Page 2 of 9 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 100
Thread: CEN Standards Collection 1/370: CEN TC 121 - Welding & Allied Processes
  1. #13
    Re: CEN standars collection 1/100: CEN TC 121 - Welding & Allied Processes
    Small update:
    English versions of this standards:
    EN ISO 3690:2012 Welding and allied processes - Determination of hydrogen content in arc weld metal (ISO 3690:2012)
    EN ISO 22825:2012 Non-destructive testing of welds - Ultrasonic testing - Testing of welds in austenitic steels and nickel-based alloys (ISO 22825:2012)
    EN ISO 15614-12:2014 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 12: Spot, seam and projection welding (ISO 15614-12:2014)
    EN ISO 18592:2009 Resistance welding - Destructive testing of welds - Method for the fatigue testing of multi-spot-welded specimens (ISO 18592:2009)
    EN ISO 15614-13:2012 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 13: Upset (resistance butt) and flash welding (ISO 15614-13:2012)
    or
  3. Re: CEN standars collection 1/100: CEN TC 121 - Welding & Allied Processes
    Mediafire link already death!
    New link:
    dont mind on name
    So, I've checked it today, there are 3 new standards, so we are now missing 9 of them, if anyone can distribute any of missing standards... :
    EN ISO 636:2015 Welding consumables - Rods, wires and deposits for tungsten inert gas welding of non-alloy and fine-grain steels - Classification (ISO 636:2015)
    EN ISO 1071:2003 Welding consumables - Covered electrodes, wires, rods and tubular cored electrodes for fusion welding of cast iron - Classification (ISO 1071:2015)
    EN ISO 18273:2015 Welding consumables - Wire electrodes, wires and rods for welding of aluminium and aluminium alloys - Classification (ISO 18273:2015)
    EN ISO 17683:2015 Ships and marine technology - Ceramic weld backing for marine use (ISO 17683:2014)
    EN ISO 2503:2009/ A1:2015 Gas welding equipment - Pressure regulators and pressure regulators with flow-metering devices for gas cylinders used in welding, cutting and allied processes up to 300 bar (30 MPa) (ISO 2503:2009/Amd 1:2015)
    EN ISO 5172:2006/A2:2015 Gas welding equipment - Blowpipes for gas welding, heating and cutting - Specifications and tests (ISO 5172:2006/Amd 2:2015)
    EN ISO 7291:2010/ A1:2015 Gas welding equipment - Pressure regulators for manifold systems used in welding, cutting and allied processes up to 30 MPa (300 bar) (ISO 7291:2010/AMD 1:2015)
    EN ISO 9018:2015 Destructive tests on welds in metallic materials - Tensile test on cruciform and lapped joints (ISO 9018:2015)
    EN ISO 17641-2:2015 Destructive tests on welds in metallic materials - Hot *****ing tests for weldments - Arc welding processes - Part 2: Self-restraint tests (ISO 17641-2:2015)
  6. Re: CEN standars collection 1/100: CEN TC 121 - Welding & Allied Processes
    Thank you very much!
  7. #17
    Mar 2011
    Bontang, Kalimantan Timur, Indonesia, Indonesia
    Danke...
    thank you..
    Matur nuwun..
  9. #18
    Thanks a lot!
    Great standards base.
  10. #19
    Thanks a lot!
  11. #20
    now I made more updates with some missing standards thanx to 66geepee, mohamed and some other egpet members...
    ok; now we missing this 4 standards, if anyone have, please share it:
    EN ISO 17683:2015 Ships and marine technology - Ceramic weld backing for marine use (ISO 17683:2014) -I AM SPECIALLY LOOKING FOR THIS ONE LONG TIME
    EN ISO 8430-1:2016 Resistance spot welding - Electrode holders - Part 1: Taper fixing 1:10 (ISO 8430-1:2016)
    EN ISO 8430-2:2016 Resistance spot welding - Electrode holders - Part 2: Morse taper fixing (ISO 8430-2:2016)
    EN ISO 8430-3:2016 Resistance spot welding - Electrode holders - Part 3: Parallel shank fixing for end thrust (ISO 8430-3:2016)
    new links with updated standards:
    mediafire link comin tomorrow
  12. #21
  13. #22
    Re: CEN Standards Collection 1/300: CEN TC 121 - Welding & Allied Processes
    and mediafire link:
  14. #23
    Update:
    EN ISO 636-2015 : Welding consumables - Rods, wires and deposits for tungsten inert gas welding of non-alloy and fine-grain steels - Classification (ISO 636:2015)
    link fixed in excel, I'm not sure if I uploaded that standard so far now
    EN ISO 1071-2015: Welding consumables - Covered electrodes, wires, rods and tubular cored electrodes for fusion welding of cast iron - Classification (ISO 1071:2015)
    also uploaded and updated link
    EN ISO 15792-1:2008 Welding consumables - Test methods - Part 1: Test methods for all-weld metal test specimens in steel, nickel and nickel alloys (ISO 15792-1:2000) - better quality copy of standard
    EN ISO 15792-2:2008 Welding consumables - Test methods - Part 2: Preparation of single-run and two-run technique test specimens in steel (ISO 15792-2:2000) - better quality
    EN ISO 17634:2015 Welding consumables - Tubular cored electrodes for gas shielded metal arc welding of creep-resisting steels - Classification (ISO 17634:2015) - better quality
    - fixed link in excel
    EN ISO 18276:2006 Welding consumables - Tubular cored electrodes for gas-shielded and non-gas-shielded metal arc welding of high-strength steels - Classification (ISO 18276:2005) - still scanned but better quality
    EN ISO 14555:2014 Welding - Arc stud welding of metallic materials (ISO 14555:2014) - added corrected version
    EN 14717:2005 Welding and allied processes - Environmental check list - added corrected version
    EN ISO 25980: 2014 Health and safety in welding and allied processes - Transparent welding curtains, strips and screens for arc welding processes (ISO 25980:2014) - added better quality
    EN 1711:2000 Non-destructive examination of welds - Eddy current examination of welds by complex plane analysis - deleted cause it's not valid anymore
    EN ISO 10863:2011 Non-destructive testing of welds - Ultrasonic testing - Use of time-of-flight diffraction technique (TOFD) (ISO 10863:2011) - instead of FDIS now we have valid standard
    EN 1256:2006 Gas welding equipment - Specification for hose assemblies for equipment for welding, cutting and allied processes - better quality added
    EN ISO 7287:2002 Graphical symbols for thermal cutting equipment (ISO 7287:2002) - added better quality with GER/EN version
    EN ISO 9013:2002 Thermal cutting - Classification of thermal cuts - Geometrical product specification and quality tolerances (ISO 9013:2002) - added better quality
    EN 1708-3:2012 Welding - Basic weld joint details in steel - Part 3: Clad, buttered and lined pressurized components - replaced by EN version
    EN ISO 9692-2:1998 Welding and allied processes - Joint preparation - Part 2: Submerged arc welding of steels (ISO 9692-2:1998) - added better quality
    EN ISO 9692-2:1998/AC:1999 Welding and allied processes - Joint preparation - Part 2: Submerged arc welding of steels (ISO 9692-2:1998)- better quality
    EN ISO 9692-3:2001 Welding and allied processes - Recommendations for joint preparation - Part 3: Metal inert gas welding and tungsten inert gas welding of aluminium and its alloys (ISO 9692-3:2000) - better quality
    EN ISO 9692-3:2001/A1:2003 Welding and allied processes - Recommendations for joint preparation - Part 3: Metal inert gas welding and tungsten inert gas welding of aluminium and its alloys (ISO 9692-3:2000) - better quality
    EN ISO 9692-4:2003 Welding and allied processes - Recommendations for joint preparation - Part 4: Clad steels (ISO 9692-4:2003) - better quality
    CEN ISO/TR 14745: 2015 Welding - Post-weld heat treatment parameters for steels (ISO/TR 14745:2015) - better quality
    EN ISO 15609-2:2001 Specification and qualification of welding procedures for metallic materials - Welding procedure specification - Part 2: Gas welding (ISO 15609-2:2001) - better quality
    EN ISO 15609-2:2001/A1:2003 Specification and qualification of welding procedures for metallic materials - Welding procedure specification - Part 2: Gas welding (ISO 15609-2:2001) - better quality
    EN ISO 15614-3:2008 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 3: Fusion welding of non-alloyed and low-alloyed cast irons (ISO 15614-3:2008) - better quality
    EN ISO 15614-4:2005/AC:2007 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 4: Finishing welding of aluminium castings (ISO 15614-4:2005/Cor 1:2007) - better quality
    EN ISO 18278-1:2015 Resistance welding - Weldability - Part 1: Assessment of weldability for resistance spot, seam and projection welding of metallic materials (ISO 18278-1:2015) - better quality
    EN ISO 22827-2:2005 Acceptance tests for Nd:YAG laser beam welding machines - Machines with optical fibre delivery - Part 2: Moving mechanism (ISO 22827-2:2005) - better quality
    EN ISO 9453:2014 Soft solder alloys - Chemical compositions and forms (ISO 9453:2014) - better quality
    CEN/TR 15235:2005 Welding - Methods for assessing imperfections in metallic structures - better quality
    EN ISO 15653:2010 Metallic materials - Method of test for the determination of quasistatic fracture toughness of welds (ISO 15653:2010) - better quality
    EN ISO 5182:2009 Resistance welding - Materials for electrodes and ancillary equipment (ISO 5182:2008) - better quality
    so we are now missing this:
    EN ISO 18278-2:2016 Resistance welding - Weldability - Part 2: Evaluation procedures for weldability in spot welding (ISO 18278-2:2016)
    EN ISO 9015-2:2016 Destructive tests on welds in metallic materials - Hardness testing - Part 2: Microhardness testing of welded joints (ISO 9015-2:2016)
    anyone have it?!
    updated linkz:
    have some problems with mediafire so i'll try to upload it later there
  16. #24
    Can you please reupload to Mediafire?
  1. Replies: 9
    Last Post: 07-10-2019, 01:40 PM
  2. ISO Collection 11/300:ISO/TC 44 - Welding and allied processes
    Last Post: 05-30-2019, 03:20 PM
  3. DIN SPEC of NA 092 - Welding and allied processes
    Last Post: 01-09-2017, 02:06 AM
  4. ISO 6947:2011 Welding and allied processes -- Welding positions
    By KVladimir in forum Mechanical Engineering
    Last Post: 10-18-2015, 06:04 PM
  5. EN 14610 - Welding and allied processes
    Last Post: 04-09-2012, 09:19 AM
