Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 13 to 24 of 32
Thread: some ASTMs needed (A20, A182, A216, A240, A285, A312, A321, A350, A420, A450 & A672)
  1. #13
    Re: some ASTMs needed (A20, A182, A216, A240, A285, A312, A321, A350, A420, A450 & A6
    A333A333M-15 Standard Specification for Seamless and Welded Steel Pipe for Low-Temperature Service and Other Applications with Required Notch Toughness
    A335A335M-15a Standard Specification for Seamless Ferritic Alloy-Steel Pipe for High-Temperature Service
    A387A387M-11 Standard Specification for Pressure Vessel Plates, Alloy Steel, Chromium- Molybdenum
    A403A403M-15 Standard Specification for Wrought Austenitic Stainless Steel Piping Fittings
    A515A515M-10(2015) Standard Specification for Pressure Vessel Plates, Carbon Steel, for Intermediate- and Higher-Temperature Service
    A516A516M-10(2015) Standard Specification for Pressure Vessel Plates, Carbon Steel, for Moderate- and Lower-Temperature Service
    A530A530M-12 Standard Specification for General Requirements for Specialized Carbon and Alloy Steel Pipe
    A671A671M-14 Standard Specification for Electric-Fusion-Welded Steel Pipe for Atmospheric and Lower Temperatures
    A672A672M-14 Standard Specification for Electric-Fusion-Welded Steel Pipe for High- Pressure Service at Moderate Temperatures
    A789A789M-14 Standard Specification for Seamless and Welded Ferritic-Austenitic Stainless Steel Tubing for General Service
    A790A790M-14a Standard Specification for Seamless and Welded Ferritic-Austenitic Stainless Steel Pipe
    A999A999M-14 General Requirements for Alloy and Stainless Steel Pipe
  6. Re: some ASTMs needed (A20, A182, A216, A240, A285, A312, A321, A350, A420, A450 & A6
    HI Sir,
    Million Thanks,
    For sharing these recent edition of ASTM's
    I need ASTM A105-2015 if you have it, Could you please share it with the group.
    With regards
    AKASH
  7. Re: some ASTMs needed (A20, A182, A216, A240, A285, A312, A321, A350, A420, A450 & A6
    Good evening!!
    Could you help me with ASTM A500 -2013 and ASTM A106-2013??
    Thanks in advance.
    Greetings from Ecuador.
  9. #18
    Aug 2015
    Dubai, UAE
    Blog Entries
    4
    Quote Originally Posted by joseluis1542 View Post
    Good evening!!
    Thanks in advance.
    here u go
  10. Re: some ASTMs needed (A20, A182, A216, A240, A285, A312, A321, A350, A420, A450 & A6
    Quote Originally Posted by amjadmalik75 View Post
    here u go
    Thanks amjadmalik75. I appreciate it very much.
    A500 is great for me, but I need ASTM A106-2013: Standard Specification for Seamless Carbon Steel Pipe for High-Temperature Service not ASTM A1604. If you have, please please send it.
    Thanks in advance.
  11. #20
    thanks amjadmalik75. I appreciate it very much.
    A500 is great for me, but i need astm a106-2013: Standard specification for seamless carbon steel pipe for high-temperature service not astm a1604. If you have, please please send it.
    Thanks in advance.
    a106-2015
  12. #21
  13. Re: some ASTMs needed (A20, A182, A216, A240, A285, A312, A321, A350, A420, A450 & A6
    Quote Originally Posted by Marty Thompson View Post
    a106-2015
    Hey Marty... I really really appreciate it very much. But I need 2013 version of A106 because I have some problems with an ASME Inspector. And he ask me for that version. I am going to keep searching.
    Thanks a lot.
  14. #23
    A106-2013
    Attached Files Attached Files
  16. Re: some ASTMs needed (A20, A182, A216, A240, A285, A312, A321, A350, A420, A450 & A6
    Thanks thanks thanks... Marty.
    You are the man!!!
  1. ASTM-A312 latest version
    By thiagorcollis1 in forum Mechanical Engineering
    Last Post: 10-29-2014, 09:34 PM
  2. Using A350/LF2 instead of A105
    By ezat2007 in forum Mechanical Engineering
    Last Post: 01-07-2014, 12:30 PM
  3. need ASTM A105/A105M and ASTM A182/A182M Ed. 2010
    By Riccardo in forum Materials Science &Corrosion
    Last Post: 10-03-2013, 11:14 AM
  4. Anyone able to share ASTM A312-12a
    By Rads53 in forum Laboratory Measurements
    Last Post: 08-02-2013, 05:43 AM
  5. A350 LF2 In Place of A105
    By ishaf5 in forum Materials Science &Corrosion
    Last Post: 04-18-2013, 05:15 PM
