API amirican petroleum institute
API 06AM 2nd ed 09 95 Material Toughness
API 006D Pipeline Valves
API 510 8th Ed Incl Add3 Dec 2001 Pres Vessel Inspection Code
API 526 flanged steel pressure Relief valves
API 527 for seat tightness of pressure relife valves
API 560 3rd Ed May 2001 Fired Heaters for general Refinery Services
API 594 Check Valves 5th ed 1997
API 598 7th ED Oct 1996 Valve Inspection and Testing
API 610 8th Ed, Aug 1995 Cent Pumps
API 611 4th Ed, Jun 1997 Steam Turb
API 612 4th Ed, Jun 1995 Spec Purp Steam Turb
API 613 4th Ed, Jun 1995 Spec Purp Gear Units
API 614 4th Ed, Apr 1999 Lub, Shaft Seal, Control Oil Sys and aux
API 616 4th Ed, Aus 1998 Gas Turbines
API 617 6th Ed, Feb 1995 Centrifugal Compressors
API 618 4th Ed, Jun 1995 Recip Compressors
API 619 3rd Ed, Jun 1997 Pos Disp Compressor
API 620 10th ed Feb 02 Design and Construction of Large Welded LP Storage Tanks
API 650 Welded Tanks for Oil Storage 10th Ed Add1 Mar 2000
API 653 3rd Ed Dec 01 Tank Insp Repair Alteration and Reconstruction
API 660 Feb 2001 6th Ed Shell and Tube Heat Exchangers
API 661 Nov 1997 4th ed Air Cooled Heat Exchangers
API 670 4th Ed Dec 2000 Machinery Prot Sys
API 530 4th ed Ocy 1996 Calc of Heater Tube Thickness
API 671 3rd Ed Oct 1998 Spec Purp Couplings
API 672 3rd Ed Sep 1996 Integ Geared Centrif Air Comp
API 674 2nd Ed Jun 1995 Pos Disp Pumps
API 675 2nd Ed Oct 1994 Pos Disp Pumps Controlled Vol
API 677 2nd Ed Jul 1997 Gear Units
API 681 1st Ed Feb 1996 Liq Ring Vac Pumps and Compressors
API 682 1st Ed Oct 1994 Shaft Sealing Sys for Cent and Rotary Pumps
API 683 1st Ed Sep 1993 Quality Improvement Manual for Mech Equipment
API 2510 8th Ed May 2001 Design and Construction od LPG Facilities
API 2510a 2nd Ed May 2001 Fire Protection of LPG FacilitiesAPI
API PUB 534 1st Ed Jan 95 Heat Recovery Steam Generators
API PUB 684 1st Ed Feb 1996 Rotoro Dynamics and Balancing
API PUB 760 2nd Ed Jun 1998 Model Risk Management Plan
API Pub 938 May 1996 1 1 4 Cr 1 2 Mo ***** Repairs
API Pub 959 May 1982 Temper Embrittlement of Cr Mo Steels
API RP 500 2nd Ed 1997 Area Classification
API RP 505 1st Ed 1997 Area Classification
API RP 521 4th Ed Mar 97 Guide for Pres Rel and Depres Sys
API RP 540 4th Ed Apr 99 Electrical Inst
API RP 572 Management of Hazards Associated with Location of Process PLants and Buildings
API RP 573 1st Ed Oct 91 Inspection of Fired Boilers and Heaters
API RP 574 2nd Ed Jun 98 Inspection Practices for Piping System Components
API RP 576 2nd Ed Dec 00 Inspection of Pressure Relieving devices
API RP 579 1st Ed Mar 00 Fitness for Service
API RP 686 1st Ed Apr 1996 Machinery Inst Guide
API RP 934 1st Ed Dec 2000
API RP 945 2nd Ed Oct 97 Avoiding Environment *****ing In Amine Units
API RP 1104 19tht Ed Oct 01 Welding of pipelines and related facilities
API RP 2028 3rd Ed Feb 02 Flame Arrestors in Piping Systems
API 579 1st Ed Revised Mar 2000 Fitness for service 1 - 100
API RP 2350 2nd Ed 1996 Overfill Prot For Storage Tanks
___
