Page 25 of 30 FirstFirst ... 15 23 24 25 26 27 ... LastLast
Results 289 to 300 of 353
Thread: Etap 14.1
  1. Re: Etap 14.1
    Version 14.0 brings not installer runs perfectly with the solution RunAsDate-x64, the version now comes with applied defaul faultysolution solution, so just run version 14 and the program will start correctly.
    Screenshot
    Quote Originally Posted by Omegarugal0 View Post
    Screenshot
    please elaborate
    Sent from my ASUS_T00J using Tapatalk
    :d :d :d
  6. Re: Etap 14.1
    Quote Originally Posted by surgeArrester View Post
    Daghan diay ta dri ani hahaha
    Sent from Mars
    Bai tabangi ko pag.install. salamat!
  7. #293
    Re: Etap 14.1
    Quote Originally Posted by himmelstern View Post
    How to run this portable version:
    Download and extract on a Drive then
    You must run as Administrator
    1. Download RunAsDate for x64
    [link Point to another website Only the registered members can access] and put the date 09.01.2015
    2. Click Start->Settings->Control Panel->Administrative Tool->DataSources (ODBC)
    or cr.ack
    Or
    [link Point to another website Only the registered members can access] ETAP 14_solution.rar
    I am not clear how to create a new data source to Sql server. I have tried several time but when I run the Etap 14 and create new project, in the end there is an error "There is no Local DB ODBC setup for ETAP, please setup Local DB DSN". That is the problem I am always facing. Maybe somene from this forum could help me?
  9. #294
    Re: Etap 14.1
    Quote Originally Posted by mukhriz View Post
    :d :d :d
    Mukhriz,
    Could you help me with below problem?
    "I am not clear how to create a new data source to Sql server. I have tried several time but when I run the Etap 14 and create new project, in the end there is an error "There is no Local DB ODBC setup for ETAP, please setup Local DB DSN". That is the problem I am always facing. Maybe somene from this forum could help me?"
  10. #295
    I did not use Runsasdate.
  11. #296
    Re: Etap 14.1
    Toolbar sometimes disappeared.
  12. #297
    Re: Etap 14.1
    If not use Runs as date, how to run Etap 14 and inform me. thanks
  13. #298
    Quote Originally Posted by PemulA View Post
    the faulty solution with all the errors as above
  14. #299
    Re: Etap 14.1
    or cr.ack
    Or
    Dear himmelstern,
    Could you elaborate how to create a new data source to Sql server as you have already showed above. I have tried several times but I though always failed. Because I can not open old project or create a new project.
    In the end I always faced an error "There is no Local DB ODBC setup for ETAP, please setup Local DB DSN".
    Could you help me by elaborating how to create a new data source to Sql server? Thank you
  16. #300
    Re: Etap 14.1
    Dear himmelstern,
    as below, this is an error when I open the existing project and create new project.
  1. Etap v12.5
    By alito_77 in forum Electrical & Power Engineering
    Last Post: 07-10-2015, 03:01 AM
  2. Etap 7
    By Sarmad Imtiaz Awan in forum Electrical & Power Engineering
    Last Post: 09-07-2014, 01:35 PM
  3. Etap 11
    By goldwincs in forum Electrical & Power Engineering
    Last Post: 03-01-2014, 12:29 PM
  4. Etap 7.1
    By Rudi Tua in forum Electrical & Power Engineering
    Last Post: 07-06-2011, 12:02 PM
