which well_1 penetrates
    MD_EXIT - measured depth of well where well_1 exits cell
    WELL_EXIT - note that there 3 rows after it which are x,y,z of point where well_1 exits cell
    EXIT_FACE - exit face of cell which well_1 exit cell
    After this amust parameters following user properties which will required in Chapter 7 when we will calculate Ro, CCF, Kh
    So what is the face of cell? below is the example describing face of cell
    From this picture you can see that there is 8 faces of cell and 16 direction all faces might have
    From this data for building schedule section we will need
    For representing well to eclipse
    wellhead_i
    wellhead_j
    For connection well to grid blocks
    GRID_I
    GRID_J
    GRID_K
    For perforation Kh calculation
    MD_ENTRY
    MD_EXIT
    Permx - user defined property
    Permy - user defined property
    Permz- user defined property
    For Ro (pressure equivalent radius )
    Nx-user defined property( cell dimension in i direction)
    Ny-user defined property( cell dimension in j direction)
    Nz-user defined property( cell dimension in k direction)
    Just write this data for now we will return to it later in Chapter 7
    For calculating well inflow the following assumptions are used
    • The well is assumed to penetrate the full thickness of the block, through its center,
    perpendicularly to two of its faces .
    NOTE!!!!!!!!!!!!!! the perforation length is counted by Kh
    • For any calculation time step density of fluid within the well bore does not vary with
    depth.
    • Friction effects in the well bore are neglected.
    • Capillary pressure is neglected when calculating inflow performance relationship; oil
    phase pressure is used.
    The inflow equation could be describe by following equation
    Or if simply to rewrite equation 5.1 is
    Q_liq=(Productivity_index*Delta_Pressure)
    and Productivity index= CCF/ viscosity
    were CCF - cell connection factor
    3. Cell connection factor (CCF) calculation
    For calculating CCF you will need following
    you need to calculate connection transmissibility in x,y,z direction by following formula
    Rw is well radius
    NOTE!!!!!!!!! As the inflow formula describe perfect flow model for purposes of taking in to account not perfectness of well drainage area Skin parameter was introduce.
    Skin is the degree of clearness of nearwellbore area.
    Traditionally if skin is negative it is mean that the area has better drainage and the more skin is positive the bad properties drainage area has. One of way to get skin is to calculate it during well tests base on pressure build up curve.
    So you will need to derive 3 T
    Tx,Ty,Tz
    For this you will need
    1. Khx, Khy, Khz
    Note!!!!!!!!!!!!!!! that original formula assumes not H, but Hx,Hy,Hz which is magnitude of perforation vector in all 3 direction.
    For simplicity I substitute it with constant H
    2. Pressure equivalent radius Ro
    The pressure equivalent radius should be calculate in 3 direction
    At the end you need to get Rox, Roy, Roz
    In a Cartesian grid the Peaceman’s formula is used
    Below is example of Ro in x direction
    Where
    Dx-Cell size in z direction
    Dy-Cell size in z direction
    Dz-Cell size in z direction
    Kx-permiability x
    Ky-permiability y
    Kz-permiability z
    3. Culculation of KH ,CCF, Ro
    Take in to account that connection transmissibility should be calculated in all 3 direction ( Tx, Ty,Tz)
    NOTE!!!! all this 3 values will be used in schedule section to make able eclipse calculate rates
    The link is
  1. Replies: 11
  2. Eclipse Step by Step?
    By Zuper in forum Reservoir
    Last Post: 04-05-2012, 12:56 AM
  3. Step by step to calculate control valve Cv thorugh Intools
    By hswang2 in forum Instrumentation & Control
    Last Post: 11-28-2010, 09:37 AM
