Page 21 of 56 FirstFirst ... 11 19 20 21 22 23 31 ... LastLast
Results 241 to 252 of 667
Thread: ETAP v11.0
  1. Re: ETAP v11.0
    DEAR fx007
    please tell me whats wrong with skm?
    i cant register that.please look at the pic
    Oct 2011
    Howrah, India, India
    Re: ETAP v11.0
    Hi fx007 can u please describe the ----- procedure once again. I have downloaded the ETAP 11.0.0c and also installed in Win 7 and Xp 32 bit but unfortunately I can't bypass the license manager I have got the Key as you have provided. But Can u please suggest how to bypass the license manager to insert the key? Is there and ----- ? if so kindly provide the link as well so I can download the same and apply. Please guide me in step by step procedure to bypass the license manager of ETAP 11.0.0c
  5. Re: ETAP v11.0
    Dear fx007, raj151857
    Please upload ETAP 11 (med) files as link is not working. Please help. Thanks a ton in advance.
    majaved
  6. Re: ETAP v11.0
    majaved
  7. Re: ETAP v11.0
    Quote Originally Posted by fx007 View Post
    Dear Friends,
    Happy holidays with ETAP 11 final ----- and PTW 7024 ******, as follows:
    [link Point to another website Only the registered members can access] Short descr: For etap, create ecp printer port, with settings: never use interrupt, enable legacy, lpt1, io range 03bc- or 02xx save, restart. follow desc in -----
    For PTW: DL PTW 7024 from 4shared. Install with softkeys. When asked for sitekey, go to ******, type your site key, the last line provided is site code, type site code in PTW, enjoy.
    I hope someone to post cdegs, its about time now ))
    the links failed. Please re upload.
  9. #246
    Mar 2010
    Navalcarnero, Madrid, Spain
    Re: ETAP v11.0
    Thanks fx007.
    Tested today with Windows Vista 32 bits and everything OK. ETAP 11 running.
    Detected that the new ETAP License Manager 11.0, superseded any previous ETAP License Managers (7.5 and lower) and therefore is not compatible with PETA6 cr......er.
    Previous ETAP versions (cr.......ed), like 7.5, 7.0 or 6.0 will not work with this new Etap License Mgr (Previous ETAP versions ask for a new activation code).
    To use previous versions is required to uninstall ETAP Lic. Mgr. 11 and re-install 7.5 and apply Peta.
  10. Smile Re: ETAP v11.0 / IT WORKS ON WIN 7 ultimate 64bits
    Quote Originally Posted by raj151857 View Post
    Dear Brothers. Please correct where am wrong.
    Can you please tell me which windows you are using. Am using Dell Latitude E5510 with Windows XP service pack 3. My ECP Printer Port (LPT1) settings are
    Port Settings
    Never use an Interrupt
    Enable legacy Plug & Play detection (arrow)
    LPT Port Number= LPT1
    Details
    Device Instance Id
    ACPI\PNP0401\5
    Resources
    I/O Range 03BC-03BF
    Setting based on current configurations
    I cannot change any setting here in Resources. In Bios I had change Parallel port to ECP mode. still after sucessful installation my Laptop hangs on starting ETAP 11.
    Please help brother.
    Raj
    I've got it working in a win 7 ultimate 64 bits laptop, IT WORKS!!!
    THANK YOU VERY MUCH fx007 and raj151857, we can't put in words our gratitude.
    To get it work you have to install it following the instructions on page 15, I reproduce below:
    1. Install Etap 11 and Etaps Lic Manager.
    2. Open Control Panel -> Administative tools -> Services, stop Etaps Lic Mgr
    service.
    3. Copy *.dll and *.exe files to the \Program Files\Operation Technology Inc\
    Etap License Manager 1100\
    4. Start "Etaps Lic Mngr" service again.
    5. Try to start etaps 11, if anything is okey it will ask you activation code.
    (stop your firewall or add this service to trusted zone)
    6. Enter new activation code: Z@8cUuS5w#nytVgCfvvccA%tDDu4jD6aNb?K
    7. Enjoy.
    Once you have installed it, if you haven't configured a new LPT1 port as described by raj151857 above, you have to do it,
    and then when you starts the program it will ask you for the activation code reproduce above in step 6.
    For installation you need the first .rar posted on page 14, reuploaded in a post you can see on the bottom of that page by tak2750
    You have to copy the 2 archives in the .rar in the installation directory as explained on step 3. in above instructions.
    THANK YOU VERY MUCH fx007 and raj151857. GREAT JOB AND GREAT CONTRIBUTION TO THE ENGINEERING COMMUNITY.
  11. #248
    Re: ETAP v11.0
    So far, 94,000 people have read this post, there were 260+comments on 21 pages, and NOONE has either SES CDEGS? I have found c***c for CDEGS 2000, but dont have the program. Then, I have latest 2009 and 2010 versions, but no c***c. Noone to help?
  12. #249
    Re: ETAP v11.0
    1. Instalar SKM PowerTools 7.0.2.4
    2. Copiar los archivos del Crk (ckInfo.exe y CrypKey Site Key Generator.ckInfo)
    3. Pegar en C:/……../bin/
    4. Ejecutar PTW32 como administrador
    5. Copiar SITE CODE
    6. Ejecutar ckInfo.exe como administrador
    7. Seleccionar el archivo CrypKey Site Key Generator.ckInfo y Presionar Abrir
    8. Escribir SITE CODE y pulsar Enter.
    9. Copiar Encrypting Key y Pegar en SITE KEY
    10. Presionar Update
  13. Re: ETAP v11.0
    Quote Originally Posted by atoyo View Post
    5. Copiar SITE CODE
    why i have error?
    please help me.
    look here
  14. Re: ETAP v11.0
    5. Copiar SITE CODE
    why i have error?
    please help me.
    look here
    please someone look at the pic and create site key for me.
    thank alot
    i really need that
  16. #252
    Re: ETAP v11.0
    Hi
    THANK YOU VERY MUCH fx007,
    but this med have a problem, After 50 minutes or more, license error occurs (can't connect with license manager).
    and after 15 minutes etap closed.
    please try to fix problem.
  1. ETAP v12
    By smzakaullah in forum Electrical & Power Engineering
    Last Post: 02-20-2015, 04:19 PM
  2. Etap 7
    By Sarmad Imtiaz Awan in forum Electrical & Power Engineering
    Last Post: 09-07-2014, 01:35 PM
  3. Need etap --------
  4. Etap 7.1
    By Rudi Tua in forum Electrical & Power Engineering
    Last Post: 07-06-2011, 12:02 PM
  5. Etap 7.0
    By pdms.ir in forum Electrical & Power Engineering
    Last Post: 08-19-2010, 10:44 PM
