Dear may be some problem with your configuration. Try to run the Example3 of the Example-Other folder, and you see that there is no problem.
My system is 8 64 bits.
paul20
paul20
No you are wrong. I have tried the same file on etap 11 and 12. You may not encounter the problem now, but sooner or later it will come. An analysis of this c.r.a.c.k file has been given on previous posts. You may refer on it. This version also runs transient stability quite longer than the normal version. But thanks to one who still made this c.r.a.c.k.
friends:
you can try this!
(this is another l1n.K but I have not tryed with this second:
and for the m3Dic1n.4:
good luck!
if you have any problem with the lin.K in mega, try with:
Thanks for the uploads. I downloaded the ******** using the 3rd link i.e from '4 Shared' and installed ETAP 12.6. The message "Parameter not correct" is still coming when opening a file after saving in ETAP 12.6. After clicking "OK" of the message the ETAP 12.6 is working. When opening the files saved in ETAP 11, there is no problem. I think the problem is in saving the file in ETAP 12.6.
Someone has used this me*d in eta*p 12*.6*.5 ?? Maybe works, greetings!
LINK FULL *****[link Point to another website Only the registered members can access]
i am using etap 12.6. But for me step potential graph not come. How to solve this problems?
[ not so serious answer ] Of course it will not come, it has no legs!
[serious answer] If you are using IEEE method, graph is not necessary, that's why it has no option for plotting.
