AWS C2.23-2003 Specification for the Application of Thermal Spray Coatings (Metallizing) of Aluminum, Zinc, and Their Alloys and Composites for the Corrosion Protection of Steel
AWS C2.20-2002 Specification for Thermal Spraying Zinc Anodes on Steel Reinforced Concrete
AWS - CMWS-2005 - Certified Welding Supervisor Manual for Quality and Productivity Improvement
thank all of you
OK, here is a big one, thanks to mohamad3010 for the original file, here it is cleaned......AWS 5.9
AWS - Welding Handbook Ninth Edition Volume 5 MATERIALS AND APPLICATIONS, PART 2
many thanks to all of you
Big Thank , Marty & Mohamed3010
AWS - Supplement 2, includes following missing files, not the reaffirmed issues
A4.2M (ISO 8429 MOD):2006 (R2014) Standard Procedures for Calibrating Magnetic Instruments to Measure the Delta Ferrite Content of Austenitic and Duplex Ferritic-Austenitic Stainless Steel Weld Metal
A4.3:1993 (R2006) Standard Methods for Determination of the Diffusible Hydrogen Content of Martensitic,Bainitic, and Ferritic Steel Weld Metal Produced by Arc Welding
A4.4M:2001 (R2006) Standard Procedures for Determination of Moisture Content of Welding Fluxes and Welding Electrode Flux Coverings
A5.15:1990 (R2016) Specification for Welding Electrodes and Rods for Cast Iron
A5.19:1992 (R2016) Specification for Magnesium Alloy Welding Electrodes and Rods
A5.20/A5.20M:2005 (R2015) Specification for Carbon Steel Electrodes for Flux Cored Arc Welding
A5.25/A5.25M:1997 (R2009) Specification for Carbon and Low-Alloy Steel Electrodes and Fluxes for Electroslag Welding
C5.7:2000 (R2006) Recommended Practices for Electrogas Welding
C6.1:1989 (R2009) Recommended Practices for Friction Welding
D10.6/D10.6M:2000 Recommended Practices for Gas Tungsten Arc Welding of Titanium Piping and Tubing
D10.12M/D10.12:2000 Guide for Welding Mild Steel Pipe
F2.2:2001 (R2010) Lens Shade Selector
G1.1M/G1.1:2006 Guide to Ultrasonic Assembly of Thermoplastics
G2.3M/G2.3:2012 Guide for the Joining of Solid Solution Austenitic Stainless Steels
PRGWM The Practical Reference Guide to Welding Metallurgy: Key Concepts for Weldability
QC19:2002 Standard for the AWS Certification of Robotic Arc Welding Personnel
RWM Resistance Welding Manual
TWM Total Welding Management
WM1.4 Welding Metallurgy, Carbon and Alloy Steels, Volume 1, Fundamentals
WQA Welding Aluminum–Questions and Answers
We are still missing these...
A1.10M:2007 Specification for Calibration and Performance testing of Secondary Current Sensing Coils and Weld Monitors used in Single-Phase AC Resistance Welding
A5.24/A5.24M:2014 Specification for Zirconium and Zirconium-Alloy Welding Electrodes and Rods
A5.28/A5.28M:2005 (R2015) Specification for Low-Alloy Steel Electrodes and Rods for Gas Shielded Metal Arc Welding
A5.35/A5.35M:2016 Specification for Covered Electrodes for Underwater Wet Shielded Metal Arc Welding
A5.36/A5.36M:2016 Specification for Carbon and Low-Alloy Steel Flux Cored Electrodes for Flux Cored Arc Welding and Metal Cored Electrodes for Metal Arc Welding
C1.5:2015 Specification for the Qualification of Resistance Welding Technicians
C2.16/C2.16M:2002 Guide for Thermal-Spray Operator Qualification
C2.19/C2.19M:2013 Specification for the Application of Thermal Spray Coatings to Machine Elements for OEM & Repair
C2.21M/C2.21:2015 Specification for Thermal Spray Equipment Acceptance Inspection
C3.4M/C3.4:2016 Specification for Torch Brazing
C3.5M/C3.5:2016 Specification for Induction Brazing
C4.1:1977 (R2010) Criteria for Describing Oxygen-Cut Surfaces, and Oxygen Cutting Surface Roughness Gauge
C5.3:2000 (R2011) Recommended Practices for Air Carbon Arc Gouging and Cutting
C5.10/C5.10M :2003 Recommended Practices for Shielding Gases for Welding and Cutting
C7.3:2016 Process Specification for Electron Beam Welding
CCRM:2015 Code Clinic–Structural Welding Code – Steel
D1.9/D1.9M:2015 Structural Welding Code—Titanium
D8.1M:2013 Specification for Automotive Weld Quality – Resistance Spot Welding of Steel
D10.13/D10.13M:2001 Recommended Practices for the Brazing of Copper Tubing and Fittings for Medical Gas Systems
D16.4M/D16.4:2015 Specification for the Qualification of Robotic Arc Welding Personnel
D17.3/D17.3M:2016 Specification for Friction Stir Welding of Aluminum Alloys for Aerospace Applications
D18.3/D18.3M:2015 Specification for Welding of Tanks, Vessels, and Other Equipment in Sanitary (Hygienic) Applications
EG2.0:2008 Guide for Training and Qualification of Welding Personnel: Entry Welder
EG3.0:2006 Guide for the Training and Qualification of Welding Personnel: Level II – Advanced Welders
G1.2M/G1.2:1999 (R2010) Specification for Standardized Ultrasonic Welding Test Specimen for Thermoplastics
G1.6:2006 Specification for the Qualification of Plastics Welding Inspectors for Hot Gas, Hot Gas Extrusion, and Heated Tool Butt Thermoplastic Welds
G1.10M:2016 Guide for the Evaluation of Hot Gas, Hot Gas Extrusion, and Heated Tool Butt Thermoplastic Welds
GWF:1998 Guide for Setting Up a Welder Training Facility
GTW:2005 Guide to Weldability: Carbon and Low-Alloy Steels
PAPQV The Professional’s Advisor on Procedure Qualification Variables
PRGHF The Practical Reference Guide for Hardfacing
PRGP Practical Reference Guide to Positioning
QC20:2011 Standard for the AWS Certification of Resistance Welding Technicians
TIH-H The Industrial Hobarts
AWS QC17-2015 Standard for AWS Accreditation of Certified Welding Fabricators
Many thanks all of you
Thank a lot indeed
please add this also to the updated list
Welding stainless steel - questions and answers a guide for troubleshooting stainless steel welding-related problems -AWS (2013)
