hi every body
I'm simulating different co2 injection modes. does any one know how can i model SWAG (simultaneous water-and-CO2 injection) process in ECLIPSE?
hi every body
hi every body
try to read technical describtion af eclipse manual ( co2 injection)
thanks for ur comment but i have problem in schedule section!i read technical description but i didn't get my answer.i don't know how can i define injecting co2 and water at the same time in the same perforation interval.can i define a stream containing mole fractions of co2 and water?
check this
SCHEDULE
RPTRST
PRESSURE SWAT SGAS DENG DENW AMF XMF YMF/
RPTRST
SWAT SGAS XMF YMF AMF /
RPTSCHED
SWAT SGAS AMF /
--Define injection and production wells
--2000a WELLSPEC is used for back-compatibility, prefered keyword is WELSPECS
--WELLSPEC
--P1 FIELD 2 2 /
--P2 FIELD 5 5 /
--P3 FIELD 6 6 /
--IG FIELD 1 1 /
--IW FIELD 8 8 /
WELSPECS
P1 FIELD 2 2 1* GAS /
P2 FIELD 5 5 1* GAS /
P3 FIELD 6 6 1* GAS /
IG FIELD 1 1 1* GAS /
IW FIELD 8 8 1* WATER /
--Define completions
--2000a WELLCOMP is for back-compatibility, prefered keyword is COMPDAT
--WELLCOMP
--P1 2 2 1 2 /
--P2 5 5 3 4 /
--P3 6 6 1 2 /
--IG 1 1 1 1 /
--IW 8 8 6 6 /
COMPDAT
P1 2 2 1 2 /
P2 5 5 3 4 /
P3 6 6 1 2 /
IG 1 1 1 1 /
IW 8 8 6 6 /
--Three producers with individual limits
--2000a WELLPROD is for back-compatibility, prefered keyword is WCONPROD
--WELLPROD
--P1 Ga 1* 1* 10000 /
--P2 Ga 1* 1* 10000 /
--P3 Ga 1* 1* 100 /
WCONPROD
P1 OPEN GRAT 1* 1* 10000 2* 10.0 /
P2 OPEN GRAT 1* 1* 10000 2* 10.0 /
P3 OPEN GRAT 1* 1* 100 2* 10.0 /
--Define water and gas injection streams (gas stream is pure CO2)
WELLSTRE
-- C1 C2 CO2 H2O
InjW 0.0 0.0 0.0 1.0 /
InjG 0.0 0.0 1.0 0.0 /
--Set water and gas injection rates
WINJGAS
IW STREAM InjW /
IG STREAM InjG /
--2000a WELLINJE is for back-compatibility, prefered keyword is WCONINJE
--WELLINJE
--IW St InjW Wa 1* 50 /
--IG St InjG Ga 2* 8000 /
WCONINJE
IW WATER OPEN RATE 50 1* 300.0 /
IG GAS OPEN RATE 8000 1* 300.0 /
--Set group production target
--2000a GRUPPROD is for back-compatibility, prefered keyword is GCONPROD
--GRUPPROD
--Field GA 1* 1* 7500 /
GCONPROD
Field GRAT 1* 1* 7500 /
--Set group gas quality target
GQUALITY
FIELD 13.5 /
--8 years of simulation
TSTEP
7*365 /
TSTEP
365 /
END
the full file you can find in ecl\2012.1\e300\data with examples
thank you so much dear temr. i have 2010.1 version. is this data file available in it?
hi there
i have a question about determining MMP using E300. can i use FIELD units instead of LAB units? because in eclipse sample data file LAB unit is used.
hi there
Hello every body
Thank you for this valuable information that you have been sharing arroud,
Even if it is not the topic I will ask my question
Can I have a cumulative curve in eclipse-office-Results of different fields.
Regards.
Hello every body
Regards.
temr,
Thanks for valuable tutorial
hi all, how can I see whats my reservoir temperature? I guess the software calculates the temperature according to the depth and with a temperature gradient..but how can i get the temperature from the software?.. because now i am calculating it by hand!
