how to remove previous format in etap 12.6?
i dont want format for etap 11.
it is just waist of disck
I have the same problem of ODBC as vlady34 is there any suggested solution
The problem is not installed or otiaccess otireport me. We solved it. If the windows is 32 bit you should go to Administrative Tools and open the ODBC data source, and then create the otiaccess otireport Access to the driver according to the version you have installed (so I resolved to windows 7 x32 with MS Office 2007). In the case of windows 64 bits (spent two days looking for solution for MS Office 2013) I had to install the ODBC access 32-bit 2010 (Microsoft Access Database Engine 2010) then create the two ODBC asking ETAP. What happens is that ETAP using Access as a driver.
The problem is not installed or otiaccess otireport me. If the windows is 32 bit you should go to Administrative Tools and open the ODBC data source, and then create the otiaccess otireport Access to the driver according to the version you have installed (so I resolved to windows 7 x32 with MS Office 2007). In the case of windows 64 bits (spent two days looking for solution for MS Office 2013) I had to install the ODBC access 32-bit 2010 (Microsoft Access Database Engine 2010) then create the two ODBC asking ETAP. What happens is that ETAP using Access as a driver.
thanks for your answer.
but i could not repair the problem.
after i installed the etpa 12.6 .i manually deleted the previous format folder.
but the problem is every time that i start the etap .it create those flder again .
is it possible to upload more pics an explain haw to do it?
One question: How is the Star View is used to activate the operating sequence?
Since I solved it, you have to associate the relay to switch. Probe my model with version 11 and the results are identical, so the calculations of fault currents are working well.
If you need ETAP 12.6, without ----- problem and fully work on All windows(Xp, 7, 8.1 32&64 bits) and fully module, I'll available here.
send email to me: eng.soft2015@gmail.com
