Dear Friends,
I need the following UL Standards:
UL 1 Flexible Metal Conduit
UL 4 Armored Cable
UL 8 Foam Fire Extinguishers
UL 9 Fire Tests of Window Assemblies
UL 10B Fire Tests of Door Assemblies
UL 10C Positive Pressure Fire Tests of Door Assemblies
UL 38 Manually Actuated Signaling Boxes for Use with Fire-Protective Signaling Systems
UL 83 Thermoplastic-Insulated Wires and Cables
UL 94 Tests for Flammability of Plastic Materials for Parts in Devices and Appliances
UL 96A Installation Requirements for Lightning Protection Systems
UL 125 Flow Control Valves for Anhydrous Ammonia and LP-Gas
UL 132 Safety Relief Valves for Anhydrous Ammonia and LP-Gas
UL 142 Steel Aboveground Tanks for Flammable and Combustible Liquids
UL 154 Carbon-Dioxide Fire Extinguishers
UL 199 Automatic Sprinklers for Fire-Protection Service
UL 299 Dry Chemical Fire Extinguishers
UL 217 Single and Multiple Station Smoke Detectors
UL 219 Lined Fire Hose for Interior Standpipes
UL 231 Power Outlets
UL 260 Standard for Dry Pipe and Deluge Valves for Fire-Protection Service
UL 262 Gate Valves for Fire-Protection Service
UL 268 Smoke Detectors for Fire Protective Signaling Systems
UL 268A Smoke Detectors for Duct Application
UL 312 Check Valves for Fire-Protection Service
UL 325 Door, Drapery, Gate, Louver, and Window Operators and Systems
UL 331 Strainers for Flammable Fluids and Anhydrous Ammonia
UL 340 Tests for Comparative Flammability of Liquids
UL 393 Indicating Pressure Gauges for Fire-Protection Service
UL 401 Portable Spray Hose Nozzles for Fire-Protection Service
UL 404 Gauges, Indicating Pressure, for Compressed Gas Service
UL 437 Key Locks
UL 448 Standard for Pumps for Fire-Protection Service
UL 467 Grounding and Bonding Equipment
UL 508A Industrial Control Panels
UL 525 Flame Arresters
UL 539 Single and Multiple Station Heat Detectors
UL 674 Standard for Electric Motors and Generators for Use in Division 1 Hazardous (Classified) Locations
UL 698A Industrial Control Panels Relating to Hazardous (Classified) Locations
UL 711 Fire Extinguishers, Rating and Fire Testing
UL 719 Nonmetallic-Sheathed Cables
UL 727 Oil-Fired Cental Furnaces
UL 778 Motor Operated Water Pumps
UL 789 Indicator Posts for Fire-Protection Service
UL 844 Electric Lighting Fixtures for Use in Hazardous (Classified) Locations
UL 864 Control Units and Accessories for Fire Alarm Systems
UL 913 Intrinsically Safe Apparatus
UL 1002 Electrically Operated Valves for Use in Hazardous (Classified) Locations
UL 1040 Fire Test of Insulated Wall Construction
UL 1058 Halogenated Agent Extinguishing System Units
UL 1072 Medium-Voltage Power Cables
UL 1091 Butterfly Valves for Fire-Protection Service
UL 1203 Explosion-Proof and Dust-Ignition Electrical Equipment for Use in Hazardous (Classified) Locations
UL 1468 Standard for Direct Acting Pressure Reducing and Pressure Restricting Valves
UL 1481 Power Supplies for Fire Protective Signaling Systems
UL 1486 Quick Opening Divices for Dry Pipe Valves for Fire-Protection Service
UL 1685 Vertical-Tray Fire-Propagation and Smoke-Release Test for Electrical and Optical-Fiber Cables
UL 1709 Standard for Rapid Rise Fire Tests of Protection Materials for Structural Steel
UL 1711 Amplifiers for Fire Protective Signaling Systems
UL 1730 Smoke Detector Monitors
UL 1739 Pilot-Operated Pressure-Control Valves for Fire-Protection Service
UL 1778 Uninterruptible Power Systems
UL 1803 Factory Follow-Up on Third Party Certified Portable Fire Extinguishers
UL 2034 Single and Multiple Station Carbon Monoxide Detectors
UL 2111 Overheating Protection for Motors
UL 2227 Standard For Safety For Overfilling Prevention Devices
UL 2250 Instrumentation Tray Cable
UL 2351 Spray Nozzles for Fire-Protection Service
UL 5085-3 Low Voltage Transformers - Part 3: Class 2 and Class 3 Transformers
UL 60079-5 Electrical Apparatus for Explosive Gas Atmospheres - Part 5: Powder Filling 'q'
UL 60079-6 Electrical Apparatus for Explosive Gas Atmospheres - Part 6: Oil-Immersion 'o'
UL 60079-7 Electrical Apparatus for Explosive Gas Atmospheres - Part 7: Increased Safety "e"
UL 60079-15 Electrical Apparatus for Explosive Gas Atmospheres - Part 15: Electrical Apparatus with Type of Protection 'n'
UL 60745-1 Hand-Held Motor-Operated Electric Tools - Safety - Part 1: General Requirements
Anyone having these standards could you please upload them.
Thanks very much.
